Loading...
Pages: [1]   Go Down
Author Topic: "Voice Your Opinion"  (Read 190 times)
Offline Offline
Newbie
View Profile
This is an art project for my GCSE that involves Arduino. It takes voice input and outputs it as randomised flashing LEDs based on the volume of the voice. HERE IS THE CODE:
Code:
int recording[200];
int micLevel = 0;
int nomore = 0;
int ending = 0;
int LEDL = 0;
int LEDS = 0;
int avail[9];
int randy = 0;
int pin = 0;
int out = 0;
int fix = 0;
int ready = 1;
int readyornot = 0;
int resist = 0;
int addition;
/* This program waits until a certian mic level is reached, record the levels of speech for
 * a maximum of 10 seconds, and then flash random LEDs at the same levels of the recording...
 * It's fixed now ;) This is my first real project, I guess. This should get me a fine art GCSE! Anyway:
 * Writer: terrabyte_aura
 * Project: Voice Your Opinion.
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  randomSeed(analogRead(0));
  avail[0] = 1;
  avail[1] = 1;
  avail[2] = 1;
  avail[3] = 1;
  avail[4] = 1;
  avail[5] = 1;
  avail[6] = 1;
  avail[7] = 1;
  avail[8] = 1;
  digitalWrite(2, HIGH);
  digitalWrite(3, HIGH);
  digitalWrite(4, HIGH);
  digitalWrite(5, HIGH);
  digitalWrite(6, HIGH);
  digitalWrite(7, HIGH);
  digitalWrite(8, HIGH);
  digitalWrite(9, HIGH);
  digitalWrite(10, HIGH);
  delay(400);
  digitalWrite(2, LOW);
  digitalWrite(3, LOW);
  digitalWrite(4, LOW);
  digitalWrite(5, LOW);
  digitalWrite(6, LOW);
  digitalWrite(7, LOW);
  digitalWrite(8, LOW);
  digitalWrite(9, LOW);
  digitalWrite(10, LOW);
  while(micLevel <= 360) { //waits for mic to be at a good level (<=360)
    micLevel = analogRead(1);
    resist = analogRead(2); //works out which pin is connected to work out any additions (to counter resistance)
    if(resist > 1000) {
      addition = 40;
    resist = analogRead(3);
    if(resist > 1000) {
      addition = 30;
    resist = analogRead(4);
    if(resist > 1000) {
      addition = 20;
    resist = analogRead(5);
    if(resist > 1000) {
      addition = 10;
    Serial.print("addition @: ");
    Serial.println(addition);
    micLevel = micLevel + addition;
    Serial.print("Mic @ ");
    Serial.print(micLevel);
    Serial.println(" Not loud enough... (if last view of message, ignore)");
    delay(100);
  for(int y = 0; y < 200; y++) {
    recording[y] = micLevel;  //records the level of the microphone in the array
    Serial.print(" MicLevel: ");
    Serial.println(micLevel);
    if(micLevel <= 360) {
      nomore = nomore + 1;
      Serial.print("nomore = ");
      Serial.print(nomore);
      if(nomore == 10) {
        fix = y;
        y = 200;  //if a low level is recorded for 2 seconds, it will terminate the recording
    else {
      nomore = 0;
      Serial.print(" nomore = 0"); //resets the counter for low level...
    delay(100);
    Serial.print(" Fix @ ");
    Serial.print(fix);
    if(fix > 0) {
      ending = fix;
      Serial.println(" Recording End Reached");
      fix = 0;
  Serial.println("FLASH!");
  delay(400);
  Serial.println("Playback...");
  for(int z = 0; z < ending; z++) {
    Serial.print(recording[z]);
    Serial.print(" ending:");
    Serial.print(ending);
    LEDL = recording[z];
    Serial.print(" Position:");
    Serial.println(z);
    if(LEDL <= 380) { //this takes the level at frame z and turns it into a number of LEDs
      LEDS = 1;
    if(LEDL > 380 && LEDL <= 411) {
      LEDS = 2;
    if(LEDL > 411 && LEDL <= 442) {
      LEDS = 3;
    if(LEDL > 442 && LEDL <= 473) {
      LEDS = 4;
    if(LEDL > 473 && LEDL <= 504) {
      LEDS = 5;
    if(LEDL > 504 && LEDL <= 535) {
      LEDS = 6;
    if(LEDL > 535 && LEDL <= 566) {
      LEDS = 7;
    if(LEDL > 566 && LEDL <= 870) {
      LEDS = 8;
    if(LEDL > 870) {
      LEDS = 9;
    Serial.print(LEDS);
    Serial.println(" is the number of LEDS to be on...");
    while(readyornot == 0) {
      out = 0;
      randy = random(0, 10);
      Serial.print(randy); //this chooses which LEDs will NOT be turned on...
      Serial.println(" is the random number");
      out = 0;
      while(out < 1) {
        if(avail[randy] == 0) { //this checks to see if the number's already been chosen
          Serial.print("previous had already been chosen... new number: ");
          Serial.println(randy);
        else {
          avail[randy] = 0;
          Serial.println(" activated");
          out = 1;
          ready = ready + 1;
          Serial.print("Ready: ");
          Serial.println(ready);
        if(ready > LEDS) {
          Serial.println("READY");
          readyornot = 1;
    ready = 1;
    readyornot = 0;
    out = 0;
    for(int p = 0; p < 9; p++) {
      pin = p + 2;
      if(avail[p] == 1) { //this writes to the LEDs
        digitalWrite(pin, LOW);
        Serial.print("LOW- ");
        Serial.println(pin);
      else {
        digitalWrite(pin, HIGH);
        Serial.print("HIGH- ");
        avail[p] = 1;
    delay(100);  //this delays the whole script
    nomore = 0;
    Serial.println("nomore reset");
  for(int q = 0; q < 9; q++) {
    pin = q + 2;
  Serial.println("CLEAR");
This is going to be part of a large canvas which I will complete in the exam on Monday/Tuesday. The only reason I'm posting this now is because I'm going to be using a QR Code in the artwork, so I need to have a link and working code before then. There will also be a YouTube video (or Vimeo) of it in action. How do you embed a video in this forum?
Also, I've attached an OK image taken on my iPod. Enjoy!
EDIT 1: Modified the code for tomorrow so that it can be calibrated based on input from A2-A5. This should counter any resistance involving the conductive paint!
EDIT 2: DONE! Here's a video: http://www.youtube.com/watch?v=OGRlFtp_4RI&feature=youtu.be
« Last Edit: December 18, 2012, 02:14:24 pm by terrabyte_aura » Logged
Pages: [1]   Go Up
Print
Jump to:
