« on: December 10, 2012, 03:21:22 pm » |
I just want to print to the serial every digitalread bit I catch.
How to do that ? How to use a buffer to do that ?
Thanks
Seattle, WA USA
Seattle, WA USA
« Reply #1 on: December 10, 2012, 03:23:57 pm » |
How to do that ? int digitalReadBit = digitalRead(theRightPin); Serial.print(digitalReadBit); How to use a buffer to do that ? int buffer[1]; buffer[0] = digitalRead(theRightPin); Serial.print(buffer[0]); Though why you want to use a buffer is a mystery.
« Reply #2 on: December 10, 2012, 03:28:44 pm » |
that way i would print on the serial a bit as a byte.
Am I wrong ? I want raw bits
Seattle, WA USA
Seattle, WA USA
« Reply #3 on: December 10, 2012, 03:34:13 pm » |
Am I wrong ? I want raw bits Well, don't cook them. What do you mean? The digitalRead() function returns an int, whose values are either 0 or 1. That looks like bits to me.
« Reply #4 on: December 10, 2012, 03:54:30 pm » |
if you Serial.print(0) it should give 00110000, not 00000000
instead I want:
byte = read_8_bits() Serial.print(byte)
Seattle, WA USA
Seattle, WA USA
« Reply #5 on: December 10, 2012, 03:59:35 pm » |
if you Serial.print(0) it should give 00110000 How do you figure that 0 is 110,000? If that value is binary, the decimal equivalent is 48, which, coincidentally enough, just happens to be the ASCII code for a 0. So, if you print '0' like so: Serial.print('0', BIN); you will get 00110000. But that has NOTHING to do with raw bits from digitalRead().
« Reply #6 on: December 10, 2012, 04:11:57 pm » |
I guess. From the manual: Serial/Print: Prints data to the serial port as human-readable ASCII text.
If digitalRead(mypin) is == 0 then: print somehow to the serial a 0 bit if digitalRead(mypin) == 1 then: print somehow to the serial a 1 bit
That's what I need. I hope i explained it better. Thanks
UK
« Reply #7 on: December 10, 2012, 04:17:58 pm » |
byte = read_8_bits() Serial.print(byte) Trying to print the name of a datatype is going to give you problems. If digitalRead(mypin) is == 0 then: print somehow to the serial a 0 bit if digitalRead(mypin) == 1 then: print somehow to the serial a 1 bit Serial.print ((byte)digitalRead (mypin));
Left Coast, CA (USA)
Measurement changes behavior
« Reply #8 on: December 10, 2012, 04:20:33 pm » |
instead I want:
Perhaps you mean you wish to read and print out AVR I/O ports that can contain up to 8 bits? as in: int portByte = PIND; //Read AVR port D bits which correspond to arduino pins 0-7 on a 328 based board Serial.print(portByte, BIN); http://playground.arduino.cc/Learning/PortManipulationLefty
« Last Edit: December 10, 2012, 04:23:18 pm by retrolefty »
UK
« Reply #9 on: December 10, 2012, 04:25:46 pm » |
I want raw bits
I'm not clear what format you're trying to output, but if you want to output binary data instead of ascii characters then you might want to look at write() instead of print(). If you want to collect eight digitalRead() results and pack them into a byte and then output that as a binary value then you need to use bitSet()/bitClear() or the equivalent bitwise operators to build the byte and then write that value out. I'm only guessing what you're trying to achieve, though, because you haven't actually said.
Saskatchewan
When the going gets weird, the weird turn pro. - Hunter S. Thompson
« Reply #10 on: December 10, 2012, 04:34:03 pm » |
Here's how I'm seeing the request byte pinState = digitalRead(mypin); if (pinState == HIGH) Serial.println("1"; else Serial.println("0");
Shrug ...
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #11 on: December 10, 2012, 04:36:13 pm » |
Would this work? void setup () { Serial.begin (115200); } // end of setup void loop () { Serial.println (PINB, BIN); delay (1000); } // end of loop
« Reply #12 on: December 10, 2012, 05:28:20 pm » |
Very easy: void sprintf_byte(unsigned char dat) { unsigned char mask = 0x80; //msb first do { if (dat & mask) Serial.print("1"); //print1 else Serial.print("0"); //print 0 mask = mask >> 1; //shift to the next bit } while (mask); }
void sprintf_short(unsigned short dat_word) { sprintf_byte(dat_word >> 8); //printf msb sprintf_byte(dat); //print lsb }
