Topic: Serial.print incomplete string ? (Read 3797 times) previous topic - next topic
HazardsMind
How would you know if you are having memory leakage problems, how do I test this?
Because I use strings a lot but, I never noticed any problems.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
liudr
Fellows, I think you may have the String thing mixed up. The OP is only using String in actionscript. Isn't that run on a computer instead of on Arduino?  8)
Regarding memory leak, I heard from experts that is a problem with free(). HazardsMind, you may not have experienced a problem possibly because you are not defining String in subroutines or loop (did you just define String outside functions?). There are plenty of others that did get into trouble and fixed the problem by not using String. The problem is if you have a String in functionX then every time the function quits free() should clean up the String but it doesn't, that's what I heard.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
HazardsMind
@liurd
I'll post a sample from my robot code when I get home, I don't have it on me right now.
It there a way to see the memory leakage?
My GitHub:
liudr
I used this:
http://playground.arduino.cc/Code/AvailableMemory
HazardsMind
This also pertains to String objects too, right?
My GitHub:
PaulS
Quote
What does? Memory is memory.
HazardsMind
The memory leakage, their are two types of strings, character arrays and objects. Do they both have the same problem?
My GitHub:
PeterH
The problem is associated with the release of dynamically allocated memory.
String objects use dynamically allocated memory, so they inherently suffer from the problem.
'C' strings (null-terminated char arrays) don't use dynamically allocated memory so don't inherently suffer from the problem.
I only provide help via the forum - please do not contact me for private consultancy.
zoomkat
Quote
The real problem in the forum is that 9 out of 10 instances (and I'm being liberal) where the forum hens cackle about not using Strings, Strings is never been proven to be the actual issue causing the problem with the code.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
HazardsMind
#24
Dec 15, 2012, 04:28 am Last Edit: Dec 15, 2012, 04:31 am by HazardsMind Reason: 1
@liurd
Here is my robot code, the only time I had a problem was when I tried to clear multiple strings like this, X,Y,State = ""
I got garbage when I tried to send the data. That was the only problem I had, everything works now.
Here:
Code: [Select]
control test
#include<string.h>
int DRV1,DRV2,STRR,STRL;
int x = 0;
int y = 0;
int s = 0;
void move(int x = 0,int y = 0,int s = 0);
//double z;
String val = "";
String  X= "";
String  Y= "";
String  state = "";
//int state = 0;
int currentCommand = 0;
int ledpin = 13;
byte Mopen = 4;
byte Mclosed = 2;
byte M1L = 3;// PWM
byte M2L = 5;// PWM
byte M1R = 9;// PWM
byte M2R = 6;// PWM
  pinMode(ledpin, OUTPUT);  // pin 13 (on-board LED) as OUTPUT
  pinMode(Mopen, OUTPUT);
  pinMode(Mclosed, OUTPUT);
  pinMode(M1L, OUTPUT);
  pinMode(M1R, OUTPUT);
  pinMode(M2L, OUTPUT);
  pinMode(M2R, OUTPUT);
  Serial.begin(9600);       // start serial communication at 115200bps
  if( Serial.available())       // if data is available to read
    digitalWrite(ledpin, HIGH);
    char c= Serial.read();
    if (c == ','){
      currentCommand++;
    else {
      val += c;
      //Serial.println(val);
      switch (currentCommand) {
      case 0:
        X += val;
        val = "";
      case 1:
        Y += val;
        val = "";
      case 2:
      //Serial.println("X: "+X);
      //Serial.println("Y: "+Y);
        state = val;
        currentCommand = 0;
        val = "";
        //Serial.println("state: "+state);
        //Serial.println();
        x=X.toInt();
        y=Y.toInt();
        s=state.toInt();
        X=""; Y=""; state="";
        move(x, y, s);
  void move(int x, int y, int s)
      x=constrain(x, -90, 90);
      y=constrain(y, -90, 90);
