Topic: Two Way Serial communication with Arduino & Processing (Read 2352 times) previous topic - next topic
lscangus
Hi. I have manage to send the sensor data "tune" to the processing, but when i am trying to send the data back to Arduino,(when "tune" is less than -100, LED on pin 13 lights up, later it will be implemented to a servo action) the reaction time is very slow, and it seems the things are out of sync. I have googled and people said is the buffer problem, but i cannot manage to find a way to sort it out.
Thank you for answering =]
Processing
Code: [Select]
import processing.serial.*;
Serial myPort;
float value;
int val;
int state;
  println("COM Ports");
  println(myPort.list());
  println("=========");
  myPort = new Serial(this, Serial.list()[5], 9600);
void draw()
void serialEvent(Serial p) {
  // get message till line break (ASCII > 13)
  if ( myPort.available() > 0) {
//    while ( myPort.available() > 0);
    String message = myPort.readStringUntil(13);
    if (message != null) {
      value = float(message);
      //    println(value);
  if (value < -100) {
    state=1;
  else {
    state=0;
  myPort.write(state);
  println(state);
Arduino
Code: [Select]
* Therremin with TTL Oscillator 4MHz
* Timer1 for freauency measurement
* Timer2 for gate time
#include <Stdio.h>
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
//! Macro that clears all Timer/Counter1 interrupt flags.
#define CLEAR_ALL_TIMER1_INT_FLAGS    (TIFR1 = TIFR1)
int pinLed = 13;                 // LED connected to digital pin 13
int pinFreq = 5;
int pinFreq2 = 6;
int incomingByte;
  pinMode(pinLed, OUTPUT);      // sets the digital pin as output
  pinMode(pinFreq, INPUT);
  pinMode(pinFreq2, INPUT);
  pinMode(8, OUTPUT);
  Serial.begin(9600);        // connect to the serial port
  // hardware counter setup ( refer atmega168.pdf chapter 16-bit counter1)
  TCCR1A=0;                   // reset timer/counter1 control register A
  TCCR1B=0;                   // reset timer/counter1 control register A
  TCNT1=0;                    // counter value = 0
  // set timer/counter1 hardware as counter , counts events on pin T1 ( arduino pin 5)
  // normal mode, wgm10 .. wgm13 = 0
  sbi (TCCR1B ,CS10);         // External clock source on T1 pin. Clock on rising edge.
  sbi (TCCR1B ,CS11);
  sbi (TCCR1B ,CS12);
  // timer2 setup / is used for frequency measurement gatetime generation
  // timer 2 presaler set to 256 / timer 2 clock = 16Mhz / 256 = 62500 Hz
  cbi (TCCR2B ,CS20);
  sbi (TCCR2B ,CS21);
  sbi (TCCR2B ,CS22);
  //set timer2 to CTC Mode
  cbi (TCCR2A ,WGM20);
  sbi (TCCR2A ,WGM21);
  cbi (TCCR2B ,WGM22);
  OCR2A = 124;                  // CTC at top of OCR2A / timer2 interrupt when coun value reaches OCR2A value
  // interrupt control
  sbi (TIMSK2,OCIE2A);          // enable Timer2 Interrupt
volatile byte i_tics;
volatile byte f_ready ;
volatile byte mlt ;
unsigned int ww;
int cal;
int cal_max;
char st1[32];
long freq_in;
long freq_zero;
long freq_cal;
unsigned int dds;
int tune;
int cnt=0;
  cnt++;
  f_meter_start();
  tune=tune+1;
  while (f_ready==0) {            // wait for period length end (100ms) by interrupt
    digitalWrite(8, (dds+=tune) >> 15);    // kind of DDS tonegenerator / connect speaker to portb.0 = arduino pin8
  tune = freq_in-freq_zero;
  Serial.println(tune);
  // Initialisation
  if (cnt == 10) {
    freq_zero=freq_in;
    freq_cal=freq_in;
    cal_max=0;
    Serial.print("INITIALISATION");
  // calibration
  if (tune>0) {   // try autocalibrate when out of range
    freq_zero=freq_in;
    freq_cal=freq_in;
    cal_max=0;
    Serial.print("CALIBRATION");
    Serial.println("");
  cal = freq_in-freq_cal;
  if ( cal < 0) cal*=-1;  // absolute value
  if (cal > cal_max) cal_max=cal;
  //  digitalWrite(pinLed,1);  // let LED blink
  if ( tune < 0) tune*=-1;  // absolute value
  //  sprintf(st1, " %04d",tune);
  //  digitalWrite(pinLed,0);
  // see if there's incoming serial data:
  if (Serial.available() > 0) {
    //    while (Serial.available() > 0)
    incomingByte = Serial.read();
  digitalWrite(pinLed, incomingByte);
void f_meter_start() {
  f_ready=0;                      // reset period measure flag
  i_tics=0;                        // reset interrupt counter
  sbi (GTCCR,PSRASY);              // reset presacler counting
  TCNT2=0;                         // timer2=0
  TCNT1=0;                         // Counter1 = 0
  cbi (TIMSK0,TOIE0);              // dissable Timer0 again // millis and delay
  TCCR1B = TCCR1B | 7;             //  Counter Clock source = pin T1 , start counting now
// Timer2 Interrupt Service is invoked by hardware Timer2 every 2ms = 500 Hz
//  16Mhz / 256 / 125 / 500 Hz
// here the gatetime generation for freq. measurement takes place:
ISR(TIMER2_COMPA_vect) {
  if (i_tics==50) {         // multiple 2ms = gate time = 100 ms
    // end of gate time, measurement ready
    TCCR1B = TCCR1B & ~7;   // Gate Off  / Counter T1 stopped
    cbi (TIMSK2,OCIE2A);    // disable Timer2 Interrupt
    sbi (TIMSK0,TOIE0);     // ensable Timer0 again // millis and delay
    f_ready=1;              // set global flag for end count period
    // calculate now frequeny value
    freq_in=0x10000 * mlt;  // mukt #ovverflows by 65636
    freq_in += TCNT1;       // add counter1 value
    mlt=0;
  i_tics++;                 // count number of interrupt events
  if (TIFR1 & 1) {          // if Timer/Counter 1 overflow flag
    mlt++;                  // count number of Counter1 overflows
    sbi(TIFR1,TOV1);        // clear Timer/Counter 1 overflow flag
