Loading...
Pages: [1]   Go Down
Author Topic: RS232, MAX232 & Serial MEGA  (Read 548 times)
Italy
Offline Offline
Newbie
I love arduino!
View Profile
I'am arduino newbie... smiley
I have create a new project for read four serial ports. I using Serial Port Arduino Mega(Serial 1,2) and MAX232 transceivers (for the conversion RS232 to TTL 5V) like this:http://arduino.cc/en/Tutorial/ArduinoSoftwareRS232
My PC Serial  exit with 3 wires (RX,TX and GND)
 ]smiley have a problem: If I use Arduino serial embedded, the data reading it works only with GND not connect... and if I use the serial connected to MAX232  it works only with GND CONNECTED!!!...
Somebody help me???
Thanks a lot and sorry for my english!  smiley-roll-sweat
Logged
MM
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
What ground where?
It is hard to know what your setup is, you do not describe it.
Grounds must always be common.
Logged
Italy
Offline Offline
Newbie
I love arduino!
View Profile
I explain you better...
In my simulation i have connected the serial on PC for trasmitted data.
My cable have 3 wires:
Green: TX
Blue: RX
Black: GND
Step1: Connect My serial directly to arduino:
Green on TX1
Blue on RX1
Black not connected
And I reading all data!! .. If connected black wire (GND) on arduino GND the serial data stopped work
Step1: Connect My serial to MAX32 thought arduino digital pin:
Green on ArduinoPIN10
Blue on ArduinoPIN10
Black Arduino GND
And I reading all data!! .. If I disconnect black wire (GND) on arduino GND the serial data stopped work
thanks....
Logged
MM
Italy
Offline Offline
Newbie
I love arduino!
View Profile
 smiley i'm sorry... Errata corrige
Step2: Connect My serial to MAX32 thought arduino digital pin:
Blue on ArduinoPIN11
Black Arduino GND
Logged
MM
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
Oof! That page referenced looks like a plate of spaghetti. As G_M says, all the grounds in
such a setup should be common. With spaghetti like that, 99% probably you have something
plugged into the wrong slot on the whiteboard.
Logged
Murphy's Corollary: the "real" problem is usually what they don't tell you about, which leads to endless second-guessing. m
Italy
Offline Offline
Newbie
I love arduino!
View Profile
 smiley-red smiley-red smiley-red
the plugs are OK!
what are kind of differences between "Arduino Serial embedded" and this "http://arduino.cc/en/Tutorial/ArduinoSoftwareRS232" ?
Logged
MM
South Texas
Offline Offline
God Member
View Profile
The arduino chip (328P) outouts 5V and 0V from the serial output an board. The Max 232 ouptus a more proper +5V and -5V. when you hook the wires up directly WITHOUT GROUND the float on the wires work to have the signals slide around and fall in a voltage range that your PC serial port is able to function with. For Now. re-arrange your desk or add some other circuit somewhere and things may not float the same and it will quit working.
Or in other words - You Got Lucky!
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Green on TX1
Blue on RX1
Black not connected
This is wrong, it is nt happening like you think,you have another mistake that is making you think it is working OK just because you are reading data. You got lucky with your fault. You need to find the real fault so that connecting the ground does not stop it working.
Logged
France
Offline Offline
Sr. Member
View Profile
Anyway, connecting directly the Pc serial port to the arduino is not a good way of doing it ! You will burn the digital pins of arduino.
Can you post a schema of the way you interface the MAX232 IC to the arduino ?
May be it will allow us to understand.
I had never trouble with arduino + MAX232 + Serial PC.
Grag
Logged
Offline Offline
Edison Member
View Profile
WWW
He says he followed the scheme in the link given in the first posts, and says his
connections are totally correct.
Logged
Pages: [1]   Go Up
Print
Jump to:
