Topic: analog input issuses (Read 7131 times) previous topic - next topic
warrenf
hi guy and girls. im new to the arduino.
i have theuno rev 3
im having an issue with using the anolg input for my project.
i have 3 push buttons and two switches
they each run threw a 10k pull down resister.
but only two push button read on the arduino.
and neather of the switches.
what could the issue be?
HazardsMind
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
AWOL
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
warrenf
ok here it is
in the drawing pin 11 becomes A4
                         10 becomes A3
                         5               A1
                         4               A2
                         2               A0
other thing you should probly know is that i made a boo boo and stuck 9v threw the 5 inputs this is y im trying to use the analog input.
silly me.
and the transistor i changed to a relay
and also tried to add in a wake up funtion for the camera with a second relay.
so i may well have messed this whole thing up.
warrenf
the code dont fit
so here is the first half
Code: [Select]
//pins on the arduino.
const int shutterPin = 3;  //output to camera
const int startLEDPin = 13;  //visual display of timelapse running
const int upPin = A1;  //input for up button
const int downPin = A2;  //input for down button
const int minutePin = A3;  //visual display of minutes yes/no (seconds in active if not HIGH)
const int HDRPin = A4; //visual display of HDR yes/no
const int startPin = A0; //input for begin button
const int wakepin = 12;
//for displaying digits on the 7-segment LEDs.
const int clockPin = 6;
const int serialOnesPin = 7;
const int serialTensPin = 8;
const int serialHundsPin = 9;
const int a=1;
const int b=2;
const int c=4;
const int d=8;
const int e=16;
const int f=32;
const int g=64;
byte digits[10];
byte inf[3];
byte pic[3];
byte intvl[3];
//interval settings
long interval = 10; //seconds
long oldInterval;
long intervalCounter = 0;  //this variable and the next allow for incrementation of the interval
long intervalStep = 10;  //so that the timelapse can be interrupted at any time.
int infoDelay = 1500;
int wakeup = 300;          //time to activate wakeup (focus)
int wakewait =200;         //time between wake and shutter
//number of pictures to be taken total
boolean changeNumPics = true;
int oldNumPics = 0;
int numPics = 0; //total number of pictures, 0 means infinite.
long numPicsChanged = infoDelay;
long numPicsTimeout = 2000; //ms
int count = 0;  //keeps track of number of pictures.
//variables for different options (HDR and minute/second)
boolean minute = false;
int minuteMultiplier = 1;
boolean HDR = false;  //flag for hdr timelapses
//button logic and debouncing
boolean start = false; //records whether timelapse should be going or not.
int startReading;  //reads start button input
int prevStartReading = LOW;  //stores last start button input for latching.
int upReading;  //reads up/down button input
int prevUpReading = LOW;  //stores last up button input for latching.
int downReading;  //reads down button input
int prevDownReading = LOW;  //stores last down button input for latching.
