Loading...
Pages: [1]   Go Down
Author Topic: Can you use digitalWrite too much?  (Read 521 times)
South East USA
Offline Offline
God Member
View Profile
In my loop I have something like:
if (reading == idleVal) motorIdle();
and then that function is:
Code:
void  motorIdle(){  //turn off motor
  digitalWrite(motorUpPin, LOW);  //motor is not going up
  digitalWrite(motorDownPin, LOW);  //or down
...it's going to be idle most of the time in real life.  Does that matter that it continually keeps setting the pin low???  If it's low, it's low, ...it won't hurt anything will it?
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Makes no difference to the processor or any hardware. Often that's as good a way as any because it saves extra logic although it does go against the grain a little I admit.
______
Rob
« Last Edit: December 13, 2012, 10:24:55 pm by Graynomad » Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
South East USA
Offline Offline
God Member
View Profile
Thanks.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Or put another way, electrons don't wear out!
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Yea. electrons are the only moving parts in a AVR chip.
OT, but also any one specific electron is pretty slow poke. An instructor once explained that while the electron current flow through a conductor is near or at the speed of light, a specific given electron may take years to travel from one end of a 12" wire to the other. Not sure about the year part (I'm old now!), but it was of a duration that made my jaw drop as I slowly got an appreciation of how many damn electrons are in a 12" 22 gauge piece of copper wire.
« Last Edit: December 17, 2012, 12:34:34 am by retrolefty » Logged
South East USA
Offline Offline
God Member
View Profile
Thanks. I know I've read something about only writing some many times to the EEPROM, and there's no moving parts in there is there?  I'm sure there's a big difference so how.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Well yes, it was a glib statement - most electronic devices only have electrons moving.
An EEPROM involves programming with high voltage gradients to force (well, quantum-tunnel) electrons through an oxide insulator -
this stresses the insulating layer and leaves electrons trapped in flaws in the oxide, these build up and eventually cause
mis-behaviour of memory cells - so technically the electrons don't wear out but the flaws in the insulator allow degradation
of the device in this manner.
Electronic devices also age (the material isn't stable long-term), suffer from thermal cycling (causes mechanical stresses),
and various effects, but in general should stay reliable if kept below "absolute maximum ratings".
Logged
Turku
Offline Offline
Full Member
Arduino rocks
View Profile
My colleagues and I once tested a microprocessor controlled device. We used softwate loops to test every system there were. One of the parts/systems was a flashrom to store some settings. We left the loop running and went to have a coffee break. After the break the chip was broken. It took some time before we understood what was wrong.
More info about flash roms and why they break.
http://en.wikipedia.org/wiki/EEPROM
Logged
Pages: [1]   Go Up
Print
Jump to:
