Topic: Simple Dumping Monitor Library version 0.14. Now Arduino Leonardo is supported (Read 3070 times) previous topic - next topic
Vanyamba
Since version 0.14 Simple Dumping Monitor for Arduino library supports Arduino Leonardo-compatible both ATmega16U4 and ATmega32U4 microcontrollers based boards.
The Simple Dumping Monitor for Arduino library allows you to get dumps of either Flash, RAM and EEPROM memories, dump of registers, interrupt vectors table and dumps of timers.
Please read more either how to get dumps or how to debug your sketches at SourceForge.
English documentation for the library is available at SourceForge wiki.
Also you can download latest version of the library from SourceForge.
Support the Arduino libraries development, tweet the library and like its SourceForge page.
Have a nice dump! =)
Proudly developed by
Vanyamba Electronics, 2012.
Vanyamba
#1
Dec 14, 2012, 11:40 pm Last Edit: Dec 14, 2012, 11:42 pm by Vanyamba Reason: 1
Hidden feature of Arduino Leonardo is Timer-Counter 2!
You can get PWM at both Digital 2 and Digital 8 pins.
This is the sketch:
Code: [Select]
#include <dumpmon.h> // This sketch uses VEduino Library.
#define LED1                DEV_TIMER2_OCA         // Set up your own values here: PORT, PIN
#define LED2                DEV_TIMER2_OCB         // Set up your own values here: PORT, PIN
uint8_t potValue;
  dumpmonSetup(19200);
 DEV_TIMER2.setClockSelect(Prescaler2::Prescaler_64);
 DEV_TIMER2.setWaveGenMode(Timer2::FastPWM);
 DEV_TIMER2.setCompOutModeA(Timer2::Clear);
 DEV_TIMER2.setCompOutModeB(Timer2::Clear);
 setModeOutput(LED1);
 setModeOutput(LED2);
  dumpmonLoop();
 potValue = analogRead(A0) >> 2;
 DEV_TIMER2.setOutputCompareA(potValue);
 DEV_TIMER2.setOutputCompareB(potValue);
pito
Hi, trying your examples with 115k2 but getting garbage.. Any hint where else to set the proper baudrate?
Vanyamba
Thank you for this BUG.  :)
I fixed it at version 0.19
pito
Nice  :)
Are these PortB infos correct?
Code: [Select]
<17> text watch
0158  count  0009  "2E2E"
015A  lcoun  00000009  "2E2E2E2E"
0140  text   "Example"
0025  PORTB  00  "2E"
N
<18> counters watch
0158  count  000A  "2E2E"
015A  lcoun  0000000A  "2E2E2E2E"
0140  text   "Example"
0025  PORTB  20  "20"
N
<19> text watch
0140  text   "Debug"
0025  PORTB  20  "20"
PS: I would add a bin representation for the PORTx as well ie:
0025  PORTB  20  " " 00100000
Vanyamba
Fixed and added to version 0.20.
pito
Vanyamba
Vanyamba
