« on: December 11, 2012, 01:33:20 pm » |
hi guy and girls. im new to the arduino. i have theuno rev 3 im having an issue with using the anolg input for my project. i have 3 push buttons and two switches they each run threw a 10k pull down resister. but only two push button read on the arduino. and neather of the switches. what could the issue be?
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
« Reply #1 on: December 11, 2012, 01:39:23 pm » |
post your code
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
UK
« Reply #2 on: December 11, 2012, 02:18:07 pm » |
And a schematic.
« Reply #3 on: December 11, 2012, 02:34:18 pm » |
ok here it is
in the drawing pin 11 becomes A4 10 becomes A3 5 A1 4 A2 2 A0
other thing you should probly know is that i made a boo boo and stuck 9v threw the 5 inputs this is y im trying to use the analog input. silly me. and the transistor i changed to a relay and also tried to add in a wake up funtion for the camera with a second relay.
so i may well have messed this whole thing up.
« Reply #4 on: December 11, 2012, 02:35:43 pm » |
the code dont fit so here is the first half //pins on the arduino. const int shutterPin = 3; //output to camera const int startLEDPin = 13; //visual display of timelapse running const int upPin = A1; //input for up button const int downPin = A2; //input for down button const int minutePin = A3; //visual display of minutes yes/no (seconds in active if not HIGH)
const int HDRPin = A4; //visual display of HDR yes/no const int startPin = A0; //input for begin button const int wakepin = 12;
//for displaying digits on the 7-segment LEDs. const int clockPin = 6; const int serialOnesPin = 7; const int serialTensPin = 8; const int serialHundsPin = 9;
const int a=1; const int b=2; const int c=4; const int d=8; const int e=16; const int f=32; const int g=64;
byte digits[10]; byte inf[3]; byte pic[3]; byte intvl[3];
//interval settings long interval = 10; //seconds long oldInterval; long intervalCounter = 0; //this variable and the next allow for incrementation of the interval long intervalStep = 10; //so that the timelapse can be interrupted at any time.
int infoDelay = 1500; int wakeup = 300; //time to activate wakeup (focus) int wakewait =200; //time between wake and shutter
//number of pictures to be taken total boolean changeNumPics = true; int oldNumPics = 0; int numPics = 0; //total number of pictures, 0 means infinite. long numPicsChanged = infoDelay; long numPicsTimeout = 2000; //ms int count = 0; //keeps track of number of pictures.
//variables for different options (HDR and minute/second) boolean minute = false; int minuteMultiplier = 1; boolean HDR = false; //flag for hdr timelapses
//button logic and debouncing boolean start = false; //records whether timelapse should be going or not. int startReading; //reads start button input int prevStartReading = LOW; //stores last start button input for latching. int upReading; //reads up/down button input int prevUpReading = LOW; //stores last up button input for latching. int downReading; //reads down button input int prevDownReading = LOW; //stores last down button input for latching.
long pressStartTime = 0; //stores time of last button state change for debouncing long pressUpTime = 0; //ditto long pressDownTime = 0; //ditto long debounceDelay = 100; //debounce wait period in ms
//miscellaneous variables boolean sleeping = false; long activityTime = 0; long sleepTime= 300000; //ms, time to wait before sleeping. (300000 ms = 5 min) int waitTime; int safetyDelay = 50; //ms, wait period when camera pin is HIGH to give the camera time to respond int HDRsafetyDelay = 1500; //ms, time the camera pin is HIGH for fast-fire HDR pictures to be taken
void setup(){ //declare the pins as inputs or outputs pinMode(shutterPin, OUTPUT); pinMode(wakepin, OUTPUT); pinMode(HDRPin, INPUT); pinMode(startPin, INPUT); pinMode(startLEDPin, OUTPUT); pinMode(clockPin, OUTPUT); pinMode(serialOnesPin, OUTPUT); pinMode(serialTensPin, OUTPUT); pinMode(serialHundsPin, OUTPUT); pinMode(upPin, INPUT); pinMode(downPin, INPUT); pinMode(minutePin, INPUT); //define which segments of the 7-segment LEDs should light for different digits digits[0] = a + b + c + d + e + f; digits[1] = b + c; digits[2] = a + b + g + e + d; digits[3] = a + b + g + c + d; digits[4] = f + g + b + c; digits[5] = a + f + g + c + d; digits[6] = a + f + g + c + d + e; digits[7] = a + b + c; digits[8] = a + b + c + d + e + f + g; digits[9] = a + b + f + g + c + d; //define the segments for displaying "inf" inf[0] = b + c; inf[1] = e + g + c; inf[2] = a + f + g + e; //define the segments for displaying "pic" pic[0] = a + b + g + f + e; pic[1] = inf[0]; pic[2] = a + f + e + d; //define the segments for displaying "int" intvl[0] = b + c; intvl[1] = inf[1]; intvl[2] = f + g + e + d; Serial.begin(9600); //start/stop button is an interrupt so that it's always active attachInterrupt(0, checkStart, RISING); //give some parameter information. displayPIC(); delay(infoDelay); if (numPics == 0){ displayINF(); } else{ displayDEC(numPics/10); } while (changeNumPics){ oldNumPics = numPics; checkUp(); checkDown(); Serial.println(numPics); if (oldNumPics != numPics){ if (numPics == 0){ displayINF(); } else{ displayDEC(numPics/10); } } if (millis() - numPicsChanged > numPicsTimeout){ changeNumPics = false; } } displayINT(); delay(infoDelay); displayDEC(interval); }
void loop(){ //if timelapse is not running, display the current interval between pictures and be ready //to accept input that will change the value of interval. if (!start){ minute = digitalRead(minutePin); oldInterval = interval; checkUp(); checkDown(); if (oldInterval != interval){ //helps reduce flicker in the display displayDEC(interval); } } while ((count <= numPics || numPics == 0) && start == true){ sleeping = (millis()-activityTime > sleepTime); Serial.println("sleep status"); Serial.println(sleeping, DEC);
//set wait time, depending on status of HDR flag. HDR = digitalRead(HDRPin); if (HDR){ waitTime = HDRsafetyDelay; } else{ waitTime = safetyDelay; } //take a picture digitalWrite(wakepin, HIGH); //turn wakeup/focus on delay(wakeup); //keep focus digitalWrite(wakepin, LOW); //turn wakeup off delay(wakewait); //wait digitalWrite(shutterPin, HIGH);
delay(waitTime);
digitalWrite(shutterPin, LOW); count++; //display picture number if (sleeping){ displayOFF(); } else{ displayDEC(count); } //wait the user-set interval if (minute){ minuteMultiplier = 60; } else{ minuteMultiplier = 1; }
intervalCounter = 0; while((intervalStep*intervalCounter) < (((interval*1000)*minuteMultiplier)-(2*waitTime)) && start){ delay(intervalStep); intervalCounter++; } //if the timelapse is to be stopped (or is finished), reset the counter to prepare it for the next timelapse. if (!start || count == numPics){ displayDEC(interval); count = 0; start = false; digitalWrite(startLEDPin, start); } } }
//////////////////////////////////////////// //////Other Functions/////////////////////// ////////////////////////////////////////////
//function to check the state of the start button and change the variables/LED state correspondingly void checkStart(){ if (!changeNumPics){ activityTime = millis(); if (sleeping){ sleeping = false; displayDEC(count); } else{ //if (millis() - pressStartTime > debounceDelay){ **debounce handled by hardware. start = !start; digitalWrite(startLEDPin, start); //pressStartTime = millis(); //} } } }
« Reply #5 on: December 11, 2012, 02:36:09 pm » |
second half
//function to check the state of the up button and increment interval accordingly. void checkUp(){ upReading = digitalRead(upPin); if (upReading == HIGH && prevUpReading == LOW && millis() - pressUpTime > debounceDelay){ activityTime = millis(); if (changeNumPics){ if (numPics >= 9950){ //allows variable to wrap around. numPics = 0; } else{ numPics += 50; numPicsChanged = millis(); } } else{ if (interval >= 999){ interval = 0; } else{ interval += 1; } } pressUpTime = millis(); } prevUpReading = upReading; }
//function to check the state of the down button and increment interval accordingly. void checkDown(){ downReading = digitalRead(downPin); if (downReading == HIGH && prevDownReading == LOW && millis() - pressDownTime > debounceDelay){ activityTime = millis(); if (changeNumPics){ if (numPics <= 0){ //allows variable to wrap around. numPics = 9950; } else{ numPics -= 50; numPicsChanged = millis(); } } else{ if (interval <= 0){ interval = 999; } else{ interval -= 1; } } pressDownTime = millis(); } prevDownReading = downReading; }
//function to display a 3 digit number on 7-segment displays. void displayDEC(int i){ for (byte bitMask = 128; bitMask > 0; bitMask >>= 1){ digitalWrite(clockPin, LOW); digitalWrite(serialOnesPin, bitMask & ~digits[i%10] ? HIGH : LOW); digitalWrite(serialTensPin, bitMask & ~digits[(i/10%10)] ? HIGH : LOW); digitalWrite(serialHundsPin, bitMask & ~digits[i/100] ? HIGH : LOW); digitalWrite(clockPin, HIGH); } }
//function to display "inf" on 3 7-segment displays. void displayINF(){ for (byte bitMask = 128; bitMask > 0; bitMask >>= 1){ digitalWrite(clockPin, LOW); digitalWrite(serialOnesPin, bitMask & ~inf[2] ? HIGH : LOW); digitalWrite(serialTensPin, bitMask & ~inf[1] ? HIGH : LOW); digitalWrite(serialHundsPin, bitMask & ~inf[0] ? HIGH : LOW); digitalWrite(clockPin, HIGH); } }
void displayPIC(){ for (byte bitMask = 128; bitMask > 0; bitMask >>= 1){ digitalWrite(clockPin, LOW); digitalWrite(serialOnesPin, bitMask & ~pic[2] ? HIGH : LOW); digitalWrite(serialTensPin, bitMask & ~pic[1] ? HIGH : LOW); digitalWrite(serialHundsPin, bitMask & ~pic[0] ? HIGH : LOW); digitalWrite(clockPin, HIGH); } } void displayINT(){ for (byte bitMask = 128; bitMask > 0; bitMask >>= 1){ digitalWrite(clockPin, LOW); digitalWrite(serialOnesPin, bitMask & ~intvl[2] ? HIGH : LOW); digitalWrite(serialTensPin, bitMask & ~intvl[1] ? HIGH : LOW); digitalWrite(serialHundsPin, bitMask & ~intvl[0] ? HIGH : LOW); digitalWrite(clockPin, HIGH); } } void displayOFF(){ for (byte bitMask = 128; bitMask > 0; bitMask >>= 1){ digitalWrite(clockPin, LOW); digitalWrite(serialOnesPin, HIGH); digitalWrite(serialTensPin, HIGH); digitalWrite(serialHundsPin, HIGH); digitalWrite(clockPin, HIGH); } } ///////////////////////////////////////////[
UK
« Reply #6 on: December 11, 2012, 02:41:15 pm » |
for (byte bitMask = 128; bitMask > 0; bitMask >>= 1){ digitalWrite(clockPin, LOW); digitalWrite(serialOnesPin, HIGH); digitalWrite(serialTensPin, HIGH); digitalWrite(serialHundsPin, HIGH); digitalWrite(clockPin, HIGH); } That's a pretty roundabout way of doing eight iterations. In the absence of comments, any particular reason? the code dont fit probably because there's too much of it.
« Last Edit: December 11, 2012, 02:43:42 pm by AWOL »
« Reply #7 on: December 11, 2012, 02:55:01 pm » |
not sure y its like that. its a code that i found on the net. im new so only know the very basics. if you know a better way im all ears.
Queens, New York
« Reply #8 on: December 11, 2012, 02:59:51 pm » |
Where did you find that code, because that is a LOT of code. Do you have a link?
« Reply #9 on: December 11, 2012, 03:03:03 pm » |
sadly i did not keep the link. guess i should have.
Queens, New York
« Reply #10 on: December 11, 2012, 03:04:43 pm » |
Could you retrace your steps?
UK
« Reply #11 on: December 11, 2012, 03:06:08 pm » |
For now, all you need to show is whether or not a number of inputs work. So, write a small sketch that does just that, using known I/O mechanisms, like Serial.print.
« Reply #12 on: December 11, 2012, 03:12:10 pm » |
thanks ill try that.
UK
« Reply #13 on: December 11, 2012, 06:25:42 pm » |
Quite possibly. A relay and a transistor are not usually interchangeable. What you're trying to do does not sound especially hard, but the picture you posted shows a fairly complex circuit, and I don't know whether you're getting even the basics right let alone wiring up things like that correctly.
« Reply #14 on: December 11, 2012, 11:38:28 pm » |
the cct worked. problems came after i put the 9v battery in the wrong side. now i just cant get the analogs to work.
