Topic: What is the normal arduino PWM frequency in Hz? (Read 3790 times) previous topic - next topic
Voidugu
Thanks in advance :) Have a great day
Magician
retrolefty
I though because of the diffences between the timers used in analogWrite() depending on the specific PWM pins that the default PWM switching speed on a 328p based board was:
Arduino Pins 5 and 6: 1kHz
Arduino Pins 9, 10, 11, and 3: 500Hz
That's from an older source, but think it still applies that there are two different switching frequencies used depending on the specific pwm output pins being used.
Lefty
nickgammon
However you can change it fairly easily by changing the prescaler, particularly for Timers 1 and 2. You could do it for Timer 0, but that would change the rate at which the millis() figure updates.
Also if you want other frequencies and are prepared to dedicate a whole timer to it you can effectively select one from a wide range. I have a table on this page which shows the various frequencies you can achieve. However you have to get a bit closer to the hardware to do that, although there are some libraries that will help with that.
