Loading...
Pages: [1]   Go Down
Author Topic: 6 pins next to the reset button ?  (Read 379 times)
LONDON UK
Offline Offline
Full Member
View Profile
on a UNO ,what are these for ? another icsp connection or what ?
and a four holes with J2 what are they for ?
just curious
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
They are for programming it if you have a hardware programmer.
Logged
Valencia, Spain
Online Online
Edison Member
View Profile
just curious
Arduino Unos are really two Arduinos in one!
If you look closely at the board you'll see a small chip that says "Atmel mega16U2". This chip is programmed to do the USB->serial interface.
http://arduino.cc/en/uploads/Main/ArduinoUno_R3_Front.jpg
I'm guessing the second set of header pins let you reprogram that chip if you want to. Maybe you could use it as a math co-processor if you're not using USB... smiley
« Last Edit: December 11, 2012, 05:21:21 am by fungus » Logged
Offline Offline
Brattain Member
View Profile
WWW
Yes but they are not the ones close to the reset button. On my board those 6 lines are just pads to solder headers onto if you want.
Logged
France
Offline Offline
Sr. Member
View Profile
just curious
It sounds like you have an Uno R3.  The reset button was moved between the R2 and the R3.  The 6-pin header near the USB port is for ICSProgramming the ATmega16u2.  This chip has a bootloader, so it can also be programmed via the USB port.  The 4 holes marked J2 connect to various port pins on the 16u2, which can be useful if you ever want to do more than USB-to-serial conversion with this chip.  Some time ago I wrote some code which allows the 16u2 to work as an ICSP programmer, meaning you could update the Arduino bootloader without needing a second Arduino.  I used one of the J2 pins to switch the software between USB-to-serial mode and ISCP mode.
Logged
LONDON UK
Offline Offline
Full Member
View Profile
thanks to all for a great response i was wondering how you would work on the U2 chip ,that gives me tips for further research on this
Logged
Pages: [1]   Go Up
Print
Jump to:
