Loading...
Pages: [1]   Go Down
Author Topic: Problem with error message  (Read 284 times)
Offline Offline
Newbie
View Profile
Me and my friend don't know how to fix this error, or why it's accouring.
Our code looks like this:
const int buttonPin = 2;
const int hl = 3;
int buttonState = 0;
pinMode(hl, OUTPUT);
pinMode(buttonPin, INPUT);
void loop(){
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(hl, LOW);
else {
// turn LED off:
digitalWrite(hl, HIGH);
digitalWrite(hl, low)
delay(1000)
When we try to verify it, we get the error:
Button:57: error: expected unqualified-id before '{' token
Please tell us how to fix the problem!!
Logged
France
Offline Offline
God Member
Scientia potentia est.
View Profile
Hello and welcome smiley
You have few problems on the last lines:
- First you forgot some ';'
- Then if you check the count of '{' and '}' (and if you indented your code correctly) then you will see the last lines are outside of void loop().
Here is your code, exactly the same but correctly indented:
Code:
const int hl = 3;
    // turn LED on:
    // turn LED off:
  delay(1000)
See the problem(s) ??
« Last Edit: December 13, 2012, 09:52:43 am by guix » Logged
Offline Offline
Newbie
View Profile
Hi, thanks for the help, we tried to look at it again, but the error is still not fixed, maybe I don't really get what the error is. It comes with the same error when we try to put the '{' other places.
Please help.
Logged
Offline Offline
Newbie
View Profile
Me and my friend don't know how to fix this error, or why it's accouring (we have very little experience with programming).
const int hl = 3;
void loop(){
// turn LED on:
else {
// turn LED off:
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
You must have an equal number of braces both { and }.
The braces must enclose blocks of code.
The braces in that code are all over the place.
Logged
Online Online
Brattain Member
View Profile
WWW
I imagine that this is what you want, but I am not sure.
Code:
const int hl = 3;
void loop(){
// turn LED on:
else {
// turn LED off:
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
First, if you post please use the # button to tag code correctly
Give this a try, I removed a { and added an extra delay(200) , .. (code not tested)
Code:
const int hl = 3;
  delay(200);  // extra
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
East Anglia (UK)
Offline Offline
Edison Member
May all of your blinks be without delay
View Profile
Problem 1 - all the statements should end with a semi-colon like this
Code:
Are there any lines in your sketch that don't ?
Problem 2 - when, if ever, is this code going to be executed ?
Code:
  delay(1000)
Logged
Offline Offline
Newbie
View Profile
Code:
const int hl = 3;
Hi, it worked, thanks, but why did you make an extra delay, and why did it work???
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Please don't cross post. Threads merged.
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
That is your homework:)
Follow the code by hand, read it carefully line by line.
Be the Arduino !
and do what the code says and you will understand.
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
Quote
Be the Arduino !
Well, ok, thank you! smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
