Topic: Computer program to set RTC to system time. (Read 16813 times) previous topic - next topic
point5
I have been wondering if a computer program or sketch exists to make syncing an I2C RTC with the computer system time easy and precise?  At the moment I either use
Code: [Select]
RTC.adjust(DateTime(__DATE__, __TIME__)
which is great but always out by the time it takes to compile etc.... or trying to set the time to account for these delays which is a bit hit and miss - but obviously not ideal.
I'm guessing that this nut has already been cracked so wondering if anyone can point me in the right direction - the RTC I am using is the great DS3231 but suspect code for other I2C RTCs wouldn't be too bad to recycle?
Thanks for any thoughts.
retrolefty
#1
Dec 12, 2012, 10:35 pm Last Edit: Dec 12, 2012, 10:39 pm by retrolefty Reason: 1
Here is the method I use to set my RTC, it's primitive for sure but simple and effective. I update the fixed values in the setup function for a time ahead maybe 3 mins. Then I upload the sketch to the board. Note that it waits for any character to be sent from the serial monitor before actually preceeding to set the RTC. Then I call up one of the many time reference web sites that have a running time clock being displayed. So when the web site time matches the time I preset into the sketch I hit a character on the serial monitor and the time gets updated in the RTC and the main loop just keeps printing the time data after that. So nothing fancy but I like being "part of the loop".  :D
Lefty
Note that this was written using IDE ver22 and might need tweaking for IDE 1.x ?
Code: [Select]
/*Reads the value from a Real Time Clock (RTC) DS1307 and displays it in the serial monitor
*Created by D. Sjunnesson 1scale1.com d.sjunnesson (at) 1scale1.com
*Created with combined information from
*http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1180908809
*http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1191209057
*Big credit to  mattt (please contact me for a more correct name...) from the Arduino forum
*which has written the main part of the library which I have modified
#include <WProgram.h>
#include <Wire.h>
#include <DS1307.h> // written by  mattt on the Arduino forum and modified by D. Sjunnesson
 Serial.begin(57600);
 Serial.println ("Hit a key to start");     // signal initalization done
 while(Serial.available() == 0){}
                             // Hit upload about 10 seconds before selected time
 RTC.stop();
 RTC.set(DS1307_SEC,0);        //set the seconds
 RTC.set(DS1307_MIN,28);       //set the minutes
 RTC.set(DS1307_HR,23);        //set the hours   note 24 hour clock
 RTC.set(DS1307_DOW,5);        //set the day of the week
 RTC.set(DS1307_DATE,13);      //set the date
 RTC.set(DS1307_MTH,1);        //set the month
 RTC.set(DS1307_YR,11);         //set the year
 RTC.start();
 Serial.print(RTC.get(DS1307_HR,true)); //read the hour and also update all the values by pushing in true
 Serial.print(":");
 Serial.print(RTC.get(DS1307_MIN,false));//read minutes without update (false)
 Serial.print(":");
 Serial.print(RTC.get(DS1307_SEC,false));//read seconds
 Serial.print("      ");                 // some space for a more happy life
 Serial.print(RTC.get(DS1307_DATE,false));//read date
 Serial.print("/");
 Serial.print(RTC.get(DS1307_MTH,false));//read month
 Serial.print("/");
 Serial.print(RTC.get(DS1307_YR,false)); //read year
rbright
The Compile Time Error seems to be close to consistant for any particular PC so why could one not adjust the delayed time then add a correction factor - something like seconds = seconds + xxx then see how that goes? Don't know enought to write the code myself which may be obvious from my suggestion above.
Alternatively to get arround this I've used this VB / Arduino application to preload real time, that is real time until it drifts over time.
http://combustory.com/wiki/index.php/RTC1307_-_Real_Time_Clock#Examples
Cheers
cyclegadget
I have been looking for examples just like those above! I am glad you guys posted this!
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
point5
Hi, Yes - thanks for the input :-)  I have since found an example of some nice code to do this via the serial window - I wasn't sure if I could post it here to start with but have since found it in the public domain so I guess its OK.
It is written for the DS3231 RTC but could be adapted for the DS1307 - the trick is that it is written for WaspMote which is Arduino-esq but needs a bit of translating as they have their own bespoke functions like USB.print which is Serial.print - I made a start but soon ran out of ability.... take a look here if you are interested - you basically use the serial window to predefine a time and date which is stored until a set command is sent to serial which sets the time specified in an instant.... so pretty accurate.
http://www.libelium.com/development/waspmote/example024
AleshMahajan
how to get wprogram.h and ds1307.h libraries
PaulS
Quote
Install version 0023 of the Arduino IDE (or earlier). If you have a later version, change WProgram.h to Arduino.h.
Quote
By mail order, from the dark side of the moon. Shipping might take a while.
While you wait, you could try google.
