Loading...
Pages: [1]   Go Down
Author Topic: avrdude: stk500_getsync(): not in sync: resp=0x30  (Read 1328 times)
Offline Offline
Newbie
View Profile
   Hi, I'm Marco from Italy!
   It's my first Arduino Uno! In mu PC at home I can't work and I have this message "avrdude: stk500_getsync(): not in sync: resp=0x30" and I have no flashing in Tx and Rx leds. If I disconnect USB cable I have the same thing! It's seems like Arduino doesn't talk to the PC.
   I made the SAME installation with SAME drivers to my PC at work and...everythings works in the good way!
   I have read every forum about this problem and I try somethings but no result to work at home!
   Someone can help me?
   Thanks a lot!
    Marco.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
most often this message indicates that you should select another board type in the GUI under tools menu. Have you tried that?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
Thanks for answer!
I checked...I have the same board type of the PC at office but in the PC at home it doesn't work!!
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
check this - http://www.instructables.com/id/A-solution-to-avrdude-stk500getsync-not-in-syn/ -
Logged
Rob Tillaart
Oz
Offline Offline
God Member
View Profile
Had that link worked, it would be terrific.
Alas it doesn't work for me.
My scenario is that I bought one, then another one.
They both work.
Then I bought another and it had this problem.
I even bought a "Genuine" Uno.
It too doesn't work.  SAME PROBLEM.
Tried other board types - as suggested in other posts from people with similar problems.
Weirdly enough I can still talk to my first Arduino.
So I am really at a loss to what is going on.
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
So you have 3 Arduino's and 2 PC's
All the Arduino's work with PC1 but only one does work with PC2
Correct?
- try another cable
- try another USB port of your PC if possible
- reinstall the drivers (remove COMports from device manager)
Logged
Rob Tillaart
Oz
Offline Offline
God Member
View Profile
I have 4 Arduinos, and 2 pcs.
One of the Arduino may be faulty.
One is working and can be programmed.  As this is my alarm clock, it is now only done from my laptop.
The other two just won't flash from either.
One of those has been tried on a third pc and also fails.
The "faulty" one works in that I can upload the BLINK sketch and it works.
Other sketches upload but as some of the I/O lines are suspect, may not work.
Suffice to say the LED stops blinking when the new sketch is uploaded.  Then starts blinking when the BLINK sketch is uploaded.
Also there are no errors.
The two new cards give this "not in sync" error.
One is a freetronics one and is a genuine Arduino uno.
Logged
Coppell, Texas
Offline Offline
Newbie
View Profile
Add me to the ever growing list of "not in sync" errors.  I'm using an Arduino UNO R3 / ZUMO Shield combo.
Had been working for a couple of hours then all of a sudden I started getting the subject error.
It started as an intermittent failure and is now solid.  I've tried all the tips suggested in this post as
well as others in this forum.  None work.  I've even update Arduino 1.0.1 to 1.0.3 and updated the USB drivers,
all to no avail....   ?????
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
There seems to be so many 1000s of people having the same problem, I would think
the Arduino development team might look into this, and either find a way for better
software driver installation, or else come up with a more bulletproof uploader program.
Maybe one that has some option settings.
Also, I think the problems have become worse with the newer R3 boards, ie, new
drivers, larger upload packets, and faster transfer baudrates.
One thing to try is see if the driver for the board is installed properly .... go to
Control Panel > System > Hardware > Device Manager, and see if the board shows
up in the Ports section when you plug and unplug the board.
Logged
Murphy's Corollary: the "real" problem is usually what they don't tell you about, which leads to endless second-guessing. m
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
Quote
It's not "the same problem."  It's a generic error message that gets reported for LOTS OF DIFFERENT PROBLEMS.
I'm pretty sure that the R3 boards have the same bootloader and speeds as the previous Unos.
To the person with the Zumo shield - does it start working if you disconnect the shield?
As the nominal "owner" of Optiboot, I'd be willing to expend some effort to debug some of these mysterious failures (especially the ones that went intermittent to solid broken), but doing so over the net seems hopeless.  I'd need to have your physical board in my possession, and since I'm not a "vendor" I can't offer a replacement board or anything while I work on it.  I'd be willing to mail it back if I get it working, though.
So if you're willing to mail me your "dead" arduino for debugging, or if you're local to the SF Bay Area and have one of these consistently failing boards, PM me for contact info...
Logged
Offline Offline
Edison Member
View Profile
Quote
Yeah, I know, still there are so many problems with uploading, especially with the newer
boards, that it seems someone might do some rethinking along the lines I mentioned.
ALSO - it would be nice if the bootloader and uploader-dude s.w. were more conducive to
wireless programming, using XBees for instance. This would probably entail adding:
1. ability to choose lower upload baudrate.
2. ability to use shorter packets.
3. adding longer turnaround ack wait times.
I would do this myself, as I use XBees all the time, but my knowledge of AVR assembler
and the tool chain s.w. is extremely limited.
Logged
Pages: [1]   Go Up
Print
Jump to:
