« on: December 13, 2012, 02:03:32 pm » |
Hi guys, I need to implement a battery life indicator for my project. What I have in mind is a very simple battery life indicator for a 9V battery, using just 1 red LED. So what happens is that when the voltage reaches around 7.8V and below, the red LED lights up. If it is higher than 7.8V, the red LED does not light up. And when the red LED lights up, it sends a signal to the arduino which then displays a warning sign on the LCD display. Can anyone help me with how the schematic should look like and connections for the battery life indicator should look like? Am totally clueless (New to arduino  )
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
« Reply #1 on: December 13, 2012, 02:28:58 pm » |
Many people have asked and done that very same thing, MANY times. Try to do a search in the forums, for reading a battery voltage.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
United Kingdom
« Reply #2 on: December 13, 2012, 02:53:25 pm » |
Make a voltage divider from two 100K resistors, connect it between +9V and ground, and connect the midpoint to an analog input pin of the Arduino. Also connect a 10nF or 100nF capacitor between the midpoint and ground. When you do an analogRead from that pin, 7.8V will correspond to (7.8/2) * (1024/5) = 799. If you get a reading less than that, drive an output pin high to light the LED. How you display the battery state on the LCD is up to you - I normally display the battery voltage to 1 decimal place if there is enough space.
the land of sun+snow
« Reply #3 on: December 13, 2012, 03:24:29 pm » |
OP, I hope you're not trying to power an Arduino using one of those measly little 9V batteries.
Murphy's Corollary: the "real" problem is usually what they don't tell you about, which leads to endless second-guessing. m
Queens, New York
« Reply #4 on: December 13, 2012, 03:28:32 pm » |
Go with a 9.6V rechargeable battery pack
Central MN, USA
Online
« Reply #5 on: December 13, 2012, 05:33:02 pm » |
If I use these "measly little 9V batteries" with my arduino projects, which don't involve actuators but do have displays, I can have them run for a maximum of 2 days straight. If you just occasionally turn them on and look at them, they can last for quite some time. One of my projects from 2 years ago is still working with this battery since I turn it off after running it for a bit. These are two extremes but the OP really didn't say what amount of power is involved in the project so every 9V batteries are not totally unfit.
If you're not living on the Edge, you're taking up too much space!
« Reply #6 on: December 13, 2012, 07:35:31 pm » |
They only work for long if you sleep the Arduino most of the time. Most beginners do not know how to do it properly.
If you fall... I'll be there for you! -Floor
Skype Brighteyes3333 (262) 696-9619
« Reply #7 on: December 13, 2012, 08:28:21 pm » |
Looking at this d/s indicates 600 mA-hr for 25 mA load, so a regular Arduino without any loading will run for maybe 24 hours. Poo on that, says I. Rechargeable 9V are only rated at 200 mA-hr, so 3X worse. http://www.jameco.com/Jameco/Products/ProdDS/198731.pdfI have used the 9V in dataloggers with 32-Khz xtal. At that rate, it will run for about 30,000 hours or about 3 years. That makes more sense.
Queens, New York
« Reply #8 on: December 13, 2012, 08:37:39 pm » |
« Reply #9 on: December 13, 2012, 10:00:27 pm » |
I am thinking of running the arduino with a 9V b attery indeed.. The arduino is basically connected to a 16 by 2 LCD display, a RTC module, 2 push buttons and a servo. But the servo runs on its own battery source. so, the arduino powers everything else other than the servo. The servo rotates 180 degrees every 4 hrs per day max. And the LCD display sleeps after inputs have been transferred to it via the pushbuttons and only wakes up when the pushbutton is pressed again or when the battery gets low... So if this is the case, any idea how long the 9V battery would last? Or any other portable and not too expensive suggestions other than http://www.batteryground.com/product/3/382/One-96v-2000mah-Nimh-High-Capacity-Battery-Pack-For-Rc-Car-robots.html ?
« Reply #10 on: December 13, 2012, 10:08:25 pm » |
To add on, I might not be using the backlight of the LCD as well
Portland, OR
« Reply #11 on: December 13, 2012, 11:09:37 pm » |
@oric_dan(333) : That is incredible -- how did using a 32-Khz xtal reduce the current draw that much? I'm curious what the exact numbers are on the current draw that you measured. I have used the 9V in dataloggers with 32-Khz xtal. At that rate, it will run for about 30,000 hours or about 3 years. That makes more sense.
