Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
« Reply #15 on: December 11, 2012, 11:46:54 pm » |
Ok you have the pull down resistor wired correctly, I'm assuming.
You don't need to make them analog unless your reading varying voltages, or resistances, I mean it will work, but you don't need it.
Just for now make the buttons and switches, digital, that way all you need to see is if it is HIGH or LOW.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
« Reply #16 on: December 12, 2012, 06:57:44 am » |
ok. all the digital pin are being used. and the origanal 5 that were the switches are damaged. this is y im using analog.
Queens, New York
« Reply #17 on: December 12, 2012, 10:28:31 am » |
Ok but, I just want you to test the buttons and switches without anything else on the arduino. When you know for sure that everything is working ,you can move them the analog pins. You need to see if you get either 1 or 255 when it is HIGH, and 0 for LOW
UK
Online
« Reply #18 on: December 12, 2012, 10:52:32 am » |
You could do a very simple ASCII "logical analyser". Set all I/O pins (except pins zero and one!) to be inputs in "setup()", and enable their pullups. In "loop()", digitalRead every pin and Serial.print its value as one or zero, and at the end of "loop()", call "Serial.println()" so all the results are on a single line. As the program is running, simply ground a pin at a time, and check that the display in the serial monitor reflects this. This program shouldn't be more than a dozen or so lines.
« Reply #19 on: December 23, 2012, 11:13:24 am » |
hey guys thanks for the advice i did the serialwrite thing to check if its picking up the inputs. and when i run the simple sketch it picks up all the buttons . but when i put the end cct together it will not pick up the start stop button. but picks up all the others? any ideas?
UK
Online
« Reply #20 on: December 23, 2012, 11:18:49 am » |
« Reply #21 on: December 23, 2012, 11:20:25 am » |
its the code i posted at the beginning of the thread
« Reply #22 on: December 28, 2012, 08:50:24 am » |
hey so iv figured out that the problem is not hardware. its in the sketch. iv stared at it for hours and cant figure out what the problem is. can some one take a look?
« Reply #23 on: December 28, 2012, 08:55:12 am » |
Then how did you determine that it is software not hardware?
UK
Online
« Reply #24 on: December 28, 2012, 08:59:02 am » |
const int startPin = A0; //input for begin button void setup () { pinMode(startPin, INPUT); Serial.begin(9600); }
void loop () { Serial.println (digitalRead (startPin)); } What does that do? (uncompiled, untested) What is connected to digital pin 2?
« Reply #25 on: December 28, 2012, 09:01:14 am » |
i loaded the sketch and all buttons work. cept the start button. so i changed the sketches buttons allocations, so changed the start and up around. same story. what used to be the start buttons works now to increase the values, but it still wont start when you press the new start button
hope that makes sense
UK
Online
« Reply #26 on: December 28, 2012, 09:01:43 am » |
other thing you should probly know is that i made a boo boo and stuck 9v threw the 5 inputs this is y im trying to use the analog input. silly me. Uh-oh! You're assuming that the interrupt functionality of pin 2 transfers to A0? Sorry.
« Reply #27 on: December 28, 2012, 09:06:13 am » |
ya the sketch didnt have a wake up function to wake the camera up after longer intervals so was goin to make pin 2 the wake up pin.
« Reply #28 on: December 28, 2012, 10:02:47 am » |
so any ideas
UK
Online
« Reply #29 on: December 28, 2012, 10:07:36 am » |
Use pin change interrupts, or replace the processor are the first two that spring to mind. The second is my favourite.
