Offline
Newbie
« on: December 13, 2012, 08:12:18 am » |
Hello, I created the following code by copy pasting... But i get an error message and i cannot find out why or how... This is the code //serial input
char incomingByte; char FileName;
void setup() { Serial.begin(115200); }
void loop() { // see if there's incoming serial data: if (Serial.available() > 0) { // read the oldest byte in the serial buffer: incomingByte = Serial.read(); // if it starts with IMG then set it as FileName if (incomingByte.startsWith("IMG")) { Serial.println("File Read"); FileName=incomingByte; } } delay(1000); } I want if the serial string starts with IMG that FileName is set to the serial input.
Logged
Global Moderator
UK
Offline
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #1 on: December 13, 2012, 08:17:39 am » |
A single char is just that - it couldn't possibly be "IMG". Did you mean String instead? I created the following code by copy pasting... Where from? But i get an error message But you didn't think you wanted to share it with us?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Pittsburgh, PA, USA
Offline
Faraday Member
I only know some basic electricity....
« Reply #2 on: December 13, 2012, 08:23:31 am » |
So you read one byte then check to see if the 1st 3 bytes of that == "IMG".....
why, whatever could be the problem??
How about doing something crazy like get the whole message before checking and possibly saving it?
Logged
Examples can be found at Learning in the Main Site and at the Playground
Offline
Newbie
« Reply #3 on: December 13, 2012, 08:30:39 am » |
@ Awol from different sites...
error is sketch_dec13a:16: error: request for member 'startsWith' in 'incomingByte', which is of non-class type 'char'
@GoForSmoke ( haha i had smoke yesterday when connecting it wrong )
ok so i need to read the whole string or what is the correct name for it..? but how do i get he whole message? back to google again...
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #4 on: December 13, 2012, 08:47:49 am » |
There are examples included in the IDE.
Logged
Manchester (England England)
Offline
Brattain Member
Solder is electric glue
« Reply #5 on: December 13, 2012, 09:03:06 am » |
@rogierv Have you ever thought your post sounds like:-
" i just got two bottles of medicine from the pharmacy and mixed them together. Now I feel ill, what is the problem"
AWO - Where did you get them from.
You " from different pharmacys "
If you want help you have to provide information to allow us to help you.
Logged
Offline
Newbie
« Reply #6 on: December 13, 2012, 10:51:22 am » |
I understand but i took the text startswith from one site some serial code from another and some pieces of an example and some from arduino pages. but the code is no at all one a site i made it myself so i dont think the site makes any sense...
but like all ways most people speak here about the mistakes you make in the posting and not about the mistakes you make in the code
i go on trying examples and find it out myself
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #7 on: December 13, 2012, 10:56:35 am » |
but like all ways most people speak here about the mistakes you make in the posting and not about the mistakes you make in the code I'm not sure I understand what you're saying here. have you worked through any of the examples provided with the IDE?
Logged
France
Offline
God Member
Scientia potentia est.
« Reply #8 on: December 13, 2012, 10:57:51 am » |
Hello, little example here, this is non blocking Serial.read's, what you type in serial monitor is stored in the char array 'input', that you can use for whatever you want, here strncmp, comparing the first 3 letters of the input. The line ending character setting (in the serial monitor) must be set to Carriage return. void loop() { if ( Serial.available() > 0 ) { static char input[64]; static uint8_t i; char c = Serial.read();
if ( c != '\r' && i < 64-1) input[i++] = c;
else { input[i] = '\0'; i = 0; if ( !strncmp( input, "IMG", 3 ) ) { Serial.println("File Read"); } } } }
Good luck
« Last Edit: December 13, 2012, 11:01:42 am by guix »
Logged
Pittsburgh, PA, USA
Offline
Faraday Member
« Reply #9 on: December 13, 2012, 03:28:41 pm » |
That guix code is better for Arduino than examples that use C++ Strings. There are too many of those on the official site... do I hear an Amen out there?
Rogierv, Serial data is slow as snails compared to Arduino which may loop 100's of times waiting between characters to arrive. You are writing real time code with no operating system dragging the feet. It is a matter of understanding the scale (1 character at a time, usable processor speed **enormously faster** than characters arrive) and modeling how the information should flow on that scale.
Me personally, I compare the characters each as they come in and have time to check many alternatives (If I have many) when a single character does not match and still empty cycles through loop() before the next at 115200 baud. But I think best you practice what guix gave until you have a better overview or strong need to save ram space.
Logged
UK
Offline
Tesla Member
« Reply #10 on: December 13, 2012, 03:36:21 pm » |
The reason is that when you ask a question poorly, it is much harder - sometimes even impossible - to answer. The sticky "Read this before posting a programming question" does have quite a lot of helpful advice about how to ask a question well. Is it fair to say you didn't read this before posting a programming question?
« Last Edit: December 13, 2012, 04:27:26 pm by PeterH »
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #11 on: December 13, 2012, 03:41:19 pm » |
Simple test code that captures a string and checks the contents of that string for a substring that will turn the arduino board LED on and off. // zoomkat 8-6-10 serial I/O string test // type a string in serial monitor. then send or enter // for IDE 0019 and later
int ledPin = 13; String readString;
void setup() { Serial.begin(9600); pinMode(ledPin, OUTPUT); Serial.println("serial on/off test 0021"); // so I can keep track }
while (Serial.available()) { delay(10); char c = Serial.read(); readString += c; }
if (readString.length() >0) { Serial.println(readString);
if(readString.indexOf("on") >=0) { digitalWrite(ledPin, HIGH); }
if(readString.indexOf("off") >=0) { digitalWrite(ledPin, LOW); }
readString=""; } }
Logged
