Topic: Arduino UNO @ 20MHz (Read 26309 times) previous topic - next topic
rvasque
Thank you!  This will come in very useful.
I'm interfacing to a 128x64 GLCD and I could use more speed to display multiple spectrum bar graphs faster.
dhenry
If you want, you will find that most of them will run at 32Mhz @ 5v.
Pretty amazing.
nickgammon
Hmm. Time to revisit my VGA output sketch. If I can get it to run that fast I could get somewhat higher resolution.
Does it get hot?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
Well that idea will have to wait. Don't have any 24 MHz crystals. Nor does my function generator output above 20 MHz.
Oh wait, found 5 x 24 MHz crystals on eBay for $1.41 + free postage. Kind of unbelievable but whatever. Worst I will do is lose $1.41.
gvi70000
Hi Nick,
No it doesn't get hot at all. I test it now for 4 hours in a row and i found out that serial, adc conversion and eeprom read/write works well.
No trouble so far. I've change one other board and put it to the test.
I will see in the morning if it goes well.
nickgammon
I ordered 100 x 20 MHz crystals for $5.69 as well.
We'll see what happens with that one. :)
bperrybap
Nick,
I get crystals from Tayda:
http://www.taydaelectronics.com/crystals-resonators-oscilliators/crystals.html
They have pretty low prices on everything they sell and their shipping is pretty
low as well.
--- bill
nickgammon
Thanks Bill.
If the worst comes to the worst, they can become stocking-fillers next year.
"What, this, Dad?"
"It's a crystal, darling"
"Cool!"
E40racer
Today I tried getting an ATmega328P-PU to work at 20MHz. I downloaded the optiboot.zip file and copied the contents to my optiboot folder (I'm using Arduino-1.0.3 on linux). I made the necessary changes to boards.txt. I then started the Arduino ide and selected the "GVI High Speed (5V-20MHz-250k Baud)" board. Burned the bootloader with an USBasp, uploaded without errors. I then hooked up my ftdi usb/serial converter to the board and tried uploading the blink sketch. But no luck, it can't get serial communication. I tried another ftdi usb/serial converter but I got the same error:
avrdude: ser_recv(): programmer is not responding
Just to be sure I plugged the chip in another board with a 16MHz crystal. Bootloaded the Uno bootloader and uploaded a couple of sketches, no problems there, so the chip is fine.
When I try uploading a sketch the led on pin 13 blinks a couple of times. So can I assume that the bootloader is working?
www.bajdi.com
nickgammon
What is the entry for boards.txt for the board you selected? In particular, the upload baud rate?
Where did you get the bootloader which expects to run at 20 MHz?
E40racer
#25
Feb 03, 2013, 10:51 pm Last Edit: Feb 03, 2013, 10:54 pm by Bajdi Reason: 1
From a previous post in this topic: http://arduino.cc/forum/index.php/topic,137902.msg1041577.html#msg1041577
I copied the code from that post to my boards.txt file, baud rate is set to 250000.
www.bajdi.com
nickgammon
Hmm. Well I was getting strange error messages if I had a non-standard baud rate:
Code: [Select]
avrdude: ser_setspeed(): tcsetattr() failed
avrdude: ser_open(): can't set attributes for device "/dev/cu.usbserial-A900gcHm": Invalid argument
ioctl("TIOCMGET"): Bad file descriptor
avrdude: ser_close(): can't reset attributes for device: Bad file descriptor
E40racer
I get this:
Using Port                    : /dev/ttyUSB0
         Using Programmer              : arduino
         Overriding Baud Rate          : 250000
avrdude: serial_baud_lookup(): Using non-standard baud rate: 250000
avrdude: Send: 0 [30]   [20]
Uploading sketches with the USBasp works.
www.bajdi.com
gvi70000
Did you change the xtal to a 20MHz one?
devobitch
would you not just change the crystal to a faster one?
do you really need to change the code?
devobtch
