Topic: MPU-6050 gyroscope unit convert to degree per second (Read 8328 times) previous topic - next topic
matt20492
I watched the Playground article. http://playground.arduino.cc/Main/MPU-6050
I tried to write a sketch, but i don't know the gyroscope unit.
i put MPU-6050 on the table, I got some data such as gyro x,y,z : 367, 220, -812
Can i converted the data into  degree per second?
johnwasser
The "ZRO" (Zero Rate Output) on the 6050 is +/-20 degrees per second.  At highest sensitivity, one degree per second is a value of 131 so the zero rotation value can be +/-2620.  Looks like your zero is well within spec.
To find your zero, take a long-term average.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Krodal
The example shows the raw values. They are not offset compensated.
So you need to compensate the offset, and after that convert them to degrees per second.
kate213
hi guy,
could you tell me the unit of raw data MPU6050?
and how to convert raw data into coordinate ?
Thanks!
michinyon
It is stated pretty clearly in the datasheet.
rholt
Opening this up again.
I've been through the InvenSense Prod Specs for this device and the documentation is 56 pages long.
when I search on "degree", i get 1 find and that basically shows that the gyro sensors can be "digitally programmed to +-250, +-500,..." "Degrees per second".
this, I grant you tells me the sensitivity of the device, but this, along with a lot of information i read through trying to look for the conversion, is by no means
"stated pretty clearly in the data sheet."
with your knowledge of MPU's, maybe this conversion information is uber-simple for you to discern, but for others, who may be LEARNING about the meaning of angular motion and how it is applied in programming, it may be a very "cloudy-murky" area.
"It is stated pretty clearly in the datasheet" came across as, I don't know... MAYBE you were suggesting that the person should read the datasheet... and MAYBE you're reading a different datasheet than I am reading... but couldn't you have just used your words to aim the reader(readers) to a particular Page, Section & Subsection (they ARE clearly stated in the PDF specs), so that the reader could home in on the clearly stated information rather than having to look through 56 pages of information that much may be over their (... our) heads and which is not necessary to the information needed?
I'm jus' sayin'...
Russ from Coral Springs, Fl.
Russ from Coral Springs, Fl, USA
