Dee Why NSW
« on: December 15, 2012, 08:21:01 pm » |
Is anybody familiar with the board in the upper picture?
I am considering putting a Sainsmart 3.2" screen on a Mega 2560, which obliges me to put a new full-size proto board in between. There don''t appear to be many cheapo options on eBay, but I found this and almost bought it, until I suddenly realised I didn't understand it. The holes for the headers don't appear to have duplicates for the wiring. The boards I have used have duplicate holes for the wiring immediately adjacent and labelled. This is such a bleeding obvious way of doing it that it never occurred to me that there might be another way.
So, is there something secret here, but more apparent on the back of the board? Or does the wiring have to be soldered directly to the header pins? This is the upper picture.
I guess I'm now more likely to use the second choice, lower picture. I was apprehensive about the surface mount pads, but I now realise I don't have to use them.
« Last Edit: December 15, 2012, 08:24:11 pm by NickPyner »
Massachusetts, USA
« Reply #1 on: December 16, 2012, 11:38:43 am » |
The $4.83 Arduino Mega ProtoShield V3 from FastTech.com might be a good choice: http://www.fasttech.com/products/1009/10001547/1115501They're in Hong Kong but I ordered from them recently and my order arrived in Massachusetts in 10 days.
Dee Why NSW
« Reply #2 on: December 16, 2012, 06:06:06 pm » |
Thanks for your comment.
As I saw the picture I thought "Gawd, I've jumped the gun and I should have bought that", but I now see that the 36pins at the end are not stackable. This is the whole point of the exercise and I would have to remove what they provide. The second picture I show is the same PCB and I have bought that.
Are you using the surface mount area at the other end? If I can sort out my bluetooth problems I might put a bare bluetooth module there. I assume it is made for one of those and I was thinking I might drill the pads for the four connections.
Now to find the 2x18 stackable header.
Boston area, metrowest
« Reply #3 on: December 16, 2012, 07:02:30 pm » |
You can use a 2 each 8-pin and 10-pin female header, both available at dipmicro.com and used here
Dee Why NSW
« Reply #4 on: December 16, 2012, 07:10:02 pm » |
Thanks. I see that is what is used on a mass-produced board, which is a pretty strong signal.........
« Reply #5 on: December 16, 2012, 07:11:14 pm » |
« Reply #8 on: December 16, 2012, 08:08:03 pm » |
This collection of parts: 1x 6 Pin Single Row Female 2x 8 Pin Single Row Female 1x 10 Pin Single Row Female 1x 6 Pin Double Row Female is no help for the mega screw shield. Ordering lots of 8 and 10 pin female headers to support 3x10pin and 7x8pin per shield works out much better. I have parts for 14 kits on hand right, 2 of them going out tomorrow.... http://www.crossroadsfencing.com/BobuinoRev17/
Dee Why NSW
« Reply #9 on: December 16, 2012, 08:56:21 pm » |
I'm not sure what you are saying here. I've ordered two kits from the USA. This gives me the 36pin, just like the picture you show, plus a 6 and an 8. The left-overs will probably get used eventually. Thanks
« Reply #10 on: December 16, 2012, 10:13:43 pm » |
Your prior post didn't indicate you were ordering 2 kits to make a partial set of headers for a mega. I was looking at it from the point of view of if being a partial kit, when I know it takes 3 10-pin headers and 7 8-pin pin headers to populate a mega.
And 3 6-pin headers won't fill the 18-pin header because the overall width of the 6-pins stacks up & causes fit interference. An 10-pin and a 8-pin do alslo, but isn't too bad.
Dee Why NSW
« Reply #11 on: December 16, 2012, 10:50:06 pm » |
OK. If the 10+8 fits on that green board, I guess that's good enough for me. Nothing that a bit of 240 wet-and-dry can't fix........
You would reckon whoever makes the non-stacking 36pin for Mega would also make the stackables. Maybe they simply are not popular enough - yet.
« Reply #12 on: December 16, 2012, 10:58:16 pm » |
4Ucon does make stackable connectors - just no one in the US is carrying them yet. I'm certainly not going to order 1000 of them
« Reply #13 on: December 17, 2012, 02:21:43 pm » |
how do I get 4 of those mega screw shields in England ?
« Reply #14 on: December 17, 2012, 09:46:34 pm » |
Send ($35 * 4) +$17 for shipping via paypal to cardinalflyer @ comcast dot net and I'll have them shipped via USPS the next day. I need e-mail & phone number for US export forms, you can e-mail those to the same address.
