Loading...
Pages: [1]   Go Down
Author Topic: Help!! tlc5940 library maximum fade buffer length with 10 tlc's  (Read 223 times)
Offline Offline
Newbie
View Profile
Hi, I'm using the Tlc5940.h library to control 10 Tlc chips, I figured that I needed to change the TLC_FADE_BUFFER_LENGTH in tlc_fades.h from the default 24 to 240. However, it stopped working at 120. Is it because of not enough ram?
If so what should I do to get it working?
thanks
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
The comment right above the line you altered says:
Code:
/** The default fade buffer length (24).  Uses 24*13 = 312 bytes of ram. */
So...what happens if you change that from 24 to 240?
Logged
Pages: [1]   Go Up
Print
Jump to:
