Topic: VirtualWire or String causes arduino to hang (Read 12002 times) previous topic - next topic
Makkan
I've written two pieces of codes that uses VirtualWire to transport a 0-1023 integer, VirtualWire_Interger_TX and RX. This code works as far as I can tell without any problems.
But when I tried to combine the RX part with another piece of code my Arduino just started hanging after a few serial messages. From googling around a bit I've seen that there is some sort of problem with the string library at the moment and basically I wonder if I should bother with this problem or just wait to have the issue fixed in an update?
From looking at the Serial Monitor output and comparing to the working example it seems that the hangs are caused when calculating the Sensor1Data/potVal to a color.
Wireless_RGB_LED_Controller (causes Arduino to hang after 5-20 messages)
Code: [Select]
RGB LED controller
4 modes: off, color select, color pulse and random cycle/pulse
By Markus Ulfberg 2009-05-19
Updated to Version 2 - 2010-01-13 (Not publicly released)
Updated to Version 3 - 2011-12-14
Thanks to: Ladyada, Tom Igoe and
everyone at the Arduino forum for excellent
tutorials and everyday help.
TODO:
1. Use millis for debounce instead of delay.
#include <VirtualWire.h>
// LED's
int ledPin = 13;
// Define and set sensors to zero
int Sensor1Data = 0;
int potVal = 0;
// RF Transmission container
char Sensor1CharMsg[4];
// set the ledPins
int ledRed = 10;
int ledGreen = 9;
int ledBlue = 6;
// LED Power variables
byte redPwr = 0;
byte greenPwr = 0;
byte bluePwr = 0;
  // sets the digital pin as output
  pinMode(ledPin, OUTPUT);
  // VirtualWire
  // Initialise the IO and ISR
  // Required for DR3100
  vw_set_ptt_inverted(true);
  // Bits per sec
  vw_setup(2000);
  // Start the receiver PLL running
  vw_rx_start();
  pinMode(ledRed, OUTPUT);
  pinMode(ledGreen, OUTPUT);
  pinMode(ledBlue, OUTPUT);
  // serial for debugging purposes only
  dataRX();
  colorControl();
  // DEBUG
  Serial.print("Sensor 1: ");
  Serial.print(Sensor1Data);
  Serial.print(" redPwr: ");
  Serial.print(redPwr, DEC);
  Serial.print(" greenPwr: ");
  Serial.print(greenPwr, DEC);
  Serial.print(" bluePwr: ");
  Serial.println(bluePwr, DEC);
  // End debug
  // END DEBUG
} // END loop()
void dataRX()
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  // Non-blocking
  if (vw_get_message(buf, &buflen))
    int i;
    // Turn on a light to show received good message
    digitalWrite(13, true);
    // Message with a good checksum received, dump it.
    for (i = 0; i < buflen; i++)
      // Fill Sensor1CharMsg Char array with corresponding
      // chars from buffer.
      Sensor1CharMsg[i] = char(buf[i]);
    // Null terminate the char array
    // This needs to be done otherwise problems will occur
    // when the incoming messages has less digits than the
    // one before.
