Topic: can i kreate 2 Khz -1/1 V signal some how with an arduino ? (Read 868 times) previous topic - next topic
kourpetis
i have an Arduino mega and i want to create 2 Khz -1/1 v sine waves !
can i do it ? and how ?
thank you very much !
retrolefty
Not directly as AVR chips only use ground and positive Vcc voltages, so not possible to create a negative output voltage directly. And as it has no true analog output functions it cannot even generate a +1vdc output directly. External components and/or modules would be required.
I would look for a bipolar DAC module that uses I2C or SPI communications to work with the arduino. Possibly something like this:
http://www.maximintegrated.com/datasheet/index.mvp/id/4241?utm_expid=50713806-2&utm_referrer=http%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26rct%3Dj%26q%3Dbipolar%2520dac%26source%3Dweb%26cd%3D3%26sqi%3D2%26ved%3D0CEsQFjAC%26url%3Dhttp%253A%252F%252Fwww.maximintegrated.com%252Fdatasheet%252Findex.mvp%252Fid%252F4241%26ei%3DcZ_MULjxN-nj2QWcu4DwBg%26usg%3DAFQjCNHkhHxZOaZ5F7zprRW7fWm8rJILRQ
Lefty
dhenry
Quote
can i do it ?
Yes.
Quote
and how ?
1) run the mcu at 2v, generate a 0-2v pulse and put a capacitor on the output. On the other side of the capacitor,  you have a -1 / +1 Vpp pulse;
2) if you have to run the mcu at a higher value, you can use a 2v zener / led to limit its swing down to 2v.
Grumpy_Mike
Please grow up dhenry you are lowering the standards of the whole forum:-
Quote
run the mcu at 2v,
Except you can't.
Quote
The guy is asking for a sin wave output -
Quote
For a Sin wave?
questions are always easy to answer if you don't read the question.
Nick Gammon
@henry: Please be serious. You can't run the Arduino Mega at 2V, because it has a 16 MHz crystal or resonator. Plus you could hardly do that without an external power supply, as the USB in, and regulated voltage in, run at 5V.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
