Topic: temperature monitoring alarm system (Read 2293 times) previous topic - next topic
cliff80
Hi,   I'm new around here and haven't ever used an arduino. Im in the process of building a temperature  monitoring alarm system with up to 50 temperature sensors. i was thinking of using DS18B20 sensors and a Arduino. From the arduino i want to send the data via mod bus to a PLC which is part of my local network. can this be done with an Ethernet connection? And what kind of arduino would work best for this application?   Thanks for any help.
Krodal
Search in this page for DS18B20 : http://playground.arduino.cc/Main/InterfacingWithHardware
Perhaps you find some new ideas.
I don't know the ModBus. Does it use RS485 ?
http://playground.arduino.cc/Code/ModbusMaster
There are expansion shields with RS485.
If you could make them work with ModBus, you have a reliable connection.
If you have ethernet cables, you could use an Ethernet Shield, or an Arduino Ethernet. But using ethernet is slow, and it doesn't handle slow or bad connections very well.
stretched59
In the playground is the ModbusMaster Library.
Google search
http://dereenigne.org/arduino/arduino-modbus-rtu-adc
These are RS-485 options. You can get RS-485 to Ethernet converters. Where I work we use a RS-485/RS-232 converter then connect to the network with a Lantronix converter. I see they have a new product:
http://www.lantronix.com/device-networking/external-device-servers/xdirect.html for $110
