Netherlands
« on: December 14, 2012, 01:39:37 pm » |
(just found it, need to dig in) For those in need of some reading material - http://www.freetechbooks.com/ -
Pittsburgh, PA, USA
I only know some basic electricity....
« Reply #1 on: December 14, 2012, 09:31:54 pm » |
wOOt! http://www.freetechbooks.com/lessons-in-electric-circuits-t258.htmlSimulating with SPICE:
One way to reduce the necessity of setting up your own laboratory, is to utilize computer simulation. One particular computer program called SPICE serves that purpose. It is a text-based piece of software intended to model circuits and provide analyses of voltage, current, frequency, etc. Although nothing is quite as good as building real circuits to gain knowledge in electronics, computer simulation is an excellent alternative.
One of the advantages is that SPICE could be used within a textbook to present circuit simulations to allow students to "observe" the phenomena for themselves. This way, the readers could learn the concepts inductively (by interpreting SPICE's output) as well as deductively (by interpreting the book's explanations). Furthermore, in seeing SPICE used over and over again, they should be able to understand how to use it themselves, providing a perfectly safe means of experimentation on their own computers with circuit simulations of their own design. I wonder if that would be good for helping forum questions with simple circuits?
Examples can be found at Learning in the Main Site and at the Playground
Greenville, IL
Warning Novice on board! 0 to 1 chance of errors!
« Reply #2 on: December 15, 2012, 11:59:58 am » |
Good site! Bookmarked!
SE USA
@ssh0le
« Reply #3 on: December 15, 2012, 10:29:31 pm » |
one of the problems with spice is that it takes a ton of setup and if you dont do it 100% right you might as well be generating random numbers ... even then when you take the same circuit to the bench, tolerance and manufacturing kick in usually borking what you saw in spice anyway.
Central MN, USA
« Reply #4 on: December 16, 2012, 01:25:34 am » |
Find and download PSPICE if you want some basic circuit simulation. There's quite a bit of learning curve and setup time. I use it every other year for an electronics class.
Vlissingen Netherlands
« Reply #5 on: January 04, 2013, 05:05:04 am » |
Way to go Rob... Lot's of good stuff out there, (you must love the internet)... I have seen some stuff also for learning C/C++, well guess i need to digg in to that also. Than i don't need to ask such stupid questions here also
Netherlands
« Reply #6 on: January 04, 2013, 02:50:10 pm » |
you must love the internet yep, it is my offline "brain" or a 7nth sense or ...
