Gothenburg, Sweden
Excellent!
« on: December 11, 2012, 05:57:07 am » |
I've written two pieces of codes that uses VirtualWire to transport a 0-1023 integer, VirtualWire_Interger_TX and RX. This code works as far as I can tell without any problems. But when I tried to combine the RX part with another piece of code my Arduino just started hanging after a few serial messages. From googling around a bit I've seen that there is some sort of problem with the string library at the moment and basically I wonder if I should bother with this problem or just wait to have the issue fixed in an update? From looking at the Serial Monitor output and comparing to the working example it seems that the hangs are caused when calculating the Sensor1Data/potVal to a color. Wireless_RGB_LED_Controller (causes Arduino to hang after 5-20 messages) /* RGB LED controller 4 modes: off, color select, color pulse and random cycle/pulse By Markus Ulfberg 2009-05-19 Updated to Version 2 - 2010-01-13 (Not publicly released) Updated to Version 3 - 2011-12-14 Thanks to: Ladyada, Tom Igoe and everyone at the Arduino forum for excellent tutorials and everyday help. TODO: 1. Use millis for debounce instead of delay. */
#include <VirtualWire.h>
// LED's int ledPin = 13;
// Define and set sensors to zero int Sensor1Data = 0; int potVal = 0;
// RF Transmission container char Sensor1CharMsg[4];
// set the ledPins int ledRed = 10; int ledGreen = 9; int ledBlue = 6;
// LED Power variables byte redPwr = 0; byte greenPwr = 0; byte bluePwr = 0;
// sets the digital pin as output pinMode(ledPin, OUTPUT);
// VirtualWire // Initialise the IO and ISR // Required for DR3100 vw_set_ptt_inverted(true); // Bits per sec vw_setup(2000);
// Start the receiver PLL running vw_rx_start();
pinMode(ledRed, OUTPUT); pinMode(ledGreen, OUTPUT); pinMode(ledBlue, OUTPUT);
// serial for debugging purposes only Serial.begin(9600); }
void loop() { dataRX(); colorControl();
// DEBUG Serial.print("Sensor 1: "); Serial.print(Sensor1Data);
Serial.print(" redPwr: "); Serial.print(redPwr, DEC); Serial.print(" greenPwr: "); Serial.print(greenPwr, DEC); Serial.print(" bluePwr: "); Serial.println(bluePwr, DEC);
// End debug // END DEBUG
} // END loop()
void dataRX() { uint8_t buf[VW_MAX_MESSAGE_LEN]; uint8_t buflen = VW_MAX_MESSAGE_LEN;
// Non-blocking if (vw_get_message(buf, &buflen)) { int i; // Turn on a light to show received good message digitalWrite(13, true);
// Message with a good checksum received, dump it. for (i = 0; i < buflen; i++) { // Fill Sensor1CharMsg Char array with corresponding // chars from buffer. Sensor1CharMsg[i] = char(buf[i]); }
// Null terminate the char array // This needs to be done otherwise problems will occur // when the incoming messages has less digits than the // one before. Sensor1CharMsg[buflen] = '\0';
// Convert Sensor1CharMsg Char array to integer Sensor1Data = atoi(Sensor1CharMsg); // Turn off light to and await next message digitalWrite(13, false); } delay(500); }
// lightMode 1 void colorControl() {
// read the potentiometer position potVal = Sensor1Data;
// RED > ORANGE > YELLOW if (potVal > 0 && potVal < 170) { redPwr = 255; bluePwr = 0; greenPwr = map(potVal, 0, 170, 0, 255); }
// YELLOW > LIME?? > GREEN if (potVal > 170 && potVal < 341) { greenPwr = 255; bluePwr = 0; redPwr = map(potVal, 341, 170, 0, 255); }
// GREEN > TURQOUISE if (potVal > 341 && potVal < 511) { greenPwr = 255; redPwr = 0; bluePwr = map(potVal, 341, 511, 0, 255); }
// TURQOUISE > BLUE if (potVal > 511 && potVal < 682) { bluePwr = 255; redPwr = 0; greenPwr = map(potVal, 682, 511, 0, 255); }
// BLUE > PURPLE if (potVal > 682 && potVal < 852) { bluePwr = 255; greenPwr = 0; redPwr = map(potVal, 682, 852, 0, 255); }
