Topic: Sending data with Ethernet (Read 2737 times) previous topic - next topic
djm2
Hi there
I was hoping some could offer some suggestions/thoughts.
I have an Arduino + ethernet shield in my house which gathers data from some weather sensors.  I want to send this data to a LCD at another house.  My plan is to have another Arduino with an Ethernet shield with the LCD connected to this display at the other house.
I had a look at the examples for Ethernet but I don't know what the best way would be.  Should I host the data on a web page and have the other fetch the data some how or use a chat server setup.
Does anyone have any experience of the easiest way of doing this or other suggestions or sample code?
Regards
David
Krodal
It seems that UDP is best for this, but I don't understand it myself yet.
zoomkat
You could have one arduino/ethernet shield setup as a server to supply the data and another arduino/shield setup as a client to retreive the data from the server and display the data. The below server test code supplies analog pin data to a client web browser.
Code: [Select]
// zoomkat meta refresh server test code
// arduino IDE 1.0
// for W5100 ethernet shield
// the IP address will be dependent on your local network/router
// port 80 is default for HTTP, but can be changed as needed
// use IP address like http://192.168.1.102:84 in your brouser
// or http://zoomkat.no-ip.com:84 with dynamic IP service
// use the \ slash to escape the " in the html
// meta refresh set for 2 seconds
#include <SPI.h>
#include <Ethernet.h>
int x=0; //set refresh counter to 0
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,102); // ip in lan
EthernetServer server(84); //server is using port 84
  // start the server
  Ethernet.begin(mac, ip);
  server.begin();
  // listen for incoming clients
  if (client) {
     while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        // see if HTTP request has ended with blank line
        if (c == '\n') {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println();
          //meta-refresh page every 2 seconds
          x=x+1; //page upload counter
          client.println("<HTML>");
          client.print("<HEAD>");
          client.print("<meta http-equiv=\"refresh\" content=\"2\">");
          client.print("<TITLE />Zoomkat's meta-refresh test</title>");
          client.print("</head>");
          client.println("<BODY>");
          client.print("Zoomkat's meta-refresh test IDE 1.0");
          client.println("<br />");
          client.print("page refresh number ");
          client.println(x); //current refresh count
          client.print("Zoomkat's arduino analog input values:");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(analogRead(analogChannel));
          client.println("</BODY>");
          client.println("</HTML>");
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
pylon
Quote
The easiest way to do this depends on your knowledge in this field. Using the HTTP protocol has the advantage that you can test your server part with your every day web browser. The chat server example is more like the equivalent serial protocol version, so if you have experience with designing and parsing serial protocols, that's the better way to go.
The UDP version suggest by Krodal doesn't give you much benefit in this context. UDP uses less network resources but the use case you describe produces such a small amount of network traffic that the additional complexity and the fewer tutorials available probably don't pay off.
ksduino
You can try our new free service KSduino: http://ksduino.org
You can connect two Arduinos with Ethernet Shields to KSduino and send parameters between it.
KSduino uses UDP to transfer packets so it will be fast. (see: http://blog.ksduino.org/post/37944359140/how-ksduino-works)
Best regards,
Kirill Scherba.
http://ksduino.org
djm2
Hi there
I had a look at ksduino but I am very close to finishing and figured I would just carry on the path I am on.
I got one arduino posting the data to a web address which is great.  Does anyone have any examples or suggests of places of where to look for code of an arduino connecting to a web page to collect data?  My web page is very very simple - a few lines with a value on each line.  My web page is formatted as follows -
Wind speed - 1.57
Wind direction - 55
Wind speed - 1.57
Temperature - 3.06
dewpoint - 3.40
Pressure - 1011.00
Humidity - 94
Days - 18
Months - 12
Years - 2012
Hours - 18
Minutes - 4
David
ksduino
I'll finish one new KSduino example and description soon. In this example one Arduino will send data to another one. I'll send link to you when this test will be ready. I can help you to add all your parameters when this test and description will be finished.
Best regards,
Kirill Scherba.
http://ksduino.org
ksduino
OK, this is Send to Other KSduino example at online documentation: http://ksduino.org/?docs=send_to_other_8ino-example.html
You should download latest KSduino library from the downloads page to run it: http://ksduino.org/?downloads
Best regards,
Kirill Scherba.
http://ksduino.org
zoomkat
Client code that when the arduino receives an e from the serial monitor, the arduino gets a test file from my web server and sends it to the serial monitor. You can try it downloading the page from your web site.
Code: [Select]
//zoomkat 9-22-12
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "web.comporium.net"; // zoomkat's test web page server
EthernetClient client;
void setup(){
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  Serial.println("Better client test 9/22/12"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.0"); //download text
    client.println("Host: web.comporium.net");
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
ksduino
There is step by step instruction how to connect two Arduinos with KSduino: http://help.ksduino.org/post/38261558718/how-to-send-parameters-from-one-to-another-arduino
Best regards,
Kirill Scherba.
http://ksduino.org
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
