Topic: 7-Seg 4 Digit Display code for ICM7211 (Read 1 time) previous topic - next topic
vogel1230
Dec 13, 2012, 04:19 pm Last Edit: Dec 13, 2012, 05:28 pm by vogel1230 Reason: 1
I looked around for a while trying to find some code for a ICM7211 display driver and didn't see anything so I've posted one below in case someone is looking for the same. The pins on this were used on a 644P chip so just change for Arduino variant you're using.
Code: [Select]
/* Author: Richard Vogel                               */
/* Date: 12/12/12                                      */
/* Description: Simple sketch to utilize a ICM7211AM   */
/* 7-segment 4-digit display driver with Arduino.      */
/* Example display for use with this sketch would be   */
/* Varitronix PN: VI-402-DP-FC-S                       */
/* Digi-Key PN: 153-1103-ND  //as of 12/12/12          */
const int d0 = 28;
const int d1 = 29;
const int d2 = 30;
const int d3 = 31;
const int dS1 = 13;
const int dS2 = 14;
const int cS1 = 2;
const int cS2 = 3;
/*This example is to display a temp to tenth of degree precision.
Decimal point connection has to go directly to diplay. Same goes for if
you want to use the colon on the display for a clock feature. The
ICM7211 does not output these lines.*/
const int dP = 4;
int tNow[4]={10,3,5,6};   // current temperature   (-35.6)
boolean on = 1;
boolean off = 0;
boolean lcdNum[16][4]=
 {off,off,off,off}, // 0
 {off,off,off,on},  // 1
 {off,off,on,off},  // 2
 {off,off,on,on},   // 3
 {off,on,off,off},  // 4
 {off,on,off,on},   // 5
 {off,on,on,off},   // 6
 {off,on,on,on},    // 7
 {on,off,off,off},  // 8
 {on,off,off,on},   // 9
 {on,off,on,off},   // -      //array pos 10
 {on,off,on,on},    // E      //array pos 11
 {on,on,off,off},   // H      //array pos 12
 {on,on,off,on},    // L      //array pos 13
 {on,on,on,off},    // P      //array pos 14
 {on,on,on,on}      // Blank  //array pos 15
 pinMode(d0, OUTPUT);
 pinMode(d1, OUTPUT);
 pinMode(d2, OUTPUT);
 pinMode(d3, OUTPUT);
 pinMode(dS1, OUTPUT);
 pinMode(dS2, OUTPUT);
 pinMode(cS1, OUTPUT);
 pinMode(cS2, OUTPUT);
 pinMode(dP, OUTPUT);
 digitalWrite(d0, LOW);
 digitalWrite(d1, LOW);
 digitalWrite(d2, LOW);
 digitalWrite(d3, LOW);
 digitalWrite(dS1, HIGH);
 digitalWrite(dS2, HIGH);
 digitalWrite(cS1, LOW);
 digitalWrite(cS2, HIGH);
 digitalWrite(dpColon, HIGH);
 for (int x = 0; x < 16; x++)
   disD1(lcdNum[x][0], lcdNum[x][1], lcdNum[x][2], lcdNum[x][3]);
   disD2(lcdNum[x][0], lcdNum[x][1], lcdNum[x][2], lcdNum[x][3]);
   disD3(lcdNum[x][0], lcdNum[x][1], lcdNum[x][2], lcdNum[x][3]);
   disD4(lcdNum[x][0], lcdNum[x][1], lcdNum[x][2], lcdNum[x][3]);
   bootUpDisplay();
   clearMemDisplay();
   helpDisplay();
   blankDisplay();
   displayTemp(tNow[0], tNow[1], tNow[2], tNow[3]);
void disD1(boolean a, boolean b, boolean c, boolean d)
 digitalWrite(d3, a);
 digitalWrite(d2, b);
 digitalWrite(d1, c);
 digitalWrite(d0, d);
 digitalWrite(dS1, LOW);
 digitalWrite(dS2, LOW);
 delay(2);
 digitalWrite(cS2, LOW);
 delay(2);
void disD2(boolean a, boolean b, boolean c, boolean d)
 delay(2);
 delay(2);
void disD3(boolean a, boolean b, boolean c, boolean d)
 delay(2);
 delay(2);
void disD4(boolean a, boolean b, boolean c, boolean d)
 delay(2);
 delay(2);
void bootUpDisplay() //"E1E1"
 disD1(lcdNum[11][0], lcdNum[11][1], lcdNum[11][2], lcdNum[11][3]);
 disD2(lcdNum[1][0], lcdNum[1][1], lcdNum[1][2], lcdNum[1][3]);
 disD3(lcdNum[11][0], lcdNum[11][1], lcdNum[11][2], lcdNum[11][3]);
 disD4(lcdNum[1][0], lcdNum[1][1], lcdNum[1][2], lcdNum[1][3]);
void clearMemDisplay() //"E2E2"
 disD2(lcdNum[2][0], lcdNum[2][1], lcdNum[2][2], lcdNum[2][3]);
 disD4(lcdNum[2][0], lcdNum[2][1], lcdNum[2][2], lcdNum[2][3]);
void helpDisplay() //"HELP"
 disD1(lcdNum[12][0], lcdNum[12][1], lcdNum[12][2], lcdNum[12][3]);
 disD2(lcdNum[11][0], lcdNum[11][1], lcdNum[11][2], lcdNum[11][3]);
 disD3(lcdNum[13][0], lcdNum[13][1], lcdNum[13][2], lcdNum[13][3]);
 disD4(lcdNum[14][0], lcdNum[14][1], lcdNum[14][2], lcdNum[14][3]);
void blankDisplay() // "  "
 disD1(lcdNum[15][0], lcdNum[15][1], lcdNum[15][2], lcdNum[15][3]);
 disD2(lcdNum[15][0], lcdNum[15][1], lcdNum[15][2], lcdNum[15][3]);
 disD3(lcdNum[15][0], lcdNum[15][1], lcdNum[15][2], lcdNum[15][3]);
 disD4(lcdNum[15][0], lcdNum[15][1], lcdNum[15][2], lcdNum[15][3]);
void displayTemp(int t4, int t3, int t2, int t1)
 disD1(lcdNum[t4][0], lcdNum[t4][1], lcdNum[t4][2], lcdNum[t4][3]);
 disD2(lcdNum[t3][0], lcdNum[t3][1], lcdNum[t3][2], lcdNum[t3][3]);
 disD3(lcdNum[t2][0], lcdNum[t2][1], lcdNum[t2][2], lcdNum[t2][3]);
 disD4(lcdNum[t1][0], lcdNum[t1][1], lcdNum[t1][2], lcdNum[t1][3]);
nshivu924
HI,
This was useful.
this is a 28 segment driver, means it can drive four digits.
can you please let me know how do you control the decimal point segment on the LCD.
If you can share a sketch of the connections would help.
Shivu
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