// PURPLE > RED if (Sensor1Data > 852 && potVal < 1023) { redPwr = 255; greenPwr = 0; bluePwr = map(potVal, 1023, 852, 0, 255); }
// Display colors colorDisplay(); }
// Displays the colors when called from other functions void colorDisplay() { analogWrite(ledRed, redPwr); analogWrite(ledGreen, greenPwr); analogWrite(ledBlue, bluePwr); }
VirtualWire_Integer_RX (works) /*
Sensor Receiver By Markus Ulfberg 2012-07-06
Gets a sensor reading 0-1023 in a char array from RF Transmitter unit via VirtualWire converts char array back to integer
// Sensors int Sensor1Data;
void setup() { Serial.begin(9600); // sets the digital pin as output pinMode(ledPin, OUTPUT); // VirtualWire // Initialise the IO and ISR // Required for DR3100 vw_set_ptt_inverted(true); // Bits per sec vw_setup(2000); // Start the receiver PLL running vw_rx_start();
} // END void setup
void loop(){ uint8_t buf[VW_MAX_MESSAGE_LEN]; uint8_t buflen = VW_MAX_MESSAGE_LEN; // Non-blocking if (vw_get_message(buf, &buflen)) { int i; // Turn on a light to show received good message digitalWrite(13, true); // Message with a good checksum received, dump it. for (i = 0; i < buflen; i++) { // Fill Sensor1CharMsg Char array with corresponding // chars from buffer. Sensor1CharMsg[i] = char(buf[i]); } // Null terminate the char array // This needs to be done otherwise problems will occur // when the incoming messages has less digits than the // one before. Sensor1CharMsg[buflen] = '\0'; // Convert Sensor1CharMsg Char array to integer Sensor1Data = atoi(Sensor1CharMsg); // DEBUG Serial.print("Sensor 1: "); Serial.println(Sensor1Data); // END DEBUG // Turn off light to and await next message digitalWrite(13, false); } }
VirtualWire_Interger_TX (works) /*
Sensor Transmitter By Markus Ulfberg 2012-07-06
Takes a sensor reading 0-1023 converts it to a char array and sends to RF receiver unit via VirtualWire
// LED's const int ledPin = 13;
// Sensors const int Sensor1Pin = A2; // const int Sensor2Pin = 3;
int Sensor1Data; //int Sensor2Data; char Sensor1CharMsg[4];
// PinModes // LED pinMode(ledPin,OUTPUT); // Sensor(s) pinMode(Sensor1Pin,INPUT); // for debugging Serial.begin(9600); // VirtualWire setup vw_setup(2000); // Bits per sec
void loop() { // Read and store Sensor 1 data Sensor1Data = analogRead(Sensor1Pin); // Convert integer data to Char array directly itoa(Sensor1Data,Sensor1CharMsg,10); /* // DEBUG Serial.print("Sensor1 Integer: "); Serial.print(Sensor1Data); Serial.print(" Sensor1 CharMsg: "); Serial.print(Sensor1CharMsg); Serial.println(" "); delay(1000);
// END DEBUG */ digitalWrite(13, true); // Turn on a light to show transmitting vw_send((uint8_t *)Sensor1CharMsg, strlen(Sensor1CharMsg)); vw_wait_tx(); // Wait until the whole message is gone digitalWrite(13, false); // Turn off a light after transmission delay(200); } // END void loop...
Seattle, WA USA
Seattle, WA USA
« Reply #1 on: December 11, 2012, 06:22:30 am » |
From googling around a bit I've seen that there is some sort of problem with the string library at the moment No. The string library is fine. The String library is a different story. It's use of dynamic memory allocation and deallocation is what causes the problem. I wonder if I should bother with this problem or just wait to have the issue fixed in an update? The Arduino team is in no hurry to address the problem. It is outside their control, and requires a newer version of the whole compile/link/upload tool chain. You'll be waiting a while. Anyway, I don't see you using the String class, so you have some other problem that fixing the String class/tool chain is not going to correct.
