Cologne
« Reply #15 on: December 16, 2012, 05:18:26 pm » |
Ich habe das oben erwähnte Programm mal für den Zweck der Messung der Implulse angepasst. // Das ursprüngliche Programm stammte von /* * Author..... Walter Anderson * E-mail..... wandrson@walteranderson.us * * Source: http://playground.arduino.cc/Code/InfraredReceivers */ #include <avr/interrupt.h> #include <avr/io.h>
#define TIMER_RESET TCNT1 = 0 #define SAMPLE_SIZE 128
int IRpin = 2; unsigned int TimerValue[SAMPLE_SIZE]; char direction[SAMPLE_SIZE]; byte change_count; long time;
void setup() { Serial.begin(115200); Serial.println("Analyze IR Remote"); TCCR1A = 0x00; // COM1A1=0, COM1A0=0 => Disconnect Pin OC1 from Timer/Counter 1 -- PWM11=0,PWM10=0 => PWM Operation disabled // ICNC1=0 => Capture Noise Canceler disabled -- ICES1=0 => Input Capture Edge Select (not used) -- CTC1=0 => Clear Timer/Counter 1 on Compare/Match // CS12=0 CS11=1 CS10=1 => Set prescaler to clock/64 TCCR1B = 0x03; // 16MHz clock with prescaler means TCNT1 increments every 4uS // ICIE1=0 => Timer/Counter 1, Input Capture Interrupt Enable -- OCIE1A=0 => Output Compare A Match Interrupt Enable -- OCIE1B=0 => Output Compare B Match Interrupt Enable // TOIE1=0 => Timer 1 Overflow Interrupt Enable TIMSK1 = 0x00; pinMode(IRpin, INPUT); }
void loop() { Serial.println("Waiting..."); change_count = 0; while(digitalRead(IRpin) == LOW) {} TIMER_RESET; TimerValue[change_count] = TCNT1; direction[change_count++] = '1'; while (change_count < SAMPLE_SIZE) { if (direction[change_count-1] == '0') { while(digitalRead(IRpin) == LOW) {} TimerValue[change_count] = TCNT1; direction[change_count++] = '1'; TIMER_RESET; } else { while(digitalRead(IRpin) == HIGH) {} TimerValue[change_count] = TCNT1; direction[change_count++] = '0'; TIMER_RESET; } } Serial.println("Bit stream detected!"); change_count = 1; time = (long) TimerValue[change_count] * 4; while (change_count < SAMPLE_SIZE) { time = (long) TimerValue[change_count] * 4; Serial.print(time); Serial.print("\t"); Serial.println(direction[change_count-1]); change_count++; } Serial.println("Bit stream end!"); delay(2000); }
Wenn man Glück hat und einen gültigen Datenstrom einfangen kann, sieht das ganz gut aus. Allerdings kommt wie bereits schon gesagt auch viel Müll an. Hier mal ein gutes Beispiel. Analyze IR Remote Waiting... Bit stream detected! 28 1 189448 0 12 1 240792 0 4 1 176688 0 12 1 122560 0 164 1 8112 0 152 1 1060 0 148 1 1060 0 148 1 2084 0 152 1 1052 0 156 1 1060 0 148 1 2084 0 152 1 1064 0 144 1 1064 0 148 1 1060 0 148 1 1068 0 136 1 1064 0 152 1 1056 0 156 1 1064 0 136 1 1064 0 140 1 1068 0 136 1 1072 0 144 1 1064 0 148 1 2096 0 144 1 1064 0 140 1 1068 0 144 1 2088 0 144 1 2088 0 152 1 1060 0 140 1 1072 0 140 1 2096 0 140 1 2108 0 136 1 2088 0 148 1 1060 0 148 1 2096 0 140 1 2096 0 140 1 2092 0 148 1 2092 0 144 1 2096 0 148 1 2092 0 148 1 2092 0 144 1 1072 0 136 1 8120 0 144 1 1064 0 140 1 1076 0 136 1 2088 0 148 1 1068 0 136 1 1060 0 148 1 2088 0 144 1 1064 0 140 1 1072 0 148 1 1064 0 148 1 1064 0 140 1 1068 0 128 1 1068 0 140 1 1064 0 148 1 1064 0 144 1 1072 0 136 1 1068 0 136 1 1084 0 132 1 2100 0 128 1 1068 0 140 1 1068 0 136 1 2108 0 132 1
In Excel oder LibreOffice Calc kann man dann die Häufigkeit des Vorkommens ermitteln und daraus die Entscheidungsschwellen für die Erkennung ableiten. Die HIGH Pegel zwischen den Datenbits sind zwischen 136 und 148us der Synchronisierungsimpuls ist 8120us die "0" Datenbits entsprechen 1064us die "1" Bits entsprechen 2090us (alles ca. Werte)
Germany S-H
« Reply #16 on: December 17, 2012, 04:26:43 am » |
Ich glaube, ich möchte zur Vorab-Analyse von Wettersensoren lieber etwas, das mir die gültigen Datenströme automatisch einfängt und dabei nur möglichst wenig Datenmüll ausgibt. Im besten Fall sollen nur die Wettersensoren selbst, eventuell Fragmente von den Wettersensoren aus der Nachbarschaft, die nur bruchstückhaft empfangen werden weil sie eigentlich außer Reichweite sind, und nur ganz wenig Datenmüll empfangen werden. Und es soll rein mit Arduino funktionieren, ohne Umweg über Soundkarte oder externe Programme. Mal schauen, was ich mir dazu selbst programmieren kann.
Cologne
« Reply #17 on: December 17, 2012, 04:36:20 am » |
Super, ich bin sehr gespannt!
Germany S-H
« Reply #18 on: December 17, 2012, 05:51:57 pm » |
So, ich habe nun nochmal etwas an den Datentelegrammen verschiedener 433 MHz Sensoren geforscht und mein Vorauswertungsprogramm für Datenpakete zeigt erste Zuckungen. Meine Sensoren liefern allesamt längere Impulse als Dein Tchibo-Sensor, die Werte liegen mehr bei: HIGH Pegel zwischen den Bits: 475 us Startbit/Sync bei ca. 9000 us die "0" Datenbits entsprechen 2000us die "1" Bits entsprechen 4000us Die High-Pegel von "Datenmüll" scheinen sehr oft bei weniger als 50 us zu liegen. Ich glaube, da werde ich mir mal ein paar plausible Grenzwerte setzen, z.B.: HIGH Pegel zwischen den Bits: mindestens 50 us oder länger Startbit mindestens 5000 us oder länger "0" Datenbits mindestens 500 us oder länger "1" Bits länger als "0" Bits Anzahl der Datenbits: 20 oder mehr Und dann versuchen, was dann noch übrig bleibt an Bits einigermaßen vernünftig aus dem Äther zu fischen und als "Vorauswertung" auszugeben. Merkwürdigerweise scheine ich verschiedene Sensoren zu haben, die ziemlich ähnliche aber trotzdem verschiedene Protokolle aussenden (identische Bit-Längen und 36-Bit Datenpakete), und trotzdem weiß die zum Sensor gehörende Basisstation, welche 36 Bits zu ihr gehören und zeigt korrekt an. Das müssen die Basisstationen dann wohl anhand von "Stationsnummern" und "Prüfsummen" unterscheiden können, welche Daten für sie bestimmt sind - und welche nicht. Nachtrag: Ich werde es auch gleich noch kompatibel zur Erkennung von Funktelegrammen machen, die von Fernbedienungen für Funksteckdosen ausgesendet werden. Die Bitfolgen für die Steuerung von Funksteckdosen sind meisten wesentlich kürzer als die von Wettersensoren. Hier getestet mehr bei 20 Bit (Funksteckdose) statt 36 Bit (Funk-Thermometer). Außerdem ist das Startbit für die Funksteckdosen unheimlich lang: 80000 us. Das ist länger als es in einen Integer hineinpasst, da werde ich mir noch etwas einfallen lassen. Und den Sketch dann mal posten.
« Last Edit: December 18, 2012, 07:14:01 am by jurs »
Germany S-H
« Reply #19 on: December 18, 2012, 09:59:05 am » |
So ein Mist, jetzt wollte ich meinen Funkanalyes-Sketch für 433MHz-Funkgerätschaften wie handelsübliche Funk-Thermometer und Funk-Steckdosen posten, schreibe noch sehr ausführlichen Text dazu, Anwendung, Funktionsweise, Hintergründe, und dann meldet das Forum beim Posten des vollständig ausgearbeiteten Beitrags einen Fehler: Kompletter Beitrag weg! Jetzt poste ich einfach nur mal den Code des Sketches. /* Sketch zur Vorab-Analyse unbekannter 433-MHZ-Wettersensoren und Fernbedienungen von 433MHz-Funksteckdosen Inspiriert durch Beiträge im Arduino-Forum: http://arduino.cc/forum/index.php/topic,119739.0.html http://arduino.cc/forum/index.php/topic,136836.0.html Hardware: 1. Arduino-Board mit 433 MHz Regenerativempfänger für ASK/OOK, angeschlossen an einem interruptfähigen Pin. 2. Funksensor entweder eines 433 MHz Funkthermometers oder Funk-Wetterstation oder Steckdosen-Funkfernbedienung Analysiert werden können Sensoren mit folgendem Funkprotokoll: - extra langes Startbit (extra langer LOW Pulse am Receiver) - langes 1-Datenbit (langer LOW Pulse am Receiver) - kurzes 0-Datenbit (kurzer LOW Pulse am Receiver) - sehr kurze Trenn-Impulse zwischen den Datenbits (sehr kurze HIGH-Impulse am Receiver) - 20 bis 50 Datenbits pro Datenpaket Diese Art Funkprotokoll trifft auf die meisten billigen 433 MHZ Funkthermometer, Funk-Wetterstationen und Funk-Steckdosen zu. Ausgabe ueber den seriellen Monitor Je erkanntem Datenpaket am Receiver wird ausgegeben: - Länge des Startbits (Mikrosekunden LOW) und des nachfolgenden HIGH-Impulses - Anzahl der erkannten Datenbits im Datenpaket - Länge aller erkannten Datenbits (Mikrosekunden LOW) - Länge der zwischen den Datenbits erkannten Pausen (Mikrosekunden HIGH) - die als 0/1-Bitstrom decodierten Datenbits des Datenpakets Nur Vorab-Analyse des Timings im Funkprotokoll! In einem weiteren Schritt muss dann die Bedeutung der Bits und die Umsetzung in Messwerte erst noch detalliert decodiert werden, dieser Sketch erkennt nur das Timing und die Groesse der Datenpakete! */
// connect data pin of rx433 module to a pin that can handle hardware interrupts // with an Arduino UNO this is digital I/O pin 2 or 3 only #define RX433DATAPIN 2
// hardware interrupt connected to the pin // with Arduino UNO interrupt-0 belongs to pin-2, interrupt-1 to pin-3 #define RX433INTERRUPT 0
// Set speed of serial in Arduino IDE to the following value #define SERIALSPEED 115200
// Now make some suggestions about pulse lengths that may be detected // minimum duration (microseconds) of the start pulse #define MINSTARTPULSE 4500
// minimum duration (microseconds) of a short bit pulse #define MINBITPULSE 450
// minimum duration (microseconds) of a HIGH pulse between valid bits #define MINHITIME 50
// variance between pulses that should have the same duration #define PULSEVARIANCE 250
// minimum count of data bit pulses following the start pulse #define MINPULSECOUNT 20
// maximum count of data bit pulses following the start pulse #define MAXPULSECOUNT 50
// buffer sizes for buffering pulses in the interrupt handler #define PBSIZE 216
void setup() { Serial.begin(115200); Serial.println(); Serial.println("Start!"); pinMode(RX433DATAPIN, INPUT); attachInterrupt(RX433INTERRUPT, rx433Handler, CHANGE); }
volatile unsigned int pulsbuf[PBSIZE]; // ring buffer storing LOW pulse lengths volatile unsigned int hibuf[PBSIZE]; // ring buffer storing HIGH pulse lengths unsigned int validpulsbuf[MAXPULSECOUNT]; // linear buffer storing valid LOW pulses unsigned int validhibuf[MAXPULSECOUNT]; // linear buffer storing valid HIGH pulses
volatile byte pbread,pbwrite; // read and write index into ring buffer
void rx433Handler() { static long rx433LineUp, rx433LineDown; long LowVal, HighVal; int rx433State = digitalRead(RX433DATAPIN); // current pin state if (rx433State) // pin is now HIGH { rx433LineUp=micros(); // line went HIGH after being LOW at this time LowVal=rx433LineUp - rx433LineDown; // calculate the LOW pulse time if (LowVal>MINBITPULSE) { // store pulse in ring buffer only if duration is longer than MINBITPULSE // To be able to store startpulses of more than Maxint duration, we dont't store the actual time, // but we store MINSTARTPULSE+LowVal/10, be sure to calculate back showing the startpulse length! if (LowVal>MINSTARTPULSE) LowVal=MINSTARTPULSE+LowVal/10; // we will store this as unsigned int, so do range checking
pulsbuf[pbwrite]=LowVal; // store the LOW pulse length pbwrite++; // advance write pointer in ringbuffer if (pbwrite>=PBSIZE) pbwrite=0; // ring buffer is at its end } } else { rx433LineDown=micros(); // line went LOW after being HIGH HighVal=rx433LineDown - rx433LineUp; // calculate the HIGH pulse time if (HighVal>31999) HighVal=31999; // we will store this as unsigned int hibuf[pbwrite]=HighVal; // store the HIGH pulse length } }
boolean counting; byte i,counter; int startBitDurationL,startBitDurationH,shortBitDuration,longBitDuration;
void showBuffer() // this function will show the results on the serial monitor // output will be shown if more bits than MINPULSECOUNT have been collected { long sum; int avg; sum=0; if (counter>=MINPULSECOUNT) { // only show buffer contents if it has enough bits in it Serial.println(); Serial.print("Start Bit L: "); Serial.print((startBitDurationL-MINSTARTPULSE)*10L); Serial.print(" H: ");Serial.println(startBitDurationH); Serial.print("Data Bits: ");Serial.println(counter); Serial.print("L: "); for (i=0;i<counter;i++) { Serial.print(validpulsbuf[i]);Serial.print(" "); sum+=validpulsbuf[i]; } Serial.println();
Serial.print("H: "); for (i=0;i<counter;i++) { Serial.print(validhibuf[i]);Serial.print(" "); } Serial.println();
avg=sum/counter; // calculate the average pulse length // then assume that 0-bits are shorter than avg, 1-bits are longer than avg for (i=0;i<counter;i++) { if (validpulsbuf[i]<avg) Serial.print('0'); else Serial.print('1'); } Serial.println(); } counting=false; counter=0; } void loop() { long lowtime, hitime; if (pbread!=pbwrite) // check for data in ring buffer { lowtime=pulsbuf[pbread]; // read data from ring buffer hitime=hibuf[pbread]; cli(); // Interrupts off while changing the read pointer for the ringbuffer pbread++; if (pbread>=PBSIZE) pbread=0; sei(); // Interrupts on again if (lowtime>MINSTARTPULSE) // we found a valid startbit! { if (counting) showBuffer(); // new buffer starts while old is still counting, show it first startBitDurationL=lowtime; startBitDurationH=hitime; counting=true; // then start collecting bits counter=0; // no data bits yet } else if (counting && (counter==0)) // we now see the first data bit { // this may be a 0-bit or a 1-bit, so make some assumption about max/min lengths of data bits that will follow shortBitDuration=lowtime/2; if (shortBitDuration<MINBITPULSE+PULSEVARIANCE) shortBitDuration=MINBITPULSE; else shortBitDuration-=PULSEVARIANCE; longBitDuration=lowtime*2+PULSEVARIANCE; validpulsbuf[counter]=lowtime; validhibuf[counter]=hitime; counter++; } else if (counting&&(lowtime>shortBitDuration)&&(lowtime<longBitDuration)) { validpulsbuf[counter]=lowtime; validhibuf[counter]=hitime; counter++; if ((counter==MAXPULSECOUNT) || (hitime<MINHITIME)) { showBuffer(); } } else // Low Pulse is too short { if (counting) showBuffer(); counting=false; counter=0; } } }
Ich habe jetzt keine Lust mehr, da nochmal zwanzig Minuten lang was zu schreiben und dann frisst das Forum den Text auf. :-( Wer Fragen hat, kann ja fragen. Feedback erwünscht!
Cologne
« Reply #20 on: December 18, 2012, 01:13:15 pm » |
Hallo jurs, super ! Musste ich natürlich direkt mit meinem Sensor ausprobieren. Hier die ersten Datensequenzen, wie sie auf dem seriellen Monitor ausgegeben werden. Hat auf Anhieb geklappt. Start!
Start Bit L: 8030 H: 208 Data Bits: 36 L: 1012 1012 2008 2016 2024 2016 1012 2016 1004 1012 1008 1016 1004 1012 1000 1012 1000 2028 996 1016 2020 1008 2016 2020 1008 1012 1012 1004 1020 2012 1012 996 1020 2016 2012 2016 H: 188 180 188 184 184 180 184 184 180 184 184 184 184 180 184 184 184 188 184 180 184 188 184 176 184 180 184 180 180 184 184 184 184 184 180 184 001111010000000001001011000001000111
Start Bit L: 8070 H: 184 Data Bits: 36 L: 1012 996 2016 2028 2012 2028 1020 2016 1020 1020 1020 1020 1016 1020 1016 1012 1008 2024 1012 1012 2036 1020 2016 2012 1020 996 1012 1012 1008 2016 1012 1012 1004 2020 2016 2028 H: 180 184 184 184 180 184 168 172 192 172 168 172 172 172 176 180 184 180 176 180 172 172 172 184 184 184 184 184 184 176 184 184 184 180 180 184 001111010000000001001011000001000111
Start Bit L: 8060 H: 180 Data Bits: 36 L: 1012 1008 2012 2020 2020 2020 1012 2024 1012 1016 1012 1008 1024 1004 1012 1016 1004 2024 1012 1016 2024 1008 2028 2016 1004 1012 1016 1000 1020 2012 1000 1012 1016 2012 2012 2012 H: 184 184 188 184 180 180 184 180 176 176 180 180 172 180 180 180 184 180 176 180 180 184 172 184 184 184 180 180 180 184 184 184 184 188 184 188 001111010000000001001011000001000111
000001000111 Temperatur 7.1 01001011 Feuchte 75% Die Daten meiner Fernbedienung für Funksteckdosen werden allerdings nicht dekodiert - die Anzeige bleibt leer.
Germany S-H
« Reply #22 on: December 18, 2012, 01:58:57 pm » |
So dachte ich mir das, dass es eben möglichst universell funktioniert und Daten verschiedener Sensoren zur Anzeige bringt. Danke für die Rückmeldung! Die Daten meiner Fernbedienung für Funksteckdosen werden allerdings nicht dekodiert - die Anzeige bleibt leer.
Hast Du geprüft, ob die Fernbedienung auch auf 433 MHz sendet? Hm, also bei mir funktioniert es mit einer Fernbedienung für ein "Quigg" Funksteckdosen-Set, und danach habe ich die Variable für die untere Datenbitzahl auf 20 gesetzt. Möglicherweise gibt es Funksteckdosen, die weniger als 20 Bit senden. Vielleicht mal probieren: #define MINPULSECOUNT 14 oder eine andere Zahl unter 20. Da Funksteckdosen nur ein/aus Befehle erhalten könnte es sein, dass es vielleicht auch bei einem Hersteller weniger als 20 übertragene Datenbits sind. Wie teuer waren die Funksteckdosen? Wenn sie überdurchschnittlich viel gekostet haben, bestünde auf 433 MHz auch die Möglichkeit, dass sie ihr Signal mit Frequenzmodulation statt mit Amplitudenmodulation modulieren. In dem Fall würde man zum Empfangen andere Empfänger benötigen (FM Receiver). Und auch mit Amplitudenmodulation sind andere Übertragungsverfahren denkbar, die ohne das extralange Startbit im Funkprotokoll auskommen, da müßte mein Sketch dann ebenfalls passen. Ist vielleicht irgendein Hersteller erkennbar, der Deine Funksteckdosen produziert hat? (Manchmal kann man Details dann im Internet googeln.) REV-Funksteckdosen scheinen das Nexa-Protokoll zu verwenden, das hier dargestellt wird: http://svn.telldus.com/svn/rf_ctrl/nexa_2_6_driver/trunk/NexaProtocol.txtDieses Protokoll kann von meinem Sketch gleich aus mehreren Gründen momentan nicht erkannt werden: a) Das Protokoll startet nicht mit einem besonders langen LOW Impuls als Startbit b) Die kürzesten LOW-Impulse im Protokoll sind nur 350 us lang, ich gehe standardmäßig von mindestens 450 us Bitdauer aus #define MINBITPULSE 450 Mit einigen Änderungen müßte es machbar sein, auch die REV-Datenpakete irgendwie einzufangen. Die haben zwar keinen extralangen LOW-Impuls am Anfang, dafür aber einen extralangen LOW-Impuls am Ende des Datenpakets. Da die Datenpakete viermal wiederholt werden, könnte man so den Sync-Impuls am Ende des ersten Pakets als Startbit des zweiten Pakets auffassen. So bekäme man dann zwar nur maximal 3 der 4 gesendeten Pakete eingefangen, aber immerhin sollte es möglich sein. Leider habe ich keine Möglichkeiten zum Testen, wenn ich die notwendigen Änderungen einbauen würde. erni-berni, sind Deines vielleicht REV-Funksteckdosen (oder kompatible wie Nexa, Proove oder ARC Technology)?
« Last Edit: December 18, 2012, 03:14:28 pm by jurs »
Cologne
« Reply #23 on: December 18, 2012, 05:32:02 pm » |
Hallo jurs, das Thema Funksteckdosen lässt sich abkürzen. Meine sind von Bahr und waren sehr günstig (Praktiker Angebot 4,99 für 3 Stück !!), Hersteller ELRO und 433 MHz. Das Protokoll entspricht dem PT2262 Protokoll, das sui in seiner Library dekodiert ( http://blog.sui.li/2011/04/12/low-cost-funksteckdosen-arduino/). Die Library wird ja auch erwähnt. Dieses Protokoll dieser Steckdosen arbeitet vollkommen anders als die Sensoren. Du müsstest also den Dekodier-Algorithmus der RCSwitch Lib in dein Programm einbauen.
Germany S-H
« Reply #24 on: December 19, 2012, 06:07:53 am » |
OK, das ist haargenau dasselbe wie das von mir ein Posting darüber verlinkte Nexa-Protokoll, das ein Hersteller Taiwan verwendet und das offensichtlich in ganz vielen Funksteckdosen weltweit zum Einsatz kommt, auf die vom taiwanesischen Hersteller ganz unterschiedliche Handelsmarken draufgepinselt werden. Dieses Protokoll dieser Steckdosen arbeitet vollkommen anders als die Sensoren.
Ja, die Funk-Wettersensoren senden eine einfache Bitlängencodierung, d.h. die Länge eines einzelnen Bits entscheidet, ob es ein 0-Bit oder ein 1-Bit ist, und zwar ist das Bit immer nur durch die Länge der LOW-Zeit zwischen zwei HIGH-Impulsen bestimmt. Im Nexa-Protokoll für die/viele Funksteckdosen sind es dagegen nicht einzelne High- oder Low-Impulse, in deren Dauer das Bit steckt, sondern jedes Bit wird mit zwei High- und zwei Low-Impulsen übertragen, insgesamt vier Flankenwechsel für ein Bit. Du müsstest also den Dekodier-Algorithmus der RCSwitch Lib in dein Programm einbauen.