    Sensor1CharMsg[buflen] = '\0';
    // Convert Sensor1CharMsg Char array to integer
    Sensor1Data = atoi(Sensor1CharMsg);
    // Turn off light to and await next message
    digitalWrite(13, false);
// lightMode 1
void colorControl() {
  // read the potentiometer position
  potVal = Sensor1Data;
  // RED > ORANGE > YELLOW
  if (potVal > 0 && potVal < 170) {
    redPwr = 255;
    bluePwr = 0;
    greenPwr = map(potVal, 0, 170, 0, 255);
  // YELLOW > LIME?? > GREEN
  if (potVal > 170 && potVal < 341) {
    greenPwr = 255;
    bluePwr = 0;
    redPwr = map(potVal, 341, 170, 0, 255);
  // GREEN > TURQOUISE
  if (potVal > 341 && potVal < 511) {
    greenPwr = 255;
    redPwr = 0;
    bluePwr = map(potVal, 341, 511, 0, 255);
  // TURQOUISE > BLUE
  if (potVal > 511 && potVal < 682) {
    bluePwr = 255;
    redPwr = 0;
    greenPwr = map(potVal, 682, 511, 0, 255);
  // BLUE > PURPLE
  if (potVal > 682 && potVal < 852) {
    bluePwr = 255;
    greenPwr = 0;
    redPwr = map(potVal, 682, 852, 0, 255);
  // PURPLE > RED
  if (Sensor1Data > 852 && potVal < 1023) {
    redPwr = 255;
    greenPwr = 0;
    bluePwr = map(potVal, 1023, 852, 0, 255);
  // Display colors
  colorDisplay();
// Displays the colors when called from other functions
void colorDisplay() {
  analogWrite(ledRed, redPwr);
  analogWrite(ledGreen, greenPwr);
  analogWrite(ledBlue, bluePwr);
VirtualWire_Integer_RX (works)
Code: [Select]
Sensor Receiver
By Markus Ulfberg 2012-07-06
Gets a sensor reading 0-1023 in a char array
from RF Transmitter unit via VirtualWire
converts char array back to integer
// LED's
int ledPin = 13;
// Sensors
int Sensor1Data;
    // VirtualWire
    // Bits per sec
    vw_setup(2000);
    vw_rx_start();
} // END void setup
void loop(){
    // Non-blocking
int i;
        // one before.
        // DEBUG
        Serial.println(Sensor1Data);
        // END DEBUG
VirtualWire_Interger_TX (works)
Code: [Select]
Sensor Transmitter
Takes a sensor reading 0-1023
converts it to a char array and sends
to RF receiver unit via VirtualWire
// LED's
const int ledPin = 13;
// Sensors
const int Sensor1Pin = A2;
// const int Sensor2Pin = 3;
int Sensor1Data;
//int Sensor2Data;
// PinModes
// LED
pinMode(ledPin,OUTPUT);
// Sensor(s)
pinMode(Sensor1Pin,INPUT);
// for debugging
// VirtualWire setup
vw_setup(2000); // Bits per sec
  // Read and store Sensor 1 data
  Sensor1Data = analogRead(Sensor1Pin);
  // Convert integer data to Char array directly
  itoa(Sensor1Data,Sensor1CharMsg,10);
  // DEBUG
  Serial.print("Sensor1 Integer: ");
  Serial.print(" Sensor1 CharMsg: ");
  Serial.print(Sensor1CharMsg);
  Serial.println(" ");
  // END DEBUG
digitalWrite(13, true); // Turn on a light to show transmitting
vw_send((uint8_t *)Sensor1CharMsg, strlen(Sensor1CharMsg));
vw_wait_tx(); // Wait until the whole message is gone
digitalWrite(13, false); // Turn off a light after transmission
delay(200);
} // END void loop...
PaulS
Quote
No. The string library is fine. The String library is a different story. It's use of dynamic memory allocation and deallocation is what causes the problem.
Quote
The Arduino team is in no hurry to address the problem. It is outside their control, and requires a newer version of the whole compile/link/upload tool chain.
You'll be waiting a while.
Anyway, I don't see you using the String class, so you have some other problem that fixing the String class/tool chain is not going to correct.
PaulS
Code: [Select]
How are you going to fit '1', '0', '2', '3' and the trailing NULL in a 4 element array?
Your array on the receiver is too small, too.
Makkan
Code: [Select]
Isn't the above a 5 element array (0 1 2 3 4), or have I got it wrong?
Ok thank you for helping me with that. Any thoughts on what might actually cause the hangs?
PaulS
Quote
No, it is not. The value in the brackets is the number of elements, not the upper index.
Quote
What I like to do is fix the bugs as a become aware of them, and see what effect that has on the program. You have a known bug. Fix it, and let us know what impact that has on your problem.
Makkan
Thanks for the tip!
So now I've changed both the transitter and receiver code as below and uploaded to both boards. However the change in behaviour seems minimal. If anything I do get a few more lines to run by in Serial Monitor before things hang again.
Code: [Select]
char Sensor1CharMsg[5];
All parts of the code work if I run them separately so I can't really tell where the problem lies. Is there something I can do to get more info on what causes the crash?
ZacharyBruno
What about the Serial.print lines? If you remove all those, does the program work? I had a problem recently when I started using Serial.print for debugging and it ended up restarting the arduino over and over again while it was trying to run the code. I think it was something to do with a memory issue.
Zachary
dc42
Code: [Select]
void dataRX()
  // Non-blocking
Classic buffer overflow bug. Even if you have increased Sensor1CharMsg to 5 elements, the version of VirtualWire.h I just looked at (1.9) defines VW_MAX_MESSAGE_LEN as 30. So the above code will write beyond the end of the buffer, if you receive a message more than 4 or 5 bytes long. Never trust input to be in the expected form, even if it is (in theory) under your control.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
nickgammon
Where did you find 1.9? I found 1.5 on this page:
http://www.pjrc.com/teensy/td_libs_VirtualWire.html
On my hard disk the version that I have claims to be 1.6 (!) and in that, the vw_get_message function appears to only return the requested number of bytes, at most.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
dc42
http://www.open.com.au/mikem/arduino/
... and in that, the vw_get_message function appears to only return the requested number of bytes, at most.
Yes, but he's asking for VW_MAX_MESSAGE_LEN bytes, instead of 4 (or 5).
nickgammon
Code: [Select]
Oh yes I see. That loop is the issue. Maybe a memcpy would be simpler. And choose the length as the destination length, not the source length.
dc42
...or convert the data directly from 'buf' instead of copying it to Sensor1CharMsg.
Makkan
Thanks for all the suggestions but I'm afraid I'm still going nowhere here.
Nope that didn't work.
This I have to research more if I should go ahead and do. So I'll put this on hold if the next one is simpler.
I tried this but that didn't work. Allthough I doubt I did it right. Am I looking for a char to integer converter or something else?
Code: [Select]
Sensor1Data = atoi(buf);
Error Message
Code: [Select]
conversion from 'uint8_t*' to 'const char*'
rgb_mixer_RF_controlled_pulse_makkan_v4_ino:115: error: initializing argument 1 of 'int atoi(const char*)'
nickgammon
Please post your amended code.
Makkan
Code: [Select]
  RGB LED controller
  TODO:
// LED's
int ledPin = 13;
// Sensors
int Sensor1Data;
int potVal;
// set the ledPins
int ledRed = 10;
int ledGreen = 9;
int ledBlue = 6;
byte redPwr = 0;
byte greenPwr = 0;
byte bluePwr = 0;
    // VirtualWire
    // Bits per sec
    vw_setup(2000);
    vw_rx_start();
  dataRX();
  colorControl();
  // DEBUG
  Serial.print(" potVal: ");
  Serial.print(potVal);
  // End debug
  // END DEBUG
} // END loop()
void dataRX()
    // Non-blocking
int i;
        /* Commented out for buffer to integer directly
        // one before.
        // Convert buffer directly to Integer String
  // delay(500);
// lightMode 1
     redPwr = 255;
     bluePwr = 0;
     greenPwr = 255;
     bluePwr = 0;
      greenPwr = 255;
      redPwr = 0;
   // TURQOUISE > BLUE
     bluePwr = 255;
     redPwr = 0;
   // BLUE > PURPLE
     bluePwr = 255;
     greenPwr = 0;
   // PURPLE > RED
     redPwr = 255;
     greenPwr = 0;
  // Display colors
  colorDisplay();
