Topic: Help with Programming Arduino Uno to sleep and wakeup with FSR sensor (Read 8908 times) previous topic - next topic
Jack Christensen
#15
Dec 15, 2012, 11:57 pm Last Edit: Dec 16, 2012, 12:02 am by Jack Christensen Reason: 1
Thanks, Jack. I'm not totally surprised. If the voltage from the FSR when not pressed is quite high (eg. 4V) and when pressed is quite low (eg. 2V) then that effectively could be treated as a digital signal, because the digital inputs would have a "transition" zone (around 2.5V) where above that is considered high, and below is considered low.
Indeed, I've measured it, and I think the FSR is darn near an open circuit with no load (weight) on it, so I'd bet the pin is very close to Vcc (the project actually runs on 2xAA alkaline cells). Since the FSR actuations in my project are quite slow, I did use a fairly long debounce interval on it (100ms vs. 20 or 25 for the buttons), but I'm not sure that is really of any consequence. Just one of those serendipitous things, it still makes me smile :D
I used this FSR from Sparkfun if that makes a difference to anyone:
https://www.sparkfun.com/products/9376
zajebiscie
Thanks for your help. I have one more question , how do i test to see if the arduino is at sleep or not. ?
PeterH
Do you mean how can your code test whether the Arduino it runs on is asleep or not? The answer is that it is awake.
I only provide help via the forum - please do not contact me for private consultancy.
Jack Christensen
You're welcome! I just used an ammeter to monitor the current drawn by the circuit.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