Nö, das soll ja nur ein Vorab-Analyseprogramm sein. Das soll nur generell ermitteln, was so an 433MHz Datenpaketen in der Luft unterwegs ist. Und zwar um das Timing der Bits unbekannter Sensoren herauszubekommen. Bei den Funksteckdosen mit Nexa, REV, Proove, ARC-Technology, ELRO, PT2262 braucht man die Timings der Datenpakete ja gar nicht mehr herauszufinden: Die werden/wurden ja überhaupt nur mit zwei Timings hergestellt: Früher mit 650 us, heute mit 350 us Periodendauer T. Das sind dann ja eigentlich keine "unbekannten Sensoren" (auch wenn ein unbekannter Name draufsteht), sondern das Timing ist bekannt und welche Library man zur Dekodierung ansetzen kann. Mal schauen, wenn ich beim Praktiker/Max Bahr mal günstig eine dieser Funksteckdosen bekommen kann, ob ich das Analyse-Programm dann nicht wenigstens noch so weit aufbohre, dass es anzeigen kann: - Funksteckdosen-Datenpaket erkannt
« Reply #25 on: February 27, 2013, 05:35:48 am » |
Hallo ihr Code- Experten! Bin seit längerer Zeit beim Auswerten meiner 433MHz Temp-Sensoren mit dem RFM12 (OOK). Das Erkennen der drei unterschiedlichen Typen klappt hervorragend. Der Empfänger schnappt aber auch noch andere Signale auf, an denen ich mich jetzt auch noch üben will. Ist in dem Bild die Manchester-Codierung zu sehen? Vielleicht sieht es einer gleich und ich kann mir die Knobelei sparen... 1120 -804 1164 -788 1104 -332 632 -844 620 -328 1176 -804 1164 -304 612 -360 616 -348 628 -848 604 -360 -356 1152 -816 604 -328 -316 604 -872 1108 -832 604 -356 632 -344 1148 -804 632 -316 632 -360 1148 -300 644 -848 1136 -804 1104 -328 632 -360 632 -328 648 -832 632 -316 660 -328 1148 -304 632 -344 632 -344 616 -360 616 -360 616 -864 1108 -840 1120 -820 1104 -328 620 -356 604 -372 632 -852 600 -356 632 -332 1120 -344 632 -344 604 -372 588 -388 616 -344 632 -852 1128 -820 600 -348 660 -316 632 -328 644 -348 616 -344 660 -316 644 -332 632 -344 616 -360 616 -360 632 -344 620 -340 632 -344 620 -356 620 -356 604 -376 616 -344 644 -332 616 -360 616 -360 616 -344 632 -360 620 -324 648 -344 632 -328 632 -360 616 -344 632 -344 620 -372 632 -328 632 -344 648 -316 632 -344 616 -372 1108 -860 1104 -320 644 -328 648 -332 644 -832 632 -328 616 -348 1148 -832 1120 -816 616 -332 632 -344 632 -344 1148 -300 664 -828 576 10236 1076 -832 1148 -804 1120 -316 616 -360 632 -848 616 -344 1176 -776 616 -344 1148 -304 644 -332 632 -344 644 -832 604 -360 652 -324 1132 -832 604 -344 1148 -300 632 1160 -780 612 -344 620 -356 1120 -832 620 -344 632 -356 604 -360 1132 -832 1096 -844 1120 -332 600 -360 644 -332 628 -864 0 -360 616 -364 1128 -316 616 -360 660 -300 648 -344 632 -328 620 -872 1120 -820 1132 -804 1148 -304 600 -376 616 -364 628 -860 604 -344 616 -348 1132 -312 632 -360 632 -344 604 -372 588 -380 596 -876 1120 -816 604 -360 644 -316 632 -360 616 -360 644 -332 616 -360 620 -356 616 -360 616 -344 632 -344 616 -348 616 -372 