Seattle, WA USA
Seattle, WA USA
« Reply #2 on: December 11, 2012, 06:26:53 am » |
// Read and store Sensor 1 data Sensor1Data = analogRead(Sensor1Pin); // Convert integer data to Char array directly itoa(Sensor1Data,Sensor1CharMsg,10); How are you going to fit '1', '0', '2', '3' and the trailing NULL in a 4 element array? Your array on the receiver is too small, too.
Gothenburg, Sweden
Excellent!
« Reply #3 on: December 11, 2012, 06:51:20 am » |
Isn't the above a 5 element array (0 1 2 3 4), or have I got it wrong? Anyway, I don't see you using the String class, so you have some other problem that fixing the String class/tool chain is not going to correct.
Ok thank you for helping me with that. Any thoughts on what might actually cause the hangs?
Seattle, WA USA
Seattle, WA USA
« Reply #4 on: December 11, 2012, 06:59:30 am » |
Isn't the above a 5 element array (0 1 2 3 4), or have I got it wrong? No, it is not. The value in the brackets is the number of elements, not the upper index. Any thoughts on what might actually cause the hangs? What I like to do is fix the bugs as a become aware of them, and see what effect that has on the program. You have a known bug. Fix it, and let us know what impact that has on your problem.
Gothenburg, Sweden
Excellent!
« Reply #5 on: December 11, 2012, 02:18:09 pm » |
Thanks for the tip! So now I've changed both the transitter and receiver code as below and uploaded to both boards. However the change in behaviour seems minimal. If anything I do get a few more lines to run by in Serial Monitor before things hang again. char Sensor1CharMsg[5]; All parts of the code work if I run them separately so I can't really tell where the problem lies. Is there something I can do to get more info on what causes the crash?
Scottsdale
« Reply #6 on: December 11, 2012, 02:29:40 pm » |
What about the Serial.print lines? If you remove all those, does the program work? I had a problem recently when I started using Serial.print for debugging and it ended up restarting the arduino over and over again while it was trying to run the code. I think it was something to do with a memory issue.
Zachary
United Kingdom
« Reply #7 on: December 11, 2012, 03:06:37 pm » |
char Sensor1CharMsg[4]; ...
void dataRX() { ... uint8_t buflen = VW_MAX_MESSAGE_LEN;
// Non-blocking if (vw_get_message(buf, &buflen)) { ... // Message with a good checksum received, dump it. for (i = 0; i < buflen; i++) { // Fill Sensor1CharMsg Char array with corresponding // chars from buffer. Sensor1CharMsg[i] = char(buf[i]); }
Classic buffer overflow bug. Even if you have increased Sensor1CharMsg to 5 elements, the version of VirtualWire.h I just looked at (1.9) defines VW_MAX_MESSAGE_LEN as 30. So the above code will write beyond the end of the buffer, if you receive a message more than 4 or 5 bytes long. Never trust input to be in the expected form, even if it is (in theory) under your control.
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #8 on: December 11, 2012, 04:28:04 pm » |
Where did you find 1.9? I found 1.5 on this page: http://www.pjrc.com/teensy/td_libs_VirtualWire.htmlOn my hard disk the version that I have claims to be 1.6 (!) and in that, the vw_get_message function appears to only return the requested number of bytes, at most.
United Kingdom
« Reply #9 on: December 11, 2012, 04:35:03 pm » |
http://www.open.com.au/mikem/arduino/... and in that, the vw_get_message function appears to only return the requested number of bytes, at most.
Yes, but he's asking for VW_MAX_MESSAGE_LEN bytes, instead of 4 (or 5).
Shannon Member
Lua rocks!
« Reply #10 on: December 11, 2012, 04:50:35 pm » |
for (i = 0; i < buflen; i++) { Sensor1CharMsg[i] = char(buf[i]); }
Oh yes I see. That loop is the issue. Maybe a memcpy would be simpler. And choose the length as the destination length, not the source length.
United Kingdom
« Reply #11 on: December 11, 2012, 04:53:37 pm » |
...or convert the data directly from 'buf' instead of copying it to Sensor1CharMsg.
Gothenburg, Sweden
Excellent!
« Reply #12 on: December 12, 2012, 01:05:47 am » |
Thanks for all the suggestions but I'm afraid I'm still going nowhere here. What about the Serial.print lines? If you remove all those, does the program work?
