Topic: PROBLEM TO UPLOAD ARDUINO mega 256 (Read 802 times) previous topic - next topic
SERET
Helo again.
I have VISTA 32. With arduino erw 1.0.2 i try upload a sketch on board ( arduino mega 2560 ) with usb.      I failed !!!!!!!.
I  took  the hex and i upload it on board with a programmer  ( stk 500 )  on chip mega 2560  with isp.       It is ok!!!!!!!!.
I can see the arduino board on com 14  with usb. But i cant  do upload .
  Please some one help  me !!!!!!!
pico
WiFi shields/Yun too expensive? Embeddedcoolness.com is now selling the RFXduino nRF24L01+ <-> TCP/IP Linux gateway: Simpler, more affordable, and even more powerful wireless Internet connectivity for *all* your Arduino projects! (nRF24L01+ shield and dev board kits available too.)
SurferTim
Quote
If you have any of those like that in your code (group of three !!!), that has been known to stop a code upload.
pico
That issue is supposed to have been addressed in latest version of the mega2560 bootloader.
The problem he is having is that the version of avrdude he using (5.10) doesn't understand what the "wiring" protocol is.
SurferTim
Quote
I wonder why mine works? I'm using  a Mega with v1.0.2.
Test the bootloader.
Code: [Select]
  Serial.println("It works!!!");
Can you upload that code?
hiduino
When you upload a sketch via isp then it will overwrite the bootloader.  You probably have no bootloader on the mega 2560.  You will need to put back the bootloader.
SERET
Thanks all of you.
I replace the bootloader on  secont chip 2560 via isp. Now it is ok.  There was:
  ( C:\Program Files\Arduino\Arduino ERW 1.0.3\hardware\arduino\bootloaders\stk500v2  )
