Topic: Problem with 5V pins... (Read 650 times) previous topic - next topic
FlyingSteve
I'm having a problem with the 5V pins on both my Uno and Mega... I'm trying to signal a mosfet and no matter if I use a pin and set it to high or connect to the 5V output it won't work.
So, I tried different power adapters, usb, etc.... If I measure voltage at the pin it's a solid 5V. If I connect a wire to the pin and then measure the voltage at the other end it'll be lower, dropping in relation to the length of the wire. It's like the pins are putting voltage out but no current. I get the same results if I try the 3.3V pin.
Previously I was setting the pin from high to low to shut the mosfet gate, but I added a 10K pull-down because I was having a problem with the mosfet gate remaining open even after 5V was removed. Could this have damaged the board by pulling too much current?
I had no problems with this setup previously, then I packed the arduino's away for a few months and now just seems like the capacitors are dead or something, I don't know.
johnwasser
Did you remember to connect the Arduino ground to the MOSFET ground.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
FlyingSteve
No. I'm powering all the devices, etc, (other than the arduino which is on a wall wart) through a PC PSU... I connected the ground pin on Arduino to the ground coming from PC PSU and what ya know, it works now lol.
Last time I powered the Arduino with the PC PSU through a barrel connector which explains why I had no problems! D'oh!
Thank you so much for the help!
johnwasser
No problem.  It's a common mistake which is why it was my first guess. :)