Nope that didn't work. Oh yes I see. That loop is the issue. Maybe a memcpy would be simpler. And choose the length as the destination length, not the source length.
This I have to research more if I should go ahead and do. So I'll put this on hold if the next one is simpler. ...or convert the data directly from 'buf' instead of copying it to Sensor1CharMsg.
I tried this but that didn't work. Allthough I doubt I did it right. Am I looking for a char to integer converter or something else? Sensor1Data = atoi(buf); Error Message conversion from 'uint8_t*' to 'const char*' rgb_mixer_RF_controlled_pulse_makkan_v4_ino:115: error: initializing argument 1 of 'int atoi(const char*)'
Shannon Member
Lua rocks!
« Reply #13 on: December 12, 2012, 01:12:47 am » |
Please post your amended code.
Gothenburg, Sweden
Excellent!
« Reply #14 on: December 12, 2012, 03:03:31 am » |
// Sensors int Sensor1Data; int potVal;
// RF Transmission container char Sensor1CharMsg[5];
void setup() { // sets the digital pin as output pinMode(ledPin, OUTPUT); // VirtualWire // Initialise the IO and ISR // Required for DR3100 vw_set_ptt_inverted(true); // Bits per sec vw_setup(2000); // Start the receiver PLL running vw_rx_start();
pinMode(ledRed, OUTPUT); pinMode(ledGreen, OUTPUT); pinMode(ledBlue, OUTPUT); // serial for debugging purposes only Serial.begin(9600); }
void loop() { dataRX(); colorControl(); // DEBUG Serial.print("Sensor 1: "); Serial.print(Sensor1Data); Serial.print(" potVal: "); Serial.print(potVal); Serial.print(" redPwr: "); Serial.print(redPwr, DEC); Serial.print(" greenPwr: "); Serial.print(greenPwr, DEC); Serial.print(" bluePwr: "); Serial.println(bluePwr, DEC); // End debug // END DEBUG
} // END loop()
void dataRX() { uint8_t buf[VW_MAX_MESSAGE_LEN]; uint8_t buflen = VW_MAX_MESSAGE_LEN; // Non-blocking if (vw_get_message(buf, &buflen)) { int i; // Turn on a light to show received good message digitalWrite(13, true); /* Commented out for buffer to integer directly // Message with a good checksum received, dump it. for (i = 0; i < buflen; i++) { // Fill Sensor1CharMsg Char array with corresponding // chars from buffer. Sensor1CharMsg[i] = char(buf[i]); } // Null terminate the char array // This needs to be done otherwise problems will occur // when the incoming messages has less digits than the // one before. Sensor1CharMsg[buflen] = '\0'; // Convert Sensor1CharMsg Char array to integer Sensor1Data = atoi(Sensor1CharMsg); */ // Convert buffer directly to Integer String Sensor1Data = atoi(buf); // Turn off light to and await next message digitalWrite(13, false); } // delay(500); }
// lightMode 1 void colorControl() { // read the potentiometer position potVal = Sensor1Data; // RED > ORANGE > YELLOW if (potVal > 0 && potVal < 170) { redPwr = 255; bluePwr = 0; greenPwr = map(potVal, 0, 170, 0, 255); } // YELLOW > LIME?? > GREEN if (potVal > 170 && potVal < 341) { greenPwr = 255; bluePwr = 0; redPwr = map(potVal, 341, 170, 0, 255); }
// GREEN > TURQOUISE if (potVal > 341 && potVal < 511) { greenPwr = 255; redPwr = 0; bluePwr = map(potVal, 341, 511, 0, 255); } // TURQOUISE > BLUE if (potVal > 511 && potVal < 682) { bluePwr = 255; redPwr = 0; greenPwr = map(potVal, 682, 511, 0, 255); } // BLUE > PURPLE if (potVal > 682 && potVal < 852) { bluePwr = 255; greenPwr = 0; redPwr = map(potVal, 682, 852, 0, 255); } // PURPLE > RED if (Sensor1Data > 852 && potVal < 1023) { redPwr = 255; greenPwr = 0; bluePwr = map(potVal, 1023, 852, 0, 255); } // Display colors colorDisplay(); }
