Author Topic: Driving an LED from an Arduino pin/TTL pin *the right way*.  (Read 458 times)
Samplefinger
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
The normal accepted hobbiest way of driving a small LED is to drive it directly from a logic IC pin.  I've heard over and over that this is not the right way to do it and I can understand why.  The Arduino has a reasonably low maximum drive current for the whole package and a lot of TTL packages have poor drive current.  But lighting LEDs this way is still done.  Now, what is the right way?  Say that I have a pin and want to light a 20mA LED on logical 1 and draw 1mA of current from the pin.  The obvious way (to me) is to connect the LED through an NPN transistor, right?  Connect the output pin through a 5K resistor to the base of the transistor (1mA current), connect +5V to the LED, through a 250 ohm resistor (20mA to the LED) to the transistor collector, connect transistor emitter to ground.  Does that sound right?  If so, what is a good transistor choice?  How do I know that 1mA on the base will give me at least 20mA from the emitter to the collector.  How do I know the transistor is open and not operating in the ohmic region?  Thank you.  I am not too familiar with discrete transistors.
« Last Edit: December 13, 2012, 12:43:03 pm by JoeN » Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Manchester (England England)
Solder is electric glue
I can't. There is nothing wrong with driving an LED and its resistor directly from a processor pin. It is done all the time. As long as the current capacity of the pin is up to the job.
No, in comparison with other processors it is very high.
Source rating yes but they are much better at sinking.
Yes. Although you won't find many 5K resistors use 4K7.
The cheapest transistor you can get. Sights like Farnell allow you to sort them by price.
You look at the data sheet and see that the gain of the transistor you are using is at least 20.
Yes I know that from this:-
No such region, do you mean saturated? It is down to the gain of the transistor.
Samplefinger
I know the ATMega328P is a pretty good driver compared to most microprocessors, but it is not a driver.   The maximum package source current is 200mA. That is all I was getting at.  In this case, really I want to drive LEDs (correctly)from a TTL package.  Since I want to turn on an LED for logic 1, the fact that TTL has good sinking current is not meaningful as far as I can see, but maybe I am having tunnel vision here in some way.
Help me on that.   How do I know if I saturated the transistor to keep the emitter to collector resistance minimal?
Can someone recommend a good NPN transistor for my scenario?  1mA to the base must allow 20mA from emitter to collector while saturating the transistor.  Correctly stated?
Thank you all.
Left Coast, CA (USA)
Measurement changes behavior
A couple of popular low(ish) current npn transistors:
2N3904
2N2222A
For driving simple 20ma leds I like the 2N7000 mosfet transistors, no series base (gate) resistor needed and they are cheap.
Lefty
the land of sun+snow
It's far too much trouble to wire up an NPN inverter for every single Led. Also, newer Leds
don't need anywhere near 20 mA to get good output, more like 4-5 mA on many. If you're
worried about current drive off the I/O pins, just buy some high-output Leds.
Duh. The only thing right about *the right way* is don't exceed the current source/sink rating
for the I/O pins.
Kitchen-Sink Arduino-compatible boards
Samplefinger
2N3904
2N2222A
Lefty
OK, I know I have all of these in my Jameco transistor kit.   100 of the 2N3904s, and only 10 each of the other two.  I will try that out.  I especially like the MOSFET idea, thank you.
Edit:  The 2N7000 looks like a great part and Jameco has free shipping this week on orders of $25 or more so I picked up five hundred of them, five cents each (and some anti-static foam which normally really kills me on the shipping cost).  I guess I am set for life.
« Last Edit: December 13, 2012, 01:57:04 pm by JoeN » Logged
Samplefinger
I should also note, for my silly current project I am actually working with 74LS TTL packages again and I want LEDs (on 330 ohm resistors) on some of the inputs and outputs.  An issue I have is that the input LEDs are obviously dimmer than the inputs so clearly the package can't supply 15.15mA and probably I am pulling it at max which can't be good, hence I think I need the transistors.  I like the idea of using these MOSFETs, it's a part I have not used so far.
Valencia, Spain
If you just want it to light up an LED then there's nothing wrong with it.
If you've heard that then it's probably because they weren't use a resistor to limit the current properly or something like that.
It actually has far too much current for normal LEDs (which enter their death zone at 20mA).
Valencia, Spain
Well...aiming at exactly 20mA with just a resistor is a bad idea. Much better to aim at the 12-15mA mark.
In that case 200mA is 13-16 LEDs. About as many as you can physically connect to an Arduino.
(Of course this requires the user understands the limitations, which isn't guaranteed ... remember the guy who connected 60 LEDs to a single Arduino pin then posted about them being a bit dimmer than he would have liked?)
Samplefinger
OK, I am aiming at 15.15mA with a 330 ohm resistor and the white LEDs I use are BRIGHT.  Very nice.  Except the one coming off the 74LS04 package which doesn't make the grade.
Valencia, Spain
Absolutely any common NPN transistor will do that (TO-92 size).
Yes you are totally missing the point. Why the fixation with a logic one turning it on. Anyway if you use an open colllector buffer and power the LED by sinking a logic one will turn it on. Try an 74LS05.
Back to front. When the collector emitter voltage is at a minimum you have saturated the transistor. You saturate a transistor by having more current through the base than the collector current divided by the gain.