long pressStartTime = 0;  //stores time of last button state change for debouncing
long pressUpTime = 0;  //ditto
long pressDownTime = 0;  //ditto
long debounceDelay = 100;  //debounce wait period in ms
//miscellaneous variables
boolean sleeping = false;
long activityTime = 0;
long sleepTime= 300000; //ms, time to wait before sleeping. (300000 ms = 5 min)
int waitTime;
int safetyDelay = 50; //ms, wait period when camera pin is HIGH to give the camera time to respond
int HDRsafetyDelay = 1500; //ms, time the camera pin is HIGH for fast-fire HDR pictures to be taken
void setup(){
 //declare the pins as inputs or outputs
 pinMode(shutterPin, OUTPUT);
 pinMode(wakepin, OUTPUT);
 pinMode(HDRPin, INPUT);
 pinMode(startPin, INPUT);
 pinMode(startLEDPin, OUTPUT);
 pinMode(clockPin, OUTPUT);
 pinMode(serialOnesPin, OUTPUT);
 pinMode(serialTensPin, OUTPUT);
 pinMode(serialHundsPin, OUTPUT);
 pinMode(upPin, INPUT);
 pinMode(downPin, INPUT);
 pinMode(minutePin, INPUT);
 //define which segments of the 7-segment LEDs should light for different digits
 digits[0] = a + b + c + d + e + f;
 digits[1] = b + c;
 digits[2] = a + b + g + e + d;
 digits[3] = a + b + g + c + d;
 digits[4] = f + g + b + c;
 digits[5] = a + f + g + c + d;
 digits[6] = a + f + g + c + d + e;
 digits[7] = a + b + c;
 digits[8] = a + b + c + d + e + f + g;
 digits[9] = a + b + f + g + c + d;
 //define the segments for displaying "inf"
 inf[0] = b + c;
 inf[1] = e + g + c;
 inf[2] = a + f + g + e;
 //define the segments for displaying "pic"
 pic[0] = a + b + g + f + e;
 pic[1] = inf[0];
 pic[2] = a + f + e + d;
 //define the segments for displaying "int"
 intvl[0] = b + c;
 intvl[1] = inf[1];
 intvl[2] = f + g + e + d;
 //start/stop button is an interrupt so that it's always active
 attachInterrupt(0, checkStart, RISING);
 //give some parameter information.
displayPIC();
delay(infoDelay);
if (numPics == 0){
  displayINF();
else{
  displayDEC(numPics/10);
 while (changeNumPics){
     oldNumPics = numPics;
     checkUp();
     checkDown();
     Serial.println(numPics);
     if (oldNumPics != numPics){
        if (numPics == 0){
          displayINF();
        else{
     if (millis() - numPicsChanged > numPicsTimeout){
       changeNumPics = false;
 displayINT();
 delay(infoDelay);
 displayDEC(interval);
void loop(){
 //if timelapse is not running, display the current interval between pictures and be ready
 //to accept input that will change the value of interval.
 if (!start){
   minute = digitalRead(minutePin);
   oldInterval = interval;
   checkUp();
   checkDown();
   if (oldInterval != interval){  //helps reduce flicker in the display
 while ((count <= numPics || numPics == 0) && start == true){
   sleeping = (millis()-activityTime > sleepTime);
   Serial.println("sleep status");
   Serial.println(sleeping, DEC);
   //set wait time, depending on status of HDR flag.
   HDR = digitalRead(HDRPin);
   if (HDR){
     waitTime = HDRsafetyDelay;
   else{
     waitTime = safetyDelay;
   //take a picture
     digitalWrite(wakepin, HIGH);   //turn wakeup/focus on
     delay(wakeup);                 //keep focus
     digitalWrite(wakepin, LOW);    //turn wakeup off
     delay(wakewait);               //wait
     digitalWrite(shutterPin, HIGH);
     delay(waitTime);
     digitalWrite(shutterPin, LOW);
     count++;
   //display picture number
   if (sleeping){
     displayOFF();
   else{
     displayDEC(count);
   //wait the user-set interval
   if (minute){
     minuteMultiplier = 60;
   else{
     while((intervalStep*intervalCounter) < (((interval*1000)*minuteMultiplier)-(2*waitTime)) && start){
       delay(intervalStep);
       intervalCounter++;
   //if the timelapse is to be stopped (or is finished), reset the counter to prepare it for the next timelapse.
   if (!start || count == numPics){
     count = 0;
     start = false;
     digitalWrite(startLEDPin, start);
//////Other Functions///////////////////////
//function to check the state of the start button and change the variables/LED state correspondingly
void checkStart(){
 if (!changeNumPics){
 activityTime = millis();
 if (sleeping){
   sleeping = false;
   displayDEC(count);
 else{
 //if (millis() - pressStartTime > debounceDelay){ **debounce handled by hardware.
   start = !start;
   //pressStartTime = millis();
warrenf
second half
//function to check the state of the up button and increment interval accordingly.
void checkUp(){
 upReading = digitalRead(upPin);
 if (upReading == HIGH && prevUpReading == LOW && millis() - pressUpTime > debounceDelay){
   if (changeNumPics){
     if (numPics >= 9950){  //allows variable to wrap around.
       numPics = 0;
     else{
       numPics += 50;
       numPicsChanged = millis();
   else{
     if (interval >= 999){
       interval = 0;
     else{
       interval += 1;
   pressUpTime = millis();
 prevUpReading = upReading;
//function to check the state of the down button and increment interval accordingly.
void checkDown(){
 downReading = digitalRead(downPin);
 if (downReading == HIGH && prevDownReading == LOW && millis() - pressDownTime > debounceDelay){
   if (changeNumPics){
     if (numPics <= 0){  //allows variable to wrap around.
       numPics = 9950;
     else{
       numPics -= 50;
   else{
     if (interval <= 0){
       interval = 999;
     else{
       interval -= 1;
   pressDownTime = millis();
 prevDownReading = downReading;
//function to display a 3 digit number on 7-segment displays.
void displayDEC(int i){
 for (byte bitMask = 128; bitMask > 0; bitMask >>= 1){
  digitalWrite(clockPin, LOW);
  digitalWrite(serialOnesPin, bitMask & ~digits[i%10] ? HIGH : LOW);
  digitalWrite(serialTensPin, bitMask & ~digits[(i/10%10)] ? HIGH : LOW);
  digitalWrite(serialHundsPin, bitMask & ~digits[i/100] ? HIGH : LOW);
  digitalWrite(clockPin, HIGH);
//function to display "inf" on 3 7-segment displays.
void displayINF(){
   digitalWrite(serialOnesPin, bitMask & ~inf[2] ? HIGH : LOW);
   digitalWrite(serialTensPin, bitMask & ~inf[1] ? HIGH : LOW);
   digitalWrite(serialHundsPin, bitMask & ~inf[0] ? HIGH : LOW);
void displayPIC(){
   digitalWrite(serialOnesPin, bitMask & ~pic[2] ? HIGH : LOW);
   digitalWrite(serialTensPin, bitMask & ~pic[1] ? HIGH : LOW);
   digitalWrite(serialHundsPin, bitMask & ~pic[0] ? HIGH : LOW);
void displayINT(){
   digitalWrite(serialOnesPin, bitMask & ~intvl[2] ? HIGH : LOW);
   digitalWrite(serialTensPin, bitMask & ~intvl[1] ? HIGH : LOW);
   digitalWrite(serialHundsPin, bitMask & ~intvl[0] ? HIGH : LOW);
void displayOFF(){
   digitalWrite(serialOnesPin, HIGH);
   digitalWrite(serialTensPin, HIGH);
   digitalWrite(serialHundsPin, HIGH);
AWOL
#6
Dec 11, 2012, 08:41 pm Last Edit: Dec 11, 2012, 08:43 pm by AWOL Reason: 1
Code: [Select]
That's a pretty roundabout way of doing eight iterations. In the absence of comments, any particular reason?
Quote
the code dont fit
probably because there's too much of it.
warrenf
not sure y its like that.
its a code that i found on the net.
im new so only know the very basics.
if you know a better way im all ears.
HazardsMind
Where did you find that code, because that is a LOT of code.
Do you have a link?
My GitHub:
warrenf
sadly i did not keep the link.
guess i should have.
HazardsMind
Could you retrace your steps?
My GitHub:
AWOL
For now, all you need to show is whether or not a number of inputs work.
So, write a small sketch that does just that, using known I/O mechanisms, like Serial.print.
warrenf
PeterH
silly me.
Quite possibly. A relay and a transistor are not usually interchangeable. What you're trying to do does not sound especially hard, but the picture you posted shows a fairly complex circuit, and I don't know whether you're getting even the basics right let alone wiring up things like that correctly.
warrenf
the cct worked.
problems came after i put the 9v battery in the wrong side.
now i just cant get the analogs to work.
