« on: December 13, 2012, 08:42:05 pm » |
I have been scouring the internet for a simple example that I can expand upon and have had no luck and am hoping someone can help. I want to control an Arduino through an Ethernet cable using VB code on a PC. I have found where someone does this but uses a WiFi connection but I have not been able to successfully modify the code to get it to talk Ethernet instead of WiFi. I will attach the code I have so far but it may be easier if someone knows of a simple example to say turn on a single LED using the above I can modify the example to get what I want. The attached code does talk to my Arduino because I can see the TX and RX lights blink when I click on the form button but I cannot get the LED to turn on or off. Arduino code: //************************************************************************************************************************************* // Declarations //************************************************************************************************************************************* #include <SPI.h> #include <Ethernet.h>
//************************************************************************************************************************************* // Wired configuration parameters //************************************************************************************************************************************* byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0xD1, 0x4B }; unsigned char local_ip[] = {192,168,1,100}; // IP address of WiShield unsigned char gateway_ip[] = {192,168,1,1}; // router or gateway IP address unsigned char subnet_mask[] = {255,255,255,0}; // subnet mask for the local network
EthernetServer server(80);
char buffer[20];
void setup() { pinMode(8,OUTPUT); Ethernet.begin(mac, local_ip); Serial.begin(9600); }
void loop() { EthernetClient client = server.available(); if (client) { boolean currentLineIsBlank = true; while (client.connected()) { if (client.available()) { int val; if (buffer[0] == 'O') { digitalWrite(8,HIGH); } else if (buffer[0] == 'F') { digitalWrite(8,LOW); } } } } }
VB Code: Imports System.Net.Sockets Imports System.Text
Public Class Form1 Dim tcpClient As New System.Net.Sockets.TcpClient() Dim networkStream As NetworkStream Dim KeyPressed As Integer
Private Function Arduino_Connect(ByVal IP As String, ByVal Port As Integer) As Boolean tcpClient.Connect(IP, Port) networkStream = tcpClient.GetStream() If Not networkStream.CanWrite Or Not networkStream.CanRead Then tcpClient.Close() networkStream = Nothing Return False End If Return True End Function
Private Sub Arduino_Write(ByVal Output As String) If Not IsNothing(networkStream) Then Dim sendBytes As [Byte]() = Encoding.ASCII.GetBytes(Output) Dim endByte As [Byte]() = {&HFE} networkStream.Write(sendBytes, 0, sendBytes.Length) networkStream.Write(endByte, 0, 1) Else MsgBox("ERROR") End If End Sub
Private Sub Form1_load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load Arduino_Connect("192.168.1.100", 80)
picOff.Visible = True picOn.Visible = False End Sub Private Sub Arduino_Disconnect() If Not IsNothing(networkStream) Then tcpClient.Close() networkStream = Nothing End If End Sub
Private Sub btnOn_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnOn.Click picOff.Visible = False picOn.Visible = True Arduino_Write("O") End Sub
Private Sub btnOff_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnOff.CLick picOff.Visible = True picOn.Visible = False Arduino_Write("F") End Sub
End Class
I have found posts that talk VB to Arduino through serial and I have that working, WiFi to Arduino but can't test due to not having a WiFi shield of any sort, and I have some HTML versions of the code working but I would really like to control the Arduino using VB and Ethernet. I am not extremely familiar with the Arduino nor VB but I know enough to understand what is going on most of the time. Any help on this is greatly appreciated especially if a simple example that I can modify can be provided or linked to.
Seattle, WA USA
Online
Seattle, WA USA
« Reply #1 on: December 14, 2012, 12:59:07 am » |
So, a client connects to the Arduino-as-server. if (client) { boolean currentLineIsBlank = true; while (client.connected()) { if (client.available()) { int val; if (buffer[0] == 'O') { digitalWrite(8,HIGH); } else if (buffer[0] == 'F') { digitalWrite(8,LOW); } } } } You check to see if the client has anything to say, but you never bother to find out what the client has to say (there are no client.read() calls). Then, you look in the buffer that you haven't written to to see if some stuff magically appeared there. Well, of course it hasn't, so buffer does not contain 'O' or 'F' in the first position, so nothing happens. You never read what the client has to say, so it stays connected. Pretty soon, there are no more connections available, so no more clients can get in line to be ignored. What was the problem, anyway?
Miramar Beach, Florida
« Reply #2 on: December 14, 2012, 07:14:39 am » |
Have you checked the Arduino server with a web browser? It seems you declare the server, but do not start it in setup. void setup() { pinMode(8,OUTPUT); Ethernet.begin(mac, local_ip); Serial.begin(9600);
// start the server listening on port 80 server.begin(); } edit: I should have posted a link to the server sketch example in the playground (playground = wiki). http://playground.arduino.cc/Code/WebServerST
« Last Edit: December 14, 2012, 07:31:18 am by SurferTim »
Get Bitlash: http://bitlash.net
« Reply #3 on: December 14, 2012, 07:37:05 am » |
You're going to have to decide whether you want to use a web server / HTTP approach or an old-school telnet-style approach on the Arduino. There are plenty of examples for the web server case (and in fact Zoomkat will be here any second to share some solid working HTTP code.) It might be worth taking a look at the BitlashWebServer example that ships with Bitlash ( http://bitlash.net). It's a sketch that exposes Bitlash scripting as a web service from the Arduino over Ethernet. It also has a telnet server so you can just send commands, as opposed to commands wrapped in HTTP GET requests. For your project you could just send "d13=1" to turn on the LED on pin 13, and "d13=0" to turn it off. Bitlash here: http://bitlash.net and you can browse the web server/telnet sketch code that ships in the distribution here: https://github.com/billroy/bitlash/blob/master/examples/BitlashWebServer/BitlashWebServer.inoGood luck with your project, -br Edit: D13 is not going to work for an LED because it is used by the Ethernet shield. Discovered this while creating a new built-in script for the BitlashWebServer. But now you can open a browser on the server ip-address/toggle5 and it will turn pin 5 on and off.
« Last Edit: December 14, 2012, 08:07:09 am by billroy »
Online
« Reply #4 on: December 14, 2012, 02:55:19 pm » |
Very simple web page control code. //zoomkat 4-1-12 //simple button GET for servo and pin 5 //for use with IDE 1.0 //open serial monitor to see what the arduino receives //use the \ slash to escape the " in the html, or use ' instead of " //address will look like http://192.168.1.102:84 when submited //for use with W5100 based ethernet shields
#include <Servo.h> Servo myservo; // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address byte ip[] = { 192, 168, 1, 102 }; // ip in lan byte gateway[] = { 192, 168, 1, 1 }; // internet access via router byte subnet[] = { 255, 255, 255, 0 }; //subnet mask EthernetServer server(84); //server port
String readString;
void setup(){
pinMode(5, OUTPUT); //pin selected to control //start Ethernet Ethernet.begin(mac, ip, gateway, gateway, subnet); server.begin();
myservo.write(90); //set initial servo position if desired myservo.attach(7); //the pin for the servo control //enable serial data print Serial.begin(9600); Serial.println("server servo/pin 5 test 1.0"); // so I can keep track of what is loaded }
void loop(){ // Create a client connection EthernetClient client = server.available(); if (client) { while (client.connected()) { if (client.available()) { char c = client.read();
//read char by char HTTP request if (readString.length() < 100) {
//store characters to string readString += c; //Serial.print(c); }
//if HTTP request has ended if (c == '\n') {
/////////////// Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page client.println("Content-Type: text/html"); client.println();
client.println("<HTML>"); client.println("<HEAD>"); client.println("<TITLE>Arduino GET test page</TITLE>"); client.println("</HEAD>"); client.println("<BODY>");
client.println("<H1>Zoomkat's simple Arduino button</H1>"); client.println("<a href=\"/?on\">ON</a>"); client.println("<a href=\"/?off\">OFF</a>");
client.println("</BODY>"); client.println("</HTML>"); delay(1); //stopping client client.stop();
///////////////////// control arduino pin if(readString.indexOf("on") >0)//checks for on { myservo.write(40); digitalWrite(5, HIGH); // set pin 5 high Serial.println("Led On"); } if(readString.indexOf("off") >0)//checks for off { myservo.write(140); digitalWrite(5, LOW); // set pin 5 low Serial.println("Led Off"); } //clearing string for next read readString="";
« Reply #5 on: December 14, 2012, 05:00:32 pm » |
I haven't had much of a chance to play around with any of the code yet but I can answer some questions. I have tried the HTML version of control and I did get that to work with my Arduino. I guess one thing I am wondering here though is how can I implement a momentary button action while using Ethernet communications. From the small amount of web experience that I do have I believe a webpage is more like an on/off switch. Is that correct? I am assuming I could probably build in some kind of delay but it would get old having to click the button many times to keep something like a light on.
