Topic: key pressing (Read 848 times) previous topic - next topic
thevital
hi ,
i want to know if i can make this thing
is there a code , when i press the key (from keyboard) it change the  INPUT PULLUP to high , when i release the key it change it to low ?
:smiley-sweat:
MikMo
thevital
is there any way to control the arduino chip from the pc by using keyboard?
PeterH
Yes, but it needs software on the PC as well as software on the Arduino, to do it.
I only provide help via the forum - please do not contact me for private consultancy.
PaulS
Quote
Why do you want to be turning the pullup resistor on or off? Toggling an output pin makes sense. Turning the pullup resistor on or off does not.
dc42
Use the Serial Monitor in the Arduino IDE to send commands to the Arduino, and the Arduino serial port to receive them. Then you can write a sketch to do whatever you want on the Arduino in response to the commands received.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
