Loading...
Pages: [1]   Go Down
Author Topic: Maximum number of 1wire temp sensors  (Read 335 times)
New Jersey
Offline Offline
Sr. Member
View Profile
I have 3 strings of 1wire temp sensors (DS18B20) where each string has 9 sensors on it.  If I plug one string into my Arduino, I can read everything fine.  I can even splice two strings together and everything is fine. But when I tie all 3 together my sketch says zero devices found.  Is there a limit to the number of devices the library supports?  I've tried each string by itself and it's fine.
Here's my sketch
Code:
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
void setup(void) {
  Serial.println("Dallas Temperature IC Control Library Demo");
  sensors.begin();
void loop(void) {
  int deviceCount;
  sensors.requestTemperatures(); // Send the command to get temperatures
  deviceCount = sensors.getDeviceCount();
  Serial.print("Found ");
  Serial.print(deviceCount);
  Serial.println(" devices");
  for (int i=0; i < deviceCount; i++)
    Serial.print("Temperature for Device ");
    Serial.print(i);
    Serial.print(" is: ");
    Serial.print(sensors.getTempFByIndex(i));
  delay(2000);
Logged
Dee Why NSW
Offline Offline
Full Member
View Profile
If you are using just a USB cable rather than a wall-wart, your problem may simply be one of inadequate power.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
can you make a drawing of the topology?
more cable means that you might need other values for your pull up/down resistors to get a nice square wave signal...
- http://www.gammon.com.au/forum/?id=10896 - search the section of pull up (yes it is another bus type but the problem can be similar)
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
New Jersey
Offline Offline
Sr. Member
View Profile
There are 5 strands, one of them is a T shape.  There is a 1wire every 16 inches.  There's 60 sensors all together. I'm powering it with +5 volts and ground from the Arduino Mega 2560.   I'm not using parasite power.  I have a 4.7k resistor between data and +5v.  Every strand works fine if it's the only one connected to the Arduino. Iif I connect the 9 device strand and 10 device strand together, it works, as does the 9 + 9 device strands.  But when I try to connect the 15 or 17 device strands to any other strand, it reads zero devices found.  That's why I suspect I'm exceeding some maximum.
Here's the topology:
Logged
Pages: [1]   Go Up
Print
Jump to:
