Loading...
Pages: [1]   Go Down
Author Topic: problem on case in switch statement in C#  (Read 572 times)
Offline Offline
Newbie
View Profile
hi everyone...would like to seek ur help in solving my problem..i have a problem of getting the warning sign...in addition, there an error stated that " control cannot fall through from one case label into another..im using c# language with visual basic 2010 ultimate software..
im also want to put the sign in serial..which means..when the transmitter sends the value of the voltage; the sign will appears accordingly.should i put the for statement for serial data?
tq
Code:
switch (waterlevel)
                    case "SAFE":
                        if (voltage >= 0.0 || voltage <= 0.50)
                            label_result.Text = " SAFE";
                            label_result.ForeColor = Color.Green;
                    case "WARNING":
                        if (voltage >= 0.50 || voltage <= 0.60)
                            label_result.Text = " WARNING";
                            label_result.ForeColor = Color.Yellow;
                    case "DANGER":
                        if (voltage >= 0.60 || voltage <= 0.70)
                            label_result.Text = " DANGER";
                            label_result.ForeColor = Color.Red;
                    default:
                        label_result.Text = "invalid";
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Code:
switch (waterlevel)
                    case "SAFE":
Lose the string.
switch/case doesn't work with strings (or Strings).
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
You most assuredly are not. You may be using C# with Visual Studio, but not to program the Arduino.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
In C# that is true, but not in C/C++.
Logged
Offline Offline
Newbie
View Profile
ok.AWOL...im declaring the water level as string...can u help me to debug my code?tq
Paul: yeah..this is visual studio 2010 ultimate..sorry for the mistakes..
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Sorry, no, I don't know any I-can't-believe-it's-not-Java C#
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Move the break statement outside the if body. The break should not be conditional.
Logged
Offline Offline
Newbie
View Profile
thanks Paul for the help..i have rectified the problem..
Logged
Pages: [1]   Go Up
Print
Jump to:
