Topic: problem on case in switch statement in C# (Read 3429 times) previous topic - next topic
arduino_learners
hi everyone...would like to seek ur help in solving my problem..i have a problem of getting the warning sign...in addition, there an error stated that " control cannot fall through from one case label into another..im using c# language with visual basic 2010 ultimate software..
im also want to put the sign in serial..which means..when the transmitter sends the value of the voltage; the sign will appears accordingly.should i put the for statement for serial data?
tq
switch (waterlevel)
                    case "SAFE":
                        if (voltage >= 0.0 || voltage <= 0.50)
                            label_result.Text = " SAFE";
                            label_result.ForeColor = Color.Green;
                            break;
                    case "WARNING":
                        if (voltage >= 0.50 || voltage <= 0.60)
                            label_result.Text = " WARNING";
                            label_result.ForeColor = Color.Yellow;
                            break;
                    case "DANGER":
                        if (voltage >= 0.60 || voltage <= 0.70)
                            label_result.Text = " DANGER";
                            label_result.ForeColor = Color.Red;
                            break;
                    default:
                        label_result.Text = "invalid";
                        break;
AWOL
switch (waterlevel)
                    case "SAFE":
Lose the string.
switch/case doesn't work with strings (or Strings).
PaulS
You most assuredly are not. You may be using C# with Visual Studio, but not to program the Arduino.
AWOL
In C# that is true, but not in C/C++.
arduino_learners
ok.AWOL...im declaring the water level as string...can u help me to debug my code?tq
Paul: yeah..this is visual studio 2010 ultimate..sorry for the mistakes..
AWOL
Sorry, no, I don't know any I-can't-believe-it's-not-Java C#
PaulS
Move the break statement outside the if body. The break should not be conditional.
arduino_learners
thanks Paul for the help..i have rectified the problem..