  //Movement varibles
  int DRV2 = map(x, -90, 0, 255, 0);
  int DRV1 = map(x, 0, 90, 0, 255);
  int STRR = map(y, -90, 0, 255, 0);
  int STRL = map(y, 0, 90, 0, 255);
  if(x > 0)//forwards
    //Serial.println("Driving");
    analogWrite(M1L, abs(DRV1 - STRL)); analogWrite(M1R, abs(DRV1 - STRR));
    analogWrite(M2L, 0); analogWrite(M2R, 0);
  else if(x < 0)//backwards
    analogWrite(M1L, 0); analogWrite(M1R, 0);
    analogWrite(M2L, abs(DRV2 - STRR)); analogWrite(M2R, abs(DRV2 - STRL));
  else if(x == 0 && y >0)//right
    analogWrite(M1L, STRL); analogWrite(M1R, 0);
    analogWrite(M2L, 0); analogWrite(M2R, STRL);
  else if(x == 0 && y < 0)//left
    analogWrite(M1L, 0); analogWrite(M1R, STRR);
    analogWrite(M2L, STRR); analogWrite(M2R, 0);
  else //full stop
    digitalWrite(M1L, LOW); digitalWrite(M1R, LOW);
    digitalWrite(M2L, LOW); digitalWrite(M2R, LOW);
   if(s == 1)
      //Serial.println("Claw Opening");
      digitalWrite(Mopen, HIGH); digitalWrite(Mclosed, LOW);
    if(s == 2)
      //Serial.println("Claw Closing");
      digitalWrite(Mopen, LOW); digitalWrite(Mclosed, HIGH);
    if(s == 0)
      digitalWrite(Mopen, LOW);  digitalWrite(Mclosed, LOW);
   else{
    digitalWrite(ledpin, LOW);
    x=0; y=0; s=0;
I tried to use arrays for the X,Y and state but it wouldn't work correctly, so I went back to strings and it worked.
My GitHub:
PeterH
Quote
I don't know where your figures come from but, regardless of what the true figures are, when somebody using Strings reports problems of the sort that can be caused by the known problem in Strings, it makes sense to remove that as a possible cause before you spend any more time looking for other possible causes. I assume the String class was introduced to simplify text processing, but using 'c' strings directly is not especially difficult so it is (imo) reasonable to recommend this as a speculative fix even when the cause is not known.
zoomkat
Quote
I've read the often posted two discussions about what is broken with the String function. It appears that the clearing of a memory space does not happen when String is used in sub functions in rather complex code. I have yet to see an issue corrected in the typical simple code (or any code posted in the forum as I remember)  by not using the String class.
Quote
The String class does simplify using strings for the new forum members. The forum String class hens cackle about not using Strings when a newbie uses them in code, but the hens almost never help the newbie by correcting the posted code to not use strings. Using 'c' is complex and difficult, especially for the newbie, and apparently for some of the hens as they never demonstrate coorecting code issues by not using Strings. The main reason  the hens don't correct the code is that Strings is not actually causing the problem with the code. Would make the hens look somewhat clueless when not using Strings does not fix the problem.  :smiley-roll:
PeterH
That seems to be pure speculation on your part about the abilities and motivation of forum contributors. If you don't believe the String class is vulnerable to the memory leak problem then good for you, but I think you're in a minority.
zoomkat
Quote
Never have I ever sad that I don't beleve the String class has a memory leak. Generally microtrollers work the way they are wired and code runs the way it is written. The problem I have is that certain forum persons inject into code problem solving String class issues that do not have any relation to solving the actual issues at hand. Persons who do this, in my opinion, are displaying a technical difficiency they have by not being able to stay on focus to solve the actual code problem. Most of the time they could just as well suggest sacrificing a 20 piece bucket of KFC extra crispy chicken to some diety, as the result would be the same.
http://www.youtube.com/watch?v=3Vg7jBJ6FdU
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
