Topic: Just wanted to share my 32 x 8 LED Matrix (Read 5322 times) previous topic - next topic
Aaron_dyer
so...4 max7219's,  4    8x8 martrices,   4    100 uF caps,  4      0.1 uF caps and 4    27 K ohm resistors later...
http://www.youtube.com/watch?v=h1tyXEDhfDM
Aaron_dyer
Oh yes and my arduino Nano.....
code is attached too...
find the max7219 playground schematic and have a good pinout for the matrix before you start connecting them...know the rows and columns...
Riva
Is it meant to have that pixel column effect on each 8x8 matrix as it scrolls?
Other than that it looks good.
fungus
It looks like the columns are off by one. A little software tweak should fix that, no problem...
Yep. Nicely laid out and plenty of capacitors!
PS: You could maybe put the resistors all facing the same way though... :)
Aaron_dyer
Ya I noticed the column effect....to me, its good to go..i have worked on this thing forever....One of these days, I want to make the 64 x 8 matrix...easy enough..just cascade more max7219s....just gotta get a large enough PCB
Aaron_dyer
Hey Fungus,
You mention a little software tweak can fix the effect......can you check out my code in a thread above and show me maybe where it can fix it please?
Riva
I have altered a version of a scroll program you did try that was hard coded for just 2x matrix displays so it will scroll on 4 displays but don't have hardware to test it on. Fancy giving it a try and letting me know if it works? I have attached it in case you do.
Aaron_dyer
Just uploaded it.....no difference in this compared to the video I posted....
Riva
Hmm, if it's scrolling across all 4 matrix displays now instead of just the two it did before and it still looks the same as the version in your video then maybe the matrix is not wired quite right. Can you slow down the scroll speed using either sketch (mine you increase 'const long scrollDelay = 70;') and video it again.
Aaron_dyer
Yes, the delay lets it slow down......and I'm beginning to think you're right about the matrices not being wired quite right....I bought them on ebay...they have   XH-1088BRW   on the side of them....
This is what I have for reference but I'll look better for a good datasheet..
The picture is attached....
Riva
#10
Dec 12, 2012, 07:17 pm Last Edit: Dec 12, 2012, 07:21 pm by Riva Reason: 1
I cannot find a datasheet for the matrix, maybe going back to the ebay seller and see if they have a picture on the website.
EDIT:
I have found a picture here http://www.ebay.co.uk/itm/16-LED-Dot-Matrix-Display-3mm-8x8-Red-Common-Anode-16pin-64-LED-Displays-module-/150963896624?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item2326264130
Aaron_dyer
I am making a new layout by manually checking the rows and columns using a power suply to see them illuminate.....
I'l update you soon..I already found  R6 / C6 and  R2 / C2 to be swapped.....
Riva
Comparing your picture to the ebay drawing your rows look fine but columns are a bit mixed. I have put your pinout in last column. Best bet is to buzz the matrix out as your doing to be sure.
PIN  R/C  Your Picture
01 = R5    r5
02 = R7    r7
03 = C2    c7
04 = C3    c6
05 = R8    r8
06 = C5    c4
07 = R6    r6
08 = R3    r3
09 = R1    r1
10 = C4    c5
11 = C6    c3
12 = R4    r4
13 = C1    c8
14 = R2    r2
15 = C7    c2
16 = C8    c1
Aaron_dyer
Thanks for that....Nice find...I'll do some switching around soonish and update the forum...
Aaron_dyer
Riva,
so I built just a small quick 8 x 8 with a max7219 using my Uno using the pinout you found....
didn't go so well.....the letters scrolled but were upside down and backwards.....
thats what I hate about these matrices ..they can go in anyway and especially with how the code is written can make them flip all over the place.....Oh well it works good enough for me