I do not have much experience with an Arduino so far and am trying to learn more everyday. I will attempt to work on the ideas mentioned above this weekend but if anyone has ideas of how I can implement a momentary style switch instead of an on/off switch it would be greatly appreciated if you would share your thoughts or ideas.
Online
« Reply #6 on: December 14, 2012, 08:57:10 pm » |
I do not have much experience with an Arduino so far and am trying to learn more everyday. I will attempt to work on the ideas mentioned above this weekend but if anyone has ideas of how I can implement a momentary style switch instead of an on/off switch it would be greatly appreciated if you would share your thoughts or ideas. You need to explain in more detail the desired operation of your "momentary style switch". Is the light to be on while the switch is closed/pushed, and off when the switch is opened/released? Are you wanting to do this via a web page or some other VB application?
« Reply #7 on: December 16, 2012, 04:41:51 am » |
« Reply #8 on: December 16, 2012, 05:30:59 pm » |
Thank you everyone for your help and posts. I have finally got it working!! PaulS, thank you for your initial post. I took a better look at my code and compared it closer to a working version of the HTML working code and found that, as you said, I was never reading the client. As for other ways of doing the same thing I am wanting a momentary button so that on my PC I would click a button and while I am holding the mouse button down the light would be on and once I let go the light goes off until I click and hold the button again. I have implemented this using the keyboard but thought it would also be nice to do it in VB code as well using the mouse but haven't figured it out just yet. Also thank you to rbright for the link. I can definitely see some uses for that interface and program in the very near future. My working code is below. It has some extra items in it that I got from another example but I think I can modify it to make what I want. Arduino Code: //************************************************************************************************************************************* // Declarations //************************************************************************************************************************************* #include <SPI.h> #include <Ethernet.h>
//char buffer[20]; String buffer = "";
void loop() { EthernetClient client = server.available(); if (client) { boolean currentLineIsBlank = true; while (client.connected()) { if (client.available()) { char c = client.read(); Serial.print(c); buffer+=c; int val; if (c == 'O') { digitalWrite(8,HIGH); } else if (c == 'F') { digitalWrite(8,LOW); } } } } }
Private Sub Control_KeyDown(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyEventArgs) Handles Control.KeyDown Select Case KeyPressed Case 38 ' Up 'Car_Stop() Case 40 ' Down ' Car_Stop() Case 39 ' Right 'MsgBox("You pressed Ctrl and Arrowkey Right") picOff.Visible = False picOn.Visible = True Arduino_Write("O") Case 37 ' Left ' Car_TurnNone() End Select KeyPressed = 0 End Sub
Private Sub Control_KeyUp(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyEventArgs) Handles Control.KeyUp KeyPressed = e.KeyCode Select Case KeyPressed Case 38 ' Up 'Car_ForwardDrive(Speed.Text) Case 40 ' Down 'Car_BackwardDrive(Speed.Text) Case 39 ' Right picOff.Visible = True picOn.Visible = False Arduino_Write("F") Case 37 ' Left ' Car_TurnLeft() End Select End Sub
End Class
Online
« Reply #9 on: December 16, 2012, 05:45:28 pm » |
In html pages mouse actions can be used like below. <input type="button" value="<<<" onmousedown="location.href ('http://127.0.0.1/cgi-bin/cgi3c8.exe?-0p700S100');" onmouseup="location.href ('http://127.0.0.1/cgi-bin/cgi3c8.exe?STOP0');"/>
« Reply #10 on: December 16, 2012, 06:42:18 pm » |
REally???? please give some code that people use not just any garbage. a mouse action is easier done using this: <form name="input" action="/yourserver" method="get"> Username: <input type="text" name="something"> <input type="submit" value="Submit"> </form>
Online
« Reply #11 on: December 16, 2012, 07:03:39 pm » |
REally???? please give some code that people use not just any garbage. Somebody pee in your corn flakes?
Seattle, WA USA
Online
Seattle, WA USA
« Reply #12 on: December 16, 2012, 07:38:50 pm » |
Somebody pee in your corn flakes? Yep. And I know who it was.
