Loading...
Pages: [1]   Go Down
Author Topic: Question: What is a bootloader?  (Read 276 times)
Offline Offline
Jr. Member
View Profile
I apologize for my probably dumb question but what exactly is a bootloader?
Could you please explain everything that had to do with it and the arduino?
ie what's the purpose of a bootloader,how does it work etc
If you could link me another thread/topic i would be more than pleased to study it
Thanks in advance
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
http://arduino.cc/en/Hacking/Bootloader?from=Main.Bootloader
Logged
Boston Suburbs
Offline Offline
God Member
I am above your silly so-called "Laws", Mister Ohm.
View Profile
WWW
It's very simple really.  A bootloader is a small program that runs and sets things up before your main program runs.
In Arduino, one of it's main functions is to see if there is any commands at the serial port, like a request to rewrite the main program coming from the computer.
If you program the chip directly using ICSP, you don't need to have a bootloader, which frees up a little space and removes the short delay when your Arduino is reset... That delay is the bootloader program waiting and checking the serial port for commands.
« Last Edit: December 12, 2012, 02:27:53 pm by focalist » Logged
When the testing is complete there will be... cake.
Offline Offline
Jr. Member
View Profile
After reading the thing i got some more questions:
1)Is the bootloader loaded on the main chip's flash or EEPROM?
2)What are fuses (something bootloader related)?
3)What is the use of the second Atmel chip on the board?
4)What are the 6 pins labeled AREF on the UNO R3?
5)Can i program the main chip via its pins instead of using the ICSP pins?
6)Does the arduino C compiler, compile the source code into the Atmel's machine language?
Again thaank you people smiley
« Last Edit: December 12, 2012, 02:53:16 pm by Voidugu » Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Flash, placed at the very end of it's memory space. Any user's sketch will fill from start of flash up to beginning of bootloader program.
They are 'firmware' switches internal to the chip that enable or disable various chip features.
It's a small microcontroller chip preprogrammed to act as a USB serial interface to allow communications
between the PC and the other AVR chip on the board. This serial link is used to upload user sketches to the AVR chip or for simple serial communications to the IDE's serial monitor or any PC based application that can use PC comm ports.
There is only one shield pin named AREF on a arduino board. The six male pins next to the AREF label is for allowing for ISCP programming of the USB serial converter chip if it ever loses it's program or if one wishes to repurpose the chip function, say as to act as a USB host chip to read a keyboard or a mouse.
The main chip can be programmed by the arduino IDE via the USB serial link using the bootloader on the main chip. Or the main chip can be programmed using a hardware programmer via it's ICSP pins. Using the serial link and bootloader is the more normal way most program their arduino boards.
Yes, the gcc C++ compiler/linker sends the final code, called object code and is comprised of only AVR instructions and user constant data.
Your welcome
Lefty
Logged
Offline Offline
Newbie
View Profile
If i recall correctly, one of the fuses(or type of fuses.) is an internal oscilator, which eliminates the need to solder/attach a 16 mhz crystal oscilator to your circuit if you were to use an atmega chip out of your arduino board(like,in a breadboard) you could use the fuse for the internal oscilator to further minimize your circuit.
This information is not relevant if you use your atmega chip inside your arduino itself i believe,since this board has an oscilator on it, it's just for when you want to make multiple copies of your arduino,minimize the space it uses and while doing this,eliminate the need for the oscilator which saves on money.
Logged
Pages: [1]   Go Up
Print
Jump to:
