Topic: QUESTION ABOUT SOLAR PANELS (Read 2056 times) previous topic - next topic
julienne
Our project is SOLAR-POWERED CHARGING STATION
My question is:
How many volts will be consumed by one laptop if we used 100watt solar panel?
Can you give some formulas for the computation?
keeper63@cox.net
You'll need to give us more information - how about a link to the panel(s) in question. Also, do you propose a direct-drive from the panel, or are you going to use an inverter (plus, will there be a battery bank in use)...?
We'll also need more information on the power needs of the laptop in question (which is what?)...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
cbagz
DC volts to watts calculation formula
The power P in watts (W) is equal to the voltage V in volts (V), times the current I in amps (A):
P(W) = V(V) × I(A)
A standard laptop is 19 volt's 3.42 amp's = 64.98watt's
