Loading...
Pages: 1 [2]   Go Down
Author Topic: I2C Repeated Start  (Read 3115 times)
Offline Offline
Newbie
View Profile
Hello,
I use this code to read the temperature from the MLX90614 IR sensor (see attachment).
The sensore has address 0x5A and I read 3 bytes from internal address 0x07.
As you can see in the captured signal, the controller sends 2 ACK and one NACK just before the STOP condition.
I suppose there is something wrong in your code, can you send it to me to have a look? Or share it somewhere on the internet.
Best regards,
Dan.
Logged
USA
Offline Offline
Newbie
View Profile
WWW
Great Dan!
I'll check it out on Monday.
Logged
USA
Offline Offline
Newbie
View Profile
WWW
Dan,
You got it.  Coding error.  It looks like I had two instances of twi going on...
Everything is working fine now.
Many thanks!
Code:
    //start read, then get n-1 responses
    TWI_StartRead(pTwi, i2c_addr, i2c_register+i, 1);
    if (!Embiic_WaitByteSent()) {//A NACK indicates a bad address, or broken com.  Exit.
      Error_Code = 100;
      TWI_SendSTOPCondition(pTwi);
    for(i = 0; i < numOfBytes-1; i++) {
      if (Embiic_WaitByteReceived()){
        params[i] = TWI_ReadByte(pTwi);
        params[i] = 0;
        Error_Code = 101;
    if (Error_Code > 0) {  //in case error from for loop above
    //now send stop before last receive request
      params[i] = 0;
      Error_Code = 101;
-Chris
« Last Edit: February 04, 2013, 04:47:08 pm by chriskner » Logged
Offline Offline
Newbie
View Profile
Hi Dan and Chris,
Do you mind sharing the code for the use of a MLX90614? I'm also trying to get one running on a Due, but unfortunatelly I'm really not into (machine)code. What I've seen in your posts is really to much for me.
regards,
Jelle
Logged
Offline Offline
Newbie
View Profile
You can find the code attached to one of the posts above.
The name of the attachment is MLX90614_Direct_Access.ino
Feel free to use it in any way you like.
Logged
West Yorkshre UK
Offline Offline
Newbie
faster, smaller, more beautiful
View Profile
I2C now working on the Due, many thanks cdan , a few address changes and the MPU6050 who am I reg is answering to your MLX90614 code.
Logged
Offline Offline
Newbie
View Profile
Can you please share your code for the MPU6050?
Logged
Russia
Offline Offline
Newbie
View Profile
Chris, can you share the function Embiic_WaitByteSent()?
I tested the method MLX90614_Direct_Access.ino on DUE + IR sensor TI TMP006.
Object temperature is not displayed correctly smiley-sad
Logged
USA
Offline Offline
Newbie
View Profile
WWW
Sure...  It's more than you asked for, but here are some checking routines:
(Embiic is the name of the project this code was used in)
Code:
uint32_t I2C_Get_Status_Register(){
  return pTwi->TWI_SR;
boolean Embiic_Check_NACK(uint32_t sr) {
  return ((sr & TWI_SR_NACK) & TWI_SR_NACK);
boolean Embiic_Check_TXCOMP(uint32_t sr) {
  return ((sr & TWI_SR_TXCOMP) == TWI_SR_TXCOMP);
Code:
boolean Embiic_Wait_ACK_TXCOMP() {
  unsigned long start, now;
  uint32_t sr, tw_nack, tw_txcomp;
  tw_txcomp = 0;
  start = micros();
  while (tw_txcomp == 0) {
    sr = I2C_Get_Status_Register();
    now = micros();
    if (now < start) {  // handle overflow, at at the expense of a longer timeout
      start = now;
      now++;
      now = now - start;
    if (now > I2C_ACK_TIMEOUTuS){
      DBG_PRINTLN("Embiic_CheckTXCOMP: Timeout.");
      I2C_Reset_Request = 1;
      return false;
    tw_nack = Embiic_Check_NACK(sr);
    if (tw_nack != 0) {
      DBG_PRINTLN("Embiic_CheckTXCOMP: NACK. Natch.");
      return false;
    tw_txcomp = Embiic_Check_TXCOMP(sr);
  return true;
Code:
boolean Embiic_Wait_TXCOMP() {
  uint32_t sr, tw_txcomp;
  tw_txcomp = 0;
  start = micros();
    now = micros();
      start = now;
      now++;
      now = now - start;
      return false;
  return true;
Code:
boolean Embiic_WaitByteSent() {
  uint32_t sr;
  //bad: TXCOMP is 1, NACK is 1
  start = micros();
  while (1) {
    now = micros();
      start = now;
      now++;
      now = now - start;
      DBG_PRINTLN("Embiic_WaitByteSent: Timeout.");
      return false;
    if ((sr & TWI_SR_NACK) & TWI_SR_NACK) {
      DBG_PRINTLN("Embiic_WaitByteSent: NACK. Bad Address?");
      return false;
    if ((sr & TWI_SR_TXRDY) == TWI_SR_TXRDY) {
      return true;
  return true;
Code:
boolean Embiic_WaitByteReceived() {
  start = millis();
  while (!TWI_ByteReceived(WIRE_INTERFACE)) {
    now = millis();
      start = now;
      now++;
      now = now - start;
    if (now > I2C_READ_TIMEOUTmS){
      DBG_PRINTLN("Embiic_WaitByteReceived: Timeout.");
      return false;
  return true;
-Chris
I'm not a coder. I just play one on the internets.
Logged
Russia
Offline Offline
Newbie
View Profile
Thank you Chris!
Unfortunately, did not work smiley-sad
With MEGA R3 sensor indicates correct.
I will continue to investigate the cause...
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