588 -372 632 -348 628 -344 620 -356 620 -344 644 -332 616 -360 632 -344 616 -360 632 -344 632 -328 652 -312 644 -344 632 -344 632 -332 600 -376 628 -360 616 -348 616 -360 628 -332 648 -328 632 -348 1160 -804 1116 -332 616 -360 604 -356 632 -860 576 -372 1148 -304 644 -848 588 -360 1104 -860 1108 -328 648 -832 600 -344 632 -344 648 10652 1104 -820 1132 -804 1148 -300 652 -312 624 -868 588 -360 1164 -800 640 -308 1148 -316 620 -356 620 -356 620 -860 588 -360 628 -348 1148 -816 604 -360 1132 -316 632 -848 1148 -804 600 -344 648 -328 1164 -804 604 -356 632 -332 1148 -816 604 -360 1148 -816 1120 -316 632 -344 616 -360 660 -820 600 -360 616 -344 1152 -312 648 -328 620 -356 620 -344 632 -356 604 -860 1120 -832 1120 -820 1120 -328 632 -344 616 -348 632 -860 588 -360 616 -360 1148 -284 648 -344 616 -360 632 -344 644 -332 632 -844 1120 -820 604 -356 632 -332 644 -344 620 -344 644 -332 632 -344 648 -328 600 -360 616 -360 632 -360 616 -344 644 -332 604 -372 616 -348 628 -344 620 -356 620 -372 604 -356 620 -344 616 -372 608 -356 632 -344 632 -344 632 -344 632 -328 632 -344 616 -376 588 -372 616 -360 616 -360 616 -344 632 -344 648 -328 620 -344 1164 -816 1136 -300 632 -344 616 -360 616 -860 604 -344 648 -328 632 -332 660 -328 -316 616 -876 588 -360 1148 -316 628 -836 600 -376 616
« Last Edit: February 27, 2013, 09:20:35 am by mde110 »
Arduino 1.0.3|MEGA2560 SSD1289 TFT Touch|UGUI|DS18B20|SD|DS1307 ADNS2610|RFM12|OOK|SSD1303|DHT22
Germany S-H
« Reply #26 on: February 27, 2013, 05:54:44 am » |
Auf jeden Fall ist es keine einfache Bitbreitencodierung. Aber eine typische Manchestercodierung ist es auch nicht. Bei einem typischen Manchestercode hast Du zwei verschiedene High-Längen und zwei verschiedene Low-Längen, aber diese sind jeweils gleich. Du hast zwar auch je zwei verschiedene High-Längen und zwei verschiedene Low-Längen, aber diese sind jeweils verschieden lang. High: ca. 1100 und ca. 630 Low: ca. 820 und ca. 330 In der Summe scheinen der lange High-Impuls und der kurze Low-Impuls sowie der kurze High-Impuls und der lange Low-Impuls den gleichen Wert zu ergeben: 1100 + 330 = 1430 630 + 820 = 1450 Aber es ist ja nicht so, daß immer ein kurzer Low-Impuls auf einen langen High-Impuls folgt und umgekehrt. Ich habe keine Ahnung, was das für eine Codierung sein könnte.
Germany S-H
« Reply #28 on: April 10, 2013, 10:26:09 am » |
ich finde euren Artikel sehr interessant. Welchen Sender und Empfänger habt ihr benutzt? Ich habe z.b. so einen gefunden:
Ja, genau solche verwende ich auch. Allerdings bekommst Du für den Preis des Amazon Versenders bei Direktbestellung in China die fünffache Menge (also 5 Sender und 5 Empfänger) für den Preis, den der Amazon Versender bereits für nur ein Pärchen haben möchte. Das sind die allerbilligsten, die es für 433 MHz gibt.
« Reply #29 on: April 10, 2013, 10:59:38 am » |
Ich verwende das RFM12 und TFA 30.3125 Außensender.
