Central MN, USA
Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
« on: December 11, 2012, 04:14:40 pm » |
I wonder if someone knows the answer to this probably obvious question. I have see on digikey.com 11mm rotary encoders and 12mm rotary encoders. I wonder where that 11mm or 12mm comes from: Datasheets: http://www.bitechnologies.com/pdfs/en11.pdfhttp://www.bitechnologies.com/pdfs/en12.pdfBesides some apparent different in the options (pulse per revolution, push button, shaft type and shaft lengths) the foot print is almost identical, with the 12mm a bit wider in one dimension. Were there 11mm 12mm names historical or do they refer to something I obviously didn't catch? Thank you!
Logged
Canada
Offline
Sr. Member
Sometimes teaching, always learning,
« Reply #1 on: December 11, 2012, 05:14:37 pm » |
It appears that their width is 11.7mm and 12.4mm, respecively. That would be my guess how they got their name.
Logged
Central MN, USA
Offline
Faraday Member
« Reply #2 on: December 11, 2012, 09:32:57 pm » |
I noticed that too. Kind of superficial difference. "Hey, we have two types of rotary encoders, they kind of differ only by 10 percent in a minor dimension". Should be other reason?!
Logged
0
Online
Tesla Member
Arduino rocks
« Reply #3 on: December 11, 2012, 09:43:55 pm » |
For potentiometers the normal dimension to use is the shaft diameter. Knowing what sized hole to drill in the front panel is also useful.
Logged
Central MN, USA
Offline
Faraday Member
« Reply #4 on: December 11, 2012, 10:31:38 pm » |
Borh series have 6mm diameter shafts.
Logged
Central MN, USA
Offline
Faraday Member
« Reply #5 on: December 12, 2012, 09:45:03 am » |
Maybe it does not refer to a measurement dimension but to case style. EN11 is cast metal body & shaft, EN12 is pressed metal body & plastic shaft.
Thanks Riva. I start to grow a feeling that there is no huge difference between 11mm and 12mm encoders.
Logged
South Texas
Offline
God Member
« Reply #6 on: December 12, 2012, 01:04:47 pm » |
Other than one has parts that are a bit more durable, and encoder is and encoder. They Give pulses as you rotate them. The various sizes have more to do with mounting than with function.
Logged
Samplefinger
Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
« Reply #7 on: December 12, 2012, 02:06:53 pm » |
Boy I disagree. The first encoders I bought were mechanical ones with detents. Then I bought several optical ones that give a whole lot more resolution and no freaking detents. I love these encoders, they are the nicest thing I have as far as user interface parts. They also breadboard really well. http://www.ebay.com/itm/370592502534It is so choice. If you have the means, I highly recommend picking one up.
Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Central MN, USA
Offline
Faraday Member
« Reply #8 on: December 12, 2012, 02:58:42 pm » |
That's the whole reason I was buying these encoders, for user interface. A rotary encoder is analog/digital in one. You can control speed with how fast you turn it, with a large range of speed. With buttons, you cannot press them too fast. http://arduino.cc/forum/index.php/topic,130945
Logged
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #9 on: December 12, 2012, 04:59:41 pm » |
Boy I disagree. The first encoders I bought were mechanical ones with detents. Then I bought several optical ones that give a whole lot more resolution and no freaking detents. I love these encoders, they are the nicest thing I have as far as user interface parts. They also breadboard really well. http://www.ebay.com/itm/370592502534It is so choice. If you have the means, I highly recommend picking one up. I can't agree more with that statement. My first playing with quad-encoders was with one of those cheap $5 mechanical ones. Between contact bounce and the mechanical de-tents not always matching up well with the contact transition positions, I was pretty frustrated with the whole concept of using on in any of my projects. Then I found a web site (gold electronics) that was selling some nice surplus (new old stock) high grade optical encoders for $5 and boy what a different (I bought 4 and they sold out quickly so don't look for them there now). It's a great device to use if you can be patient and look for a good one via surplus or used on E-bay. The cheap mechanical ones are really garbage, I'm not saying that with enough tweaking of code and you can't make a mechanical one somewhat work, but I personally will never waste my time using one. I still have 3 optical encoders left. Lefty
Logged
Central MN, USA
Offline
Faraday Member
« Reply #10 on: December 12, 2012, 06:17:27 pm » |
The mechanical ones I bought for less than a dollar a piece are fine enough for user interface. I'll make some videos hopefully today.
Logged
Offline
Brattain Member
« Reply #11 on: December 12, 2012, 09:50:34 pm » |
Sure if you hate the user. Steve Jobs would never have approved the use of a mechanical encoder.  Lefty
Logged
Central MN, USA
Offline
Faraday Member
« Reply #12 on: December 12, 2012, 11:40:24 pm » |
Logged
South Texas
Offline
God Member
« Reply #13 on: December 13, 2012, 02:00:49 pm » |
Mechanical encoders have their place, and opticals have their place. I have designed a welding machine that used 10 of the $2.58 mechanical encoders and the users loved them. Previously they had used optical encoders and they were almost useless. For an operator input the small mechanicals fit the bill well. for motion monitoring the optical encoders are much better.
Logged
Samplefinger
Offline
God Member
« Reply #14 on: December 13, 2012, 02:16:28 pm » |
One thing I don't like about the mechanicals is their stated lifetime. It's usually pathetic. Is it OK to use that on a machine that is used two shifts a day?
Logged
