Pages: 1 [2]   Go Down
Author Topic: How are people powering battery-driven projects?  (Read 556 times)
Left Coast, CA (USA)
Measurement changes behavior
It's a quandary...a 4-cell AA battery is too high voltage for the 5v input, but almost too low for the 78M05 regulator input, adn will drop out fairly quickly despite battery capacity left.  A 9v doesn;t have the endurance of multiple batteries.
I do see however there is a 5v switching arrangement on the Nano at least, to switch, from the USB 5v to the 5v main bus?  Not sure that is an alternative...
So what are people doing in this regard?
So nobody can blame me, I won't suggest that anyone do this, but *I* personally have run an Uno R3 board on 4 AA lithium cells in series. As you may or may not know, a brand new lithium AA cell is around 1.80 volts DC, which is 7.2 volts for 4 of them.
The 4 AA cells in series power the board's "5 volt" supply directly. It does not go through the regulator.
I've made several projects powered like this and they are running fine.
Well that is well above the absolute maximum Vcc voltage limit of 6.0 per the AVR datasheet. How do you account for not having a bunch of burned out boards? And it's magic is not a proper answer.  smiley-wink
Lefty
Krupski... I kinda expected that answer :-)
Yeah, it doesn't surprise me that it'll work over spec.
But the important thing here, is I want to make a whole bunch of these...and they need to work on every single item, not just "that one I tried on the bench".  Not surprised at all it'll work for awhile like that in testing.
Portland, OR
@liudr:
Just curious: What would be some DISadvantages of switched-mode dc-dc converters? Aside from cost, it appears they are better than LDOs in most situations, am I wrong?
E.g., I am considering powering my circuit with a Li-ion battery and using the TPS63000/TPS63002 Buck-boost regulators; they seem to have very good efficiency in both buck and boost modes.
Boston area, metrowest
I've run uCs off 3 AA batteries, ~4.5V, even a '2560 based board @ 16 MHz.
I've also run 3.3V Promini @ 8 MHz from a single LiPo battery.
I don' think I saw what the application is here. Haven't seen what the need is for boost converters unless the goal is to run from  a single AAA or AA size battery.
Australia
The single biggest issue with battery projects is how long do you want the batteries to last
before they have to be replaced.
That effectively defines what sort of batteries are needed, and hence what voltage batteries are needed.
Id stay away from any kind of arranagement that needs voltage converters of any kind, because although they are more
efficent that linear regulators, at very low power levels , they can consume more power than the micro.
Salem, Oregon
Arduino rocks but sometimes it rolls
Well I'm sure there are other, more practical applications but...
I've been designing and selling APRS Trackers (for the non-ham, think 'LoJack') for high-altitude balloon flights, where the goal is to be small and light-weight.
My latest version is powered via a TI TPS61202 (so 2xAA batteries) that drives the on-board 5v Radiometrix 300mW transmitter (HX1) as well as a 3.3V LDO regulator that powers the ATmega328P at 8Mhz (and the ublox GPS).
For a look at the prototype (and get a copy of the design files), check out https://www.dropbox.com/sh/pw3ukfinr6e9mve/wh_THMOnoi?m
Running off 2xAA batteries cuts weight by at least 30 grams and so far, my latest test has logged 13hrs (and is still running) off 2xAA (L91's).
(Plus I've had people interested in using the tracker w/ LiPo's for terrestrial use - things like parades and SAR work).
Regards,
Brad
KF7FER
PS If you're interested in watching paint dry, you can see the prototype running a battery test at http://aprs.fi/?c=raw&call=KF7FER-10&limit=1000&view=normal
Grand Blanc, MI, USA
"We're a proud service of the Lost Electricity Reclamation Agency"
I'm looking to expand my experience with boost and buck converters both, the TPS61202 looks interesting. Are you hand assembling? How tough is it to solder that package, and are you soldering the thermal pad?
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
the land of sun+snow
A little out of context, but I just bought a Pololu Zumo robot, and on their Zumo shield they use
4 AA-cells powering a boost converter outputting 7.45V, rated about 1A.
The 4 AA-cells also directly power an h-bridge to control the motors [beautiful little gearmotors],
and the boost regulator provides power to a standard Arduino UNO/etc, board that plugs in on top.
You end up with a neat tracked mini-sumo that's less than 2" tall with everything running off 4 NiMH
AA-cells.
http://www.pololu.com/catalog/product/2505
http://www.pololu.com/catalog/product/2504
Kitchen-Sink Arduino-compatible boards
Salem, Oregon
Jack-
When I got this set of PCBs back from the fab, I found every excuse for the first three days to not start.  I honestly was terrified at soldering the TPS61202.
I always hand-assemble my boards, though I have used a hot-plate before.
But I ended up using an Aoyue hot-air rework station and solder paste to handle just the TPS61202, then I hand-assembled the rest of the board.
It worked the first time even.  Ok, the boost converter did.  I got the wrong LDO and had to swap it, but otherwise the board was fine - especially for "Revision A".
I probably should add that the guys in the UK and Australia doing HAB work have been using boost converters for some time (see http://ava.upuaut.net/?p=353) so I got a lot of help from them (thanks M0UPU and VK5QI!)
I hope this helps,
Brad
KF7FER
PS I have to double-check the test data but I believe we are at 22hrs and counting (battery voltage is still at 2.59v).  Those "ultimate lithium" batteries are expensive but when compared to generic "big-box" store batteries they run much longer (I got 7hrs off of 2xAA "Kirkland" batteries) and weigh almost 1/2 as much (15g vs 25g).
Brad, thanks for the info. I can hand-solder some SMDs fairly well, but some of those packages just don't lend themselves to it. Congrats on a great low-power project, sounds like it's working well!
Pages: 1 [2]   Go Up
