Loading...
Pages: [1]   Go Down
Author Topic: Suggestion: New toolbar button: "Upload, then Monitor"  (Read 1392 times)
Offline Offline
Sr. Member
View Profile
Hi all,
I recently added a toolbar button to my 1.0.3 IDE called "Upload, then Monitor" (which, with shift, is "Upload with Programmer, then Monitor"). All it does is compile and upload the sketch, if it's successful, then the serial monitor is automatically opened. It makes repeated "edit/test" cycles a bit easier by eliminating the need to hit two buttons.
If anyone would like to try it or use it, please download the attached "pde.zip" file which contains the new "pde.jar" file. In your Arduino /lib directory, rename your existing pde.jar to pde.backup, then unzip the new file into the same place. You should now have two new files: the new pde.jar, and in the theme directory, a new file named "buttons2.gif" which is the modified icons file containing the new "upload, then serial" icon.
See if you like it, and please comment if it works properly, if you have any suggestions, etc....
Thanks.
-- Roger
(mods: if this is in the wrong place, sorry and please move it).
« Last Edit: December 16, 2012, 08:05:27 pm by Krupski » Logged
Offline Offline
Full Member
View Profile
you might be interested in this
http://arduino.cc/forum/index.php/topic,118440.0.html
Logged
Offline Offline
Sr. Member
View Profile
I see it's for Windows (I use Linux). But the source is included so maybe I can compile it here.
Thanks for the pointer!
Logged
0
Offline Offline
Sr. Member
Always making something...
View Profile
WWW
I've recently been looking through that source code, to adapt part to Teensyduino.
If you make any progress isolating the code for only this 1 feature, would you please post your results here?
Logged
Pages: [1]   Go Up
Print
Jump to:
