Author Topic: Problem with error message  (Read 275 times)
Me and my friend don't know how to fix this error, or why it's accouring.
Our code looks like this:
const int buttonPin = 2;
const int hl = 3;
int buttonState = 0;
pinMode(hl, OUTPUT);
pinMode(buttonPin, INPUT);
void loop(){
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(hl, LOW);
else {
// turn LED off:
digitalWrite(hl, HIGH);
digitalWrite(hl, low)
delay(1000)
When we try to verify it, we get the error:
Button:57: error: expected unqualified-id before '{' token
Please tell us how to fix the problem!!
France
Scientia potentia est.
Hello and welcome smiley
You have few problems on the last lines:
- First you forgot some ';'
- Then if you check the count of '{' and '}' (and if you indented your code correctly) then you will see the last lines are outside of void loop().
Here is your code, exactly the same but correctly indented:
const int hl = 3;
    // turn LED on:
    // turn LED off:
  delay(1000)
See the problem(s) ??
« Last Edit: December 13, 2012, 09:52:43 am by guix » Logged
Hi, thanks for the help, we tried to look at it again, but the error is still not fixed, maybe I don't really get what the error is. It comes with the same error when we try to put the '{' other places.
Please help.
Me and my friend don't know how to fix this error, or why it's accouring (we have very little experience with programming).
const int hl = 3;
void loop(){
// turn LED on:
else {
// turn LED off:
Manchester (England England)
Solder is electric glue
You must have an equal number of braces both { and }.
The braces must enclose blocks of code.
The braces in that code are all over the place.
I imagine that this is what you want, but I am not sure.
const int hl = 3;
void loop(){
// turn LED on:
else {
// turn LED off:
Netherlands
First, if you post please use the # button to tag code correctly
Give this a try, I removed a { and added an extra delay(200) , .. (code not tested)
const int hl = 3;
  delay(200);  // extra
Rob Tillaart
East Anglia (UK)
May all of your blinks be without delay
Problem 1 - all the statements should end with a semi-colon like this
Are there any lines in your sketch that don't ?
Problem 2 - when, if ever, is this code going to be executed ?
  delay(1000)
const int hl = 3;
Hi, it worked, thanks, but why did you make an extra delay, and why did it work???
Melbourne, Australia
Shannon Member
Lua rocks!
Please don't cross post. Threads merged.
Netherlands
That is your homework:)
Follow the code by hand, read it carefully line by line.
Be the Arduino !
and do what the code says and you will understand.
Rob Tillaart
Be the Arduino !
Well, ok, thank you! smiley
