Topic: Intercettare change di tutti i PORT PinChangeInt (Read 2294 times) previous topic - next topic
pablos71
#15
Dec 14, 2012, 12:21 pm Last Edit: Dec 14, 2012, 02:52 pm by pablos Reason: 1
Ci sono vicino ho applicato il pezzo di Lesto per trovare i bit cambiati e funziona, ma ottengo un numero in uscita sbagliato
Code: [Select]
//--------------------timer--------------------------------------------------------
unsigned long previousMillis_e = 0;
unsigned long interval_e = 50;
byte Port[] = {0,0,0,0,0,0,0,0,0}; //A,B,C,D,E,G,H,J,L  ... valori hold
byte cont; // contatore per pulsante port 32(test)
 Serial.begin(9600);//debug
 pinMode(32, INPUT);
 DDRL = 255;  // set a OUTPUT i pin 42-43-44-45-46-47-48-49
 //PORTL = 0;  // metto a LOW i pin 42-43-44-45-46-47-48-49
 unsigned long currentMillis_e = millis();
 if(currentMillis_e - previousMillis_e > interval_e)
       previousMillis_e = currentMillis_e;
   if(Port[2] !=  PINC){
   byte C[] = {30,31,32,33,34,35,36,37};
   BitChange(Port[2], PINC, C);
   Port[2] =  PINC;
   Serial.println("CHANGE PORT_C 30-31-32-33-34-35-36-37 >> val byte = " + (String)PINC );//debug
   /*if(Port[3] != PIND){
   Serial.println("CHANGE PORT_D 18-19-20-21-38 >> val byte = " + (String)PIND);//debug
   if(Port[5] !=  PING){
   Port[5] =  PING;
   Serial.println("CHANGE PORT_G 39-40-41-4  >> val byte = " + (String)PING);//debug
   if(Port[8] !=  PINL){
   byte L[] = {42,43,44,45,46,47,48,49};
   BitChange(Port[8], PINL, L);
   Port[8] =  PINL;
   Serial.println("CHANGE PORT_L 42-43-44-45-46-47-48-49 >> val byte = " + (String)PINL );//debug
//----------------------test con pulsante-----------------------
       if (digitalRead(32)) cont++; else cont=0;
       if (digitalRead(42) == 0 && cont == 1){
         PORTL |= (1<<7); cont++;
       if (digitalRead(42) == 1 && cont == 1){
         PORTL &= ~(1<<7); cont++;
void BitChange(byte Hold_Val_Port, byte New_Val_Port, byte Pin[])
  byte Cambio = New_Val_Port ^ Hold_Val_Port;
      for ( byte i=0; i < 8; i++)
        if ( Cambio & (1<<(8-i)))  //controllo lo stato del bit in posizione 8-i
        Serial.print("Il pin " + (String)Pin[i] + " e' cambiato! ...  ");//debug   <<<<<<<<<<<< ERRORE!!!
ricapitolando ho:
Un pulsante sul pin 32 quindi PORTC
Un led sul pin 42 quindi PORTL
premo il pulsante e lo rilascio immediatamente
se metto
Code: [Select]
ottengo questa uscita
Il pin 33 e' cambiato! ...  CHANGE PORT_C 30-31-32-33-34-35-36-37 >> val byte = 32   <<< ERRORE
Il pin 43 e' cambiato! ...  CHANGE PORT_L 42-43-44-45-46-47-48-49 >> val byte = 128  <<< ERRORE
Il pin 33 e' cambiato! ...  CHANGE PORT_C 30-31-32-33-34-35-36-37 >> val byte = 0     <<< ERRORE
se metto ivece -1 pensavo di correggere entrambi i valori
Code: [Select]
Serial.print("Il pin " + (String)Pin[i-1] + " e' cambiato! ...  ");
ottengo invece questa uscita
Il pin 31 e' cambiato! ...  CHANGE PORT_C 30-31-32-33-34-35-36-37 >> val byte = 32   <<< ERRORE
Il pin 42 e' cambiato! ...  CHANGE PORT_L 42-43-44-45-46-47-48-49 >> val byte = 128 <<< GIUSTO
Il pin 31 e' cambiato! ...  CHANGE PORT_C 30-31-32-33-34-35-36-37 >> val byte = 0    <<< ERRORE
Perchè??? dannazione  :smiley-sweat:
Tabella dal file pins_arduino.h - Pin definition functions for Arduino
PL   , // PL 7 ** 42 ** D42
PL   , // PL 6 ** 43 ** D43
PL   , // PL 5 ** 44 ** D44
PL   , // PL 4 ** 45 ** D45
PL   , // PL 3 ** 46 ** D46
PL   , // PL 2 ** 47 ** D47
PL   , // PL 1 ** 48 ** D48
PL   , // PL 0 ** 49 ** D49
PC   , // PC 7 ** 30 ** D30
PC   , // PC 6 ** 31 ** D31
PC   , // PC 5 ** 32 ** D32
PC   , // PC 4 ** 33 ** D33
PC   , // PC 3 ** 34 ** D34
PC   , // PC 2 ** 35 ** D35
PC   , // PC 1 ** 36 ** D36
PC   , // PC 0 ** 37 ** D37
L'esperienza è il tipo di insegnante più difficile ....
Prima ti fa l'esame e poi ti spiega la lezione.
pablos71
#16
Dec 14, 2012, 02:24 pm Last Edit: Dec 14, 2012, 02:52 pm by pablos Reason: 1
Risolto, grazie per le idee e l'aiuto
Code: [Select]
        if ( Cambio & 1<<i)  //controllo lo stato del bit in posizione 8-i
        Serial.print("Il pin " + (String)Pin[i] + " e' cambiato! ...  BIT n = " + (String)i + " ");//debug
diventa
byte C[] = {37,36,35,34,33,32,31,30};
diventa
byte L[] = {49,48,47,46,45,44,43,42};
risposta di debug prima pressione e rilascio
Il pin 32 e' cambiato! ...  BIT n = 5 CHANGE PORT_C 37,36,35,34,33,32,31,30 >> val byte = 32
Il pin 42 e' cambiato! ...  BIT n = 7 CHANGE PORT_L 49,48,47,46,45,44,43,42 >> val byte = 128
Il pin 32 e' cambiato! ...  BIT n = 5 CHANGE PORT_C 37,36,35,34,33,32,31,30 >> val byte = 0
risposta di debug seconda pressione e rilascio
Il pin 42 e' cambiato! ...  BIT n = 7 CHANGE PORT_L 49,48,47,46,45,44,43,42 >> val byte = 0
leo72
Quindi serviva invertire l'ordine dei pin negli array.
pablos71
#18
Dec 14, 2012, 02:31 pm Last Edit: Dec 14, 2012, 02:34 pm by pablos Reason: 1
si cambiare l'ordine e modificare il confronto, stampando il debug del for mi si è evidenziato l'errore
da
a
if ( Cambio & 1<< i)
ho ridotto inoltre il debounce da 100ms a 50ms
lesto
ahhah lol e pensare che mi sono sbattuto apposta a fare (8-i) per invertire le uscite in base alla maschera :)
Guida per principianti http://playground.arduino.cc/Italiano/newbie
Unoffical Telegram group https://t.me/genuino
pablos71
#20
Dec 14, 2012, 08:52 pm Last Edit: Dec 14, 2012, 08:54 pm by pablos Reason: 1
Guarda lascia perdere, nel sistemare lo sketch mi sono accorto che l'errore su PORTC era casusato da
byte C[] = {30,31,31,33,34,35,36,37};
Non ho ancora provato, ma con Pin[i-1] e if ( Cambio & (1<<(8-i))) +  l'array corretto sono quasi certo che funzionava lo stesso
Grazie il tuo intervento e' stato utilissimo
ciao
pablos71
Leo me la fai una libreria interceptor su tutti i gruppi PORT?
Mgari la chiami LeoPORTAvia ... LeoPORC ahahahah chiamala come ti pare ... ti va?
Ti prendi anche i diritti GPL GAS ENI  a me non interessa :)
Io non son buono, sei tu l'esperto mastro libraio  ]:D
ciao
leo72
ciao
Che libreria ti devo fare?  :smiley-sweat:
pablos71
Siccome non è possibile avere tutti i pin della mega (70pin I/O) collegati internamente a degli interrupt, sarebbe possibile creare nel loop un richiamo in background per leggere le variazioni dei PORT con relativa uscita dei pin cambiati?
Chiaramente prendendo spunto dallo sketch completo che ho fatto.
Penso che faresti felice molti utenti che hanno progetti domo e altri progetti dove deve essere controllata l'attività I/O dell'MCU.
A parte scherzi io te l'ho buttata li, se hai tempo, voglia e ritieni sia il caso secondo me può essere utile per un certo tipo di automazione.
ciao
leo72
ciao
Non ho capito qual'è la differenza fra il codice che hai usato tu e la libreria PinChangeInterrupt che è già fatta (e che mi pareva di aver linkato in precedenza).
pablos71
Perchè solo 20 pin possono supportare gli interrupt.
Io lo faccio esternamente su 54 pin.
Tra quelli supportati ci sono i pin 10-11-12-13 50-51-52-53 usati dallo shield Ethernet e SD.
Ma non mi serve la lib scherzavo, ma la  PinChangeInt library for the Arduino non fa al caso mio
leo72
Ah, ora capisco.
Quote
Pablos, lo puoi fare anche tu. Prendi il leOS2, e metti in un task il codice per controllare il cambio di stato dei pin usando l'algoritmo che hai elaborato. Basta quindi che ad ogni chiamata del task tu faccia la fotografia di tutti i pin e se quello per cui è stato attivato un interrupt SW ha cambiato di stato chiami una routine.
