Topic: Displaying temperature on a MAX6951 (Read 1 time) previous topic - next topic
0miker0
Dec 17, 2012, 07:49 pm Last Edit: Dec 18, 2012, 01:19 pm by 0miker0 Reason: 1
I found code for driving the MAX6951 on this site that displays digits from the serial terminal. I've modified the code and attached a 1-wire temperature ic but the digits are pushed to the far left of the display with what was zeros to the right.  0x03 in the SCANLIMIT_ADDRESS will knock off the trailing zeros but I was wondering if the temperature can easily be pushed to the right. I believe that having SCANLIMIT_ADDRESS to 0x0F and putting blank digits in the first two spots will work but I have no idea how to do this.
Code: [Select]
Using SPI for interfacing to MAX6951
- pin 13      SCK      SPI clock  ,DISPLAY CLK, PIN#2
- pin 12      MISO     SPI master in, slave out  ,NOT USED
- pin 11      MOSI     SPI master out, slave in ,DISPLAY DIN, PIN#4
- pin 10      SS       SPI slave select, DISPLAY CS, PIN#3
The default SPI configuation is as follows:
- SPI Master enabled
- MSB of the data byte transmitted first
- SPI mode 0 (CPOL = 0, CPHA = 0)
- SPI clock frequency = system clock / 4
#include <studio.h>
#include <OneWire.h>  //for DS18S20 temp sensor
#include <SPI.h>  // bring in SPI Library
// SPI uses hardware Chip Select vs having device address
#define DECODE_ADDRESS 0x01// 0x07, all 8 on
#define INTENSITY_ADDRESS 0x02 // 0x07 to start, half intensity 02
#define SCANLIMIT_ADDRESS 0x03 // 0x07, all 8 on
#define CONFIG_ADDRESS 0x04
// 0000 0001 => 0 shutdown, 1 = normal mode, no fooling with blink modes & stuff
// 0000 0010 = not used
// 0000 0100 => 0  slow blink, 1 = fast blink
// 0000 1000 => 0 = global blink disabled (Plane 1 data ignored), 1  global blink enabled Plane 1 data used)
// 0001 0000 => 0 = blink unaffected during I2C acknowledge
// 0010 0000 => 0 = data unaffected during I2C ack, 1 = data cleared
// 0100 0000 => not used
// 1000 0000 => blank phase - blink status is read back
// for this use: 0000 0101 => normal operation, fast blink
#define DISPLAYTEST_ADDRESS 0x07 // 0x01, on, 0x00 off 07
#define DIGIT0_ADDRESS 0x20 // write Plane 0 20
#define DIGIT1_ADDRESS 0x21 // write Plane 0 21
#define DIGIT2_ADDRESS 0x22 // write Plane 0
#define DIGIT3_ADDRESS 0x23 // write Plane 0
#define DIGIT4_ADDRESS 0x24 // write Plane 0
#define DIGIT5_ADDRESS 0x25 // write Plane 0
#define DIGIT6_ADDRESS 0x26 // write Plane 0
#define DIGIT7_ADDRESS 0x27 // write Plane 0
int DS18S20_Pin = 0; //DS18S20 Signal pin on digital 0
int ColonLED=3;
const int slaveSelectPin = 10;
int led = 3;
//Temperature chip i/o
OneWire ds(DS18S20_Pin);  // on digital pin 2
Serial.begin(9600); //monitor Temp
// define pins used - 13,12,11,10 defined by SPI
pinMode(ColonLED, OUTPUT);
//pinMode(SS, OUTPUT);
pinMode (slaveSelectPin, OUTPUT);
pinMode(led, OUTPUT);
// start up SPI
SPI.begin(); // nothing in () because we are the master
//  write config register
digitalWrite(slaveSelectPin,LOW);
SPI.transfer(CONFIG_ADDRESS);  // select the Address,
SPI.transfer(0x05);      // select the data 5
digitalWrite(slaveSelectPin,HIGH); // take the SS pin high to de-select the chip:
//  write intensity register
SPI.transfer(INTENSITY_ADDRESS);  // select the Address,
SPI.transfer(0x00);  //DIM Display  ,0x0E is full brightness
//Serial.println("intensity register");
// write scanlimit register
digitalWrite(slaveSelectPin,LOW); // take the SS pin low to select the chip:
SPI.transfer(SCANLIMIT_ADDRESS);  // select the Address,
SPI.transfer(0x0F);      // select the data //Was 0F
// write decode register
SPI.transfer(DECODE_ADDRESS);  // select the Address,
SPI.transfer(0xFF);      // select the data, FF
//digitalWrite(SS,HIGH);   // take the SS pin high to de-select the chip:
//Serial.println("decode register");
//display test
SPI.transfer(DISPLAYTEST_ADDRESS);  // select the Address,
SPI.transfer(0x00);      // select the data,01
delay (1000);
 float temperature = getTemp();
 int t = temperature*100;  //get rid of decimel point
 int ones = t%10;
 int tens = (t/10)%10;
 int hundreds = (t/100)%10;
 int thousands = (t/1000)%10;
 write_digits(0x00,0x00,ones,tens,hundreds+0x80,thousands); //0x80 is the decimal
static void write_digits(int u, int v,int w,int x, int y, int z)
  SPI.transfer(DIGIT5_ADDRESS);
  SPI.transfer(u);      // select the data
  SPI.transfer(DIGIT4_ADDRESS);
  SPI.transfer(v);      // select the data
  SPI.transfer(DIGIT3_ADDRESS);
  SPI.transfer(w);      // select the data
  SPI.transfer(DIGIT2_ADDRESS);  // select the Address,
  SPI.transfer(x);      // select the data
  SPI.transfer(DIGIT1_ADDRESS);  // select the Address,
  SPI.transfer(y);      // select the data
  SPI.transfer(DIGIT0_ADDRESS);  // select the Address,
  SPI.transfer(z);      // select the data
float getTemp(){
 //returns the temperature from one DS18S20 in DEG Celsius
 byte data[12];
 byte addr[8];
 if ( !ds.search(addr)) {
     //no more sensors on chain, reset search
     ds.reset_search();
     return -1000;
 if ( OneWire::crc8( addr, 7) != addr[7]) {
     Serial.println("CRC is not valid!");
     return -1000;
 if ( addr[0] != 0x10 && addr[0] != 0x28) {
     Serial.print("Device is not recognized");
     return -1000;
 ds.reset();
 ds.select(addr);
 ds.write(0x44,1); // start conversion, with parasite power on at the end
 byte present = ds.reset();
 ds.select(addr);
 ds.write(0xBE); // Read Scratchpad
 for (int i = 0; i < 9; i++) { // we need 9 bytes
   data[i] = ds.read();
 ds.reset_search();
 byte MSB = data[1];
 byte LSB = data[0];
 float tempRead = ((MSB << 8) | LSB); //using two's compliment
 float TemperatureSum = tempRead / 16;
 float test = ((MSB << 8) | LSB);
 return TemperatureSum;
PaulS
At 77 posts, you REALLY should know how to post code properly. Modify your post, and do it right. The # icon is there for a reason. Use it!
0miker0
I have corrected post by posting code the proper way. Thanks PaulS.
PaulS
Quote
What are they now?
Quote
So, experiment. Just set SCANLIMIT_ADDRESS to 0x0F and make no other changes. What happens?
A link to the device in question would be useful.
