Hello fellow Arduino users.
I`m kinda new to C++ programming, but quite interested in this programming language.
Normally I use PLC in my work, so this is something new for me.
The thing I wanna do with my program is to control the direction of 2 ea Parallax continuos servos, using two pot meters.
I want tor be able to:
-1. Start, and run both servos in opposite direction using the joystick intput-value from 600-1024
-2. Stop the servos when the joystick is in the mid-position (input value fluctuates 520-530)
-3. Start, and run both servos in inverted direction relative to statement "1" using the joystick intput-value from 0-400
The problem I run into is when using "if" functionality.. I cannot get the servos to run as desired.
#include <Servo.h> //intialize servoSUBprogram
Servo servoX; // Create Servo object to control the servo
Servo servoY; // Create Servo object to control the servo
int X = A0; //map variabel x to A0
int Y = A1; //map variabel y to A1
int pos = 650; //variable
int neg = 350; //variable
int mid = (450,550); //variable
void setup(){
Serial.begin(9600); //initialize serial com
void loop(){
int X = analogRead(A0); //reads the value of the potentiometer (value between 0 and 1023)
int Y = analogRead(A1); //reads the value of the potentiometer (value between 0 and 1023)
servoX.attach(7); // Servo is connected to digital pin 7
servoY.attach(8); // Servo is connected to digital pin 8
Serial.print("pot X"); // unique header to identify start of message
Serial.print(","); // comma to differenciate
Serial.print( X ,DEC); // print variable in DEC
Serial.print(" "); // space
Serial.print("pot Y"); // unique header to identify start of message
Serial.print( Y ,DEC); // print variable in DEC
Serial.print(","); // note that a comma is sent after the last field
Serial.println(); // send a cr/lf
delay(1); // wait ms
if (Y>pos){
servoX.writeMicroseconds(1300); // servo direction
servoY.writeMicroseconds(1700); // opposite direction
if (Y<neg){
servoX.writeMicroseconds(1700); // servo direction
servoY.writeMicroseconds(1300); // opposite direction
if (Y=mid){
servoX.writeMicroseconds(1500); // servo stop
servoY.writeMicroseconds(1500); // servo stop
