Loading...
Pages: 1 [2] 3   Go Down
Author Topic: analog input issuses  (Read 1349 times)
Queens, New York
Offline Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
Ok you have the pull down resistor wired correctly, I'm assuming.
You don't need to make them analog unless your reading varying voltages, or resistances, I mean it will work, but you don't need it.
Just for now make the buttons and switches, digital, that way all you need to see is if it is HIGH or LOW.
Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Offline Offline
Newbie
View Profile
ok. all the digital pin are being used. and the origanal 5 that were the switches are damaged. this is y im using analog.
Logged
Queens, New York
Offline Offline
Edison Member
View Profile
Ok but, I just want you to test the buttons and switches without anything else on the arduino. When you know for sure that everything is working ,you can move them the analog pins. You need to see if you get either 1 or 255 when it is HIGH, and 0 for LOW
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
You could do a very simple ASCII "logical analyser".
Set all I/O pins (except pins zero and one!) to be inputs in "setup()", and enable their pullups.
In "loop()", digitalRead every pin and Serial.print its value as one or zero, and at the end of "loop()", call "Serial.println()" so all the results are on a single line.
As the program is running, simply ground a pin at a time, and check that the display in the serial monitor reflects this.
This program shouldn't be more than a dozen or so lines.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
hey guys thanks for the advice i did the serialwrite thing to check if its picking up the inputs. and when i run the simple sketch it picks up all the buttons .
but when i put the end cct together it will not pick up the start stop button. but picks up all the others?
any ideas?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
any ideas?
Post code.
Logged
Offline Offline
Newbie
View Profile
its the code i posted at the beginning of the thread
Logged
Offline Offline
Newbie
View Profile
hey so iv figured out that the problem is not hardware. its in the sketch. iv stared at it for hours and cant figure out what the problem is. can some one take a look?
Logged
Offline Offline
Edison Member
View Profile
Then how did you determine that it is software not hardware?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Code:
const int startPin = A0; //input for begin button
void setup ()
  pinMode(startPin, INPUT);
void loop ()
  Serial.println (digitalRead (startPin));
What does that do? (uncompiled, untested)
What is connected to digital pin 2?
Logged
Offline Offline
Newbie
View Profile
i loaded the sketch and all buttons work. cept the start button.
so i changed the sketches buttons allocations, so changed the start and up around.
same story. what used to be the start buttons works now to increase the values,
but it still wont start when you press the new start button
hope that makes sense
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
other thing you should probly know is that i made a boo boo and stuck 9v threw the 5 inputs this is y im trying to use the analog input.
silly me.
Uh-oh!
You're assuming that the interrupt functionality of pin 2 transfers to A0?
Sorry.
Logged
Offline Offline
Newbie
View Profile
ya the sketch didnt have a wake up function to wake the camera up after longer intervals so was goin to make pin 2 the wake up pin.
Logged
Offline Offline
Newbie
View Profile
so any ideas
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Use pin change interrupts, or replace the processor are the first two that spring to mind.
The second is my favourite.
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